Question about Poulan 25cc 2-Cycle Gas Powered String Trimmer with Curved Shaft #P1500
Poulan Pro PPB250 String trimmer How do you
Poulan Pro PPB250 String trimmer. How do you remove the clutch to replace the pull string?
  • 76 Answers
SOURCE: replace string on trimmer
Hi
check in you tube .
The video is talking about trimmer strings in general , but my experience is that all trimmers are more or less the same.
hope it helps
http://www.youtube.com/watch?v=WFu66Q6J62Q
Posted on Jul 16, 2009
woobie dog
  • 1273 Answers
SOURCE: string for a Poulan Pro PPB330
Pull your spool off, and look next to the notches on the bottom of the spool. The decimal number is the size of line that you can use. Some spools will have more than one size listed; they can use either size.
Best regards, --W/D--
Posted on Aug 21, 2009
nova2nv
  • 197 Answers
SOURCE: Ref: Stihl FS46 string trimmer. Broken Flex shaft.
Remove orange sheild,remove single screw holding head in shaft then grab head with pliers and twist side to side until complete head is free.You should then be able to grab part of shaft.On power head loosen screws {about one turn each} that hold two white case halves near trigger,I think there are four,then there is a single torx screw on the bottom of lower case half in the middle that must be taken out to allow tube to be removed.Romove flexshaft from top.Check 4 plastic burnt to flexshaft,if there is you must replace tube liner as well,usally around bent part of tube the liner will go bad.
Posted on Nov 28, 2009
jyackle5
  • 8197 Answers
SOURCE: I lost my manual on
You can get the manual on the link below.
http://weborder.husqvarna.com/order_static/doc/NOUS/NOUS2009/NOUS2009_115156126.pdf
Good Luck and please rate 4 thumbs up for the free answer
Posted on Sep 12, 2010
rycgl
  • 1545 Answers
SOURCE: how to test a poulan pro 31cc ppb 250e gas string
The proper way to test it is with an ohm meter by doing a continuity test. If your switch isn't working on the machine, there is the possibility that the wire from it that connects to the coil module is loose or is off. I would check for that first and then do the continuity test if needed. The coil is under the front cover of the machine and will require disassembly to access where the black switch wire spade terminal is.
Posted on Oct 21, 2010
How do I remove the shaft from my trimmer
String Trimmer Drive Shaft Replacement - Poulan Pro ...
? 2:18
www.youtube.com/watch?v=A_Sv1S7r_-o
Mar 4, 2013 - Uploaded by RepairClinic.com
This video provides step-by-step instructions for replacing the lower drive shaft on Poulan string trimmers. The .
Jul 28, 2015 | Garden
Poulan trimmer drive shaft attachment problem
Square drive on the end of the drive shaft has to line up with the drive on the output of the clutch.
Jul 07, 2014 | Poulan Pro Pp125 25cc Gas Straight Shaft...
How to replace flexible drive shaft on Poulan Twist n Edge, TE 450 CXL LE string trimmer. I have removed the lower string assembly - can't remove shaft.
Shaft needs to come out the top, will have to split the case or remove motor from shaft to pull cable out
Aug 29, 2011 | Poulan Garden
Replace pull string (how to put string on after taking cover off)
Basically, pull the string through the winding hole and knot it off insuring no more than .25" tail on the knot and pull tight. :)
Jul 22, 2010 | Poulan/Weed Eater No. Te475 952711797 17"...
Replacing pull string on Poulan BVM200VS leaf blower
You will need to split the housing and remove the impeller wheel. In doing this you will have to disconnect the throttle cable and the switch assy. This can be a hand full if you have never done one.
In the future when you are purchasing a string trimmer or blower
or hedge trimmer, be sure that the starter can be removed by
removing 4 screws. This makes starter repair a 5 minute $10 job
instead of an hour $40 or more job. The problem is that you will
not find this in most home centers or box stores. You will have to
go to a full service dealer.
Sep 12, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
How do you put string in
turn trimmer upside down grab the spool head firmly and pull out replace string but wind in the way arrow shows you and replace fishing the loose end back through the hole on the side as you slip back together ,once together grab string and pull to remove any slack and away you go
Aug 22, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
String for a Poulan Pro PPB330
Aug 21, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
How do you wind replacement line to the Poulan Pro String Trimmer?
If it is a duel line trimmer then:
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
If it is a single line trimmer, just wind a single piece of string clockwise onto spool.
Jim
Jun 28, 2009 | Poulan Pro Pp125 25cc Gas Straight Shaft...
Poulan 25cc 2-Cycle Gas Powered String Trimmer with Curved Shaft #P1500 Logo
141 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
