Question about Tomtom ONE GPS Receiver
How do you turn up the volume on the Tom Tom. Sometimes when I run my finger across the bottom it shows the volume but now I can't get it to show up.
  • 218 Answers
Generally it should be on the bottom left hand corner. It you touch the area where "no route planned " is shown, the volume bar pops out. If this is not happening, follow this procedure. Tap on : the main screen. Tap on : Change preferences. If the sound is turned off, you will see a green button that says turn on sound. Tap on it. Else Tap on : Arrow. Tap on : Volume preferences. It shows an info screen. Jjust tap on it. On the next page that opens, increase the volume. Also select link volume to car speed as it is a good option. Tap on : test Tap on : Done.
Posted on May 12, 2010
Testimonial: "Thanks for the quick respond. I just was not tapping it on the corner instead running my finger across. Thanks and have a good day."
Kindle paper white won't move from the first page that shows up.
Try swiping your finger across the middle of the screen from right to left. This action turns the page forward. Swiping your finger across the middle of the page from left to right turns the pages backwards. I don't think the icon on the bottom is for page turning.
May 04, 2015 | Amazon Kindle Paperwhite
How to turn volume up on tom tom
when turned on set destnation then run finger along bottom of screen
Jun 25, 2012 | Tomtom One XL GPS Receiver
Tomtom g0 520 no sound
Tap on the bottom left hand corner. If you touch the bottom left hand corner area where "no route planned " is shown, the volume bar pops out.Increase the volume by sliding your finger over it. If this is not workng, follow this procedure. Tap on : the main screen. Tap on : Change preferences. If the sound is turned off, you will see a green button that says, turn on sound. Tap on it. Else Tap on : Arrow. Tap on : Volume preferences. It shows an info screen. Just tap on it. On the next page that opens, increase the volume. Also select link volume to car speed as it is a good option. Tap on : test. Tap on : Done.
May 11, 2010 | GPS
HOW DO I TURN UP THE VOLUME
Users will continually need to quickly change the volume on a TOMTOM units, depending on the loudness of traffic noise, the radio or conversations. Although there are no external volume controls, the volume on the ONE can be easily accessed on screen by touching the bottom left corner of the map display. Once the volume controller appears you just slide your finger to increase or decrease volume. We found the audio levels a little softer on this unit and had to set the volume to around 60% or 70% in order to clearly hear it.
Please rate my help++++Thanks for using Fixya
Dec 12, 2009 | Tomtom One XL GPS Receiver
Tomtom one v2 will not turn on tried soft reset
tap the bottom left hand side of the screen and the volume bar should show. then use your finger to slide the volume up.
Sep 26, 2009 | Tomtom ONE GPS Receiver
Volume control on tom tom 830
With the tt on and displaying the map, tap the bottom left side. At the bottom a slider bar will appear. Use your finger to adjust the volumn to your desired level. Another way is to tap the map screen, then tap change preferances, tap the arrow until you come to volumn preferances and change the volume setting there.
Apr 30, 2009 | LG LN735 GPS
GPS
Click on bottom left corner when unit is on. A slide bar appears, which you can move with your finger.
Mar 09, 2008 | Tomtom ONE GPS Receiver
Volume
Hello Smboston,
I like to help if i can. On your Tom Tom one there is whole at the bottom, this hole is to reset the Tom Tom in case of if it does not work properly. Put a pin (not a sharp one) into the hole and push it couple of times till you feel button is being pressed. That will reset the whole of your Tom Tom and try it then to see if it works fine. If it works good if not you need to check all your volume settings by going into the volume control settings. I hope it works for you. Good Luck.
Feb 01, 2008 | Tomtom ONE GPS Receiver
Volume control
Tap the screen on the bottom left side (while it is showing you where you are on the map). It will bring up a volume screen, and you will hear a sample voice message. You can raise or lower the volume immediately at this point, but if you wait more than 3 seconds the screen will go back to the basic navigation screen.
Jan 06, 2008 | Tomtom ONE GPS Receiver
Tom tom 300
"My tom tom wonts switch on. I have reset it and still it comes on with a boom boom noise and shows the 2 hands on the screen. It also shows the loading bar at the bottom, but then it just freezes and nothing happens. can anyone help please ASAP"
Sound as though your Map data card is corrupt. Remove the SD card and check it with your computer using a card reader. Backup the SD card onto your computer. You can run either chkdsk or go to the drive letter under 'My Computer' right click and select properties, then tools, then check now. You can also try starting the Tomtom with the SD card out of the unit. It should show a picture of the Tomtom with a 'X'. You can also try copying the data on the SD card to another SD card.
Sep 12, 2007 | Tomtom GO 300 GPS Receiver
Tomtom ONE GPS Receiver Logo
2,123 people viewed this question
Top Tomtom GPS Experts
k24674
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
