Error code 7 for Haier
Did you find out what this error refers to?
Thanks for your help.
  • nic_nac_nou Jan 25, 2009
    keeps reading error 7
6ya staff
SOURCE:
Anonymous
  • 7 Answers
SOURCE: error code 7
The error code 7 is in fact a motor error.
The motor that drives the spin cycle has become faulty. The only solution now is to get an engineer in to fix it or get it sent away to get repaired.
Posted on Oct 26, 2008
Anonymous
  • 70 Answers
SOURCE: I keep getting an error code of F35. I can find
I haven't seen an F-35 error code listed on this specific model of Kenmore washer. I do see an F-32 error code; this indicates a pressure switch failure. The Sud error code indicates a suds lock condition.
Be sure that you are using HE laundry detergent & the drain hose is not too low. Other testing will require accessing the internal components & making tests with a volt/ohm meter. If you have a meter & feel safe about making voltage checks.
Posted on Aug 30, 2009
Anonymous
  • 41 Answers
SOURCE: error code 8
Could be water valve stuck open/ malfunction on coil. or possibly level control valve.
Posted on Sep 03, 2009
Anonymous
SOURCE: Error code 7
You need a new motor.
Posted on Feb 04, 2010
Anonymous
SOURCE: My Haier HW-C1460TVE-U washing m/c keeps giving (CLrF) ERROR Code
Anyway, my machine shows an error code "clrf". I just spoke to someone at Comet, and apparently this means there is too much foam in the machine. The machine will then refill with water and try to rinse it out, but if after that the machine still has too much foam in, then it will stop the cycle. Hence why my clothes are still wet (although I'd not realised they weren't rinsed properly either!).
I have not been using excessive amounts of washing powder, and usually use powder tablets or the liquid tablet sort, so they are a set amount and I don't do anything daft like stick 6 tablets in! I find it ridiculous that this would cause a problem with the washing machine, as I've used them perfectly fine with other washing machines.
Anyway, the advice from Comet was to keep trying different washing powders until i find one that foams less.
Posted on Mar 20, 2010
Haier dishwasher HDW9WHT beeps 5 times and won't wash what is wrong with it can I fix it or should I get someone in
7 results (0.54 seconds) Search Results
    Haier HDW100WH / HDW100SS - ProductReview.com.au
    www.productreview.com.au > ... > Dishwashers > Freestanding > Haier
    Rating: 1.7 - ‎30 votes
    Haier HDW100WH / HDW100SS: 30 customer reviews on Australia's largest ... 1.7 out of 5 stars for Haier HDW100WH / HDW100SS in Freestanding Dishwashers. ... I putthis review in to do my part for what I think is a great consumer service you ... it it keeps beeping 10 times telling me doors open??and won't begin cycle.
    Haier Dishwasher Error Fault Codes - Lights Flashing ...
    removeandreplace.com/.../haier-dishwasher-error-fault-codes-lights-flash...
    Dec 21, 2015 - Haier dishwasher error codes - flashing lights - beeping ...Dishwasher keep filling water and draining at the same time ... Fix Washing Machine That Won't Drain - Washer Not Draining Water .... 2015; Samsung Galaxy Note 5 Quick Users Guide September 25, 2015; My Freezer Is Cold But The Refrigerator ...
    Dishwasher Has Beeping Sounds Blinking Lights - How To ...
    removeandreplace.com/.../dishwasher-has-beeping-sounds-blinking-light...
    Dec 21, 2015 - At times your dishwasher may need to be reset. ... Haier DishwasherError Fault Codes - Lights Flashing Beeping Sounds My Haier ... Fix WashingMachine That Won't Drain - Washer Not Draining Water .... 2015; Samsung Galaxy Note5 Quick Users Guide September 25, 2015; My Freezer Is Cold But The ...
    How to Troubleshoot & Repair a Dishwasher ' HomeTips
    www.hometips.com/repair-fix/dishwasher.html
Jan 19, 2016 | Haier Dishwashers
Voltas vertis error code E3. what does it mean
Unfortunately, Haier for whatever reason, does not include any of the error codes in their literature. To find out what E3 means and the solution, contact Haier Customer Support 1-877-337-3639, Have the correct model number handy when you call.
I hope this helped you and thanks for choosing FixYa.
Aug 19, 2011 | Haier Energy Star ESA3183 Air Conditioner
I'm getting error 7 on my washing machine wot can I do to fix it
In my list Haier error 7 refers to 'motor overheat protection or is damaged'. Sorry ;-0(
Also for the future it might save you time if you had a manual if you have not already ;-0)
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Jul 25, 2011 | Haier Washing Machines
Error code E1. Please tell me what E1 refers to.
Unfortunately. Haier does not have an online manual for your model AC. However, if you contact their Customer Support Dept 1-877-337-363, they can tell you what the code means and supply you with an Owner's Manual for future reference.
Hope this helped you.
Jun 28, 2011 | Haier ESA3109 WallWindow Air Conditioner
It is displaying error 7
100% motor , you may try the carbons, need help phone 0161 355 8254 , thanks , hope this helps
Mar 02, 2009 | Haier HWD1000
Portable ice maker not working as good as it did
Hi
Kindly refer to the Haier service manual which will help you for sure.
Thanks
Rylee
Jan 30, 2009 | Haier Freezers
Error code 7
Sep 08, 2008 | Haier XQG50-11 Front Load Washer / Dryer
Wont boot just has series of beeps
Table 2. System Beep Codes
Beep Code Possible Cause Corrective Action
1 Memory refresh failure Reseat the DIMMs.
2 Parity cannot be reset Reseat the DIMMs.
3 Memory failure within the first 64 KB of memory Reseat the DIMMs.
4 Timer not operational See Chapter 7, "Getting Help," of the Reference and Troubleshooting Guide for instructions on obtaining technical assistance.
5 Processor failure See Chapter 7, "Getting Help," of the Reference and Troubleshooting Guide for instructions on obtaining technical assistance.
6 8442 keyboard controller error See Chapter 7, "Getting Help," of the Reference and Troubleshooting Guide for instructions on obtaining technical assistance.
7 Processor exception error See Chapter 7, "Getting Help," of the Reference and Troubleshooting Guide for instructions on obtaining technical assistance.
8 Video display memory error See Chapter 7, "Getting Help," of the Reference and Troubleshooting Guide for instructions on obtaining technical assistance.
9 Optional ROM checksum error See Chapter 7, "Getting Help," of the Reference and Troubleshooting Guide for instructions on obtaining technical assistance.
10 CMOS memory error See Chapter 7, "Getting Help," of the Reference and Troubleshooting Guide for instructions on obtaining technical assistance.
11 BIOS checksum error See Chapter 7, "Getting Help," of the Reference and Troubleshooting Guide for instructions on obtaining technical assistance.
Jan 11, 2008 | ASUS K8V-MX Motherboard
Washing Machines Logo
183 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
