Question about Whirlpool GC5SHEXNS Side by Side Refrigerator
New Whirlpool Gold (1 month) has a clicking sound when motor starts. Is this normal. Everything works well?
    Problem Solver:
  • 13 Answers
The motor may not be well aligned,try open it.
Posted on May 12, 2010
Whirlpool refrigerator not cooling after storm
Assuming that both freezer and refrigerator temperatures have risen and the humming sound that you heard was followed by a sudden click more than likely the start device on the compressor has gone bad. This is a common problem with all Whirlpool refrigerators (KitchenAid is Whirlpools top of the line product and suffers the same problem).
May 11, 2012 | Refrigerators
I have a Whirlpool Gold electric cooktop. It is
It sounds like the selector switch is shorted, the only way to fix that is to replace the switch
always unplug electricity before working on any electrical appliance
Sep 25, 2017 | Whirlpool GJC3034 Electric Cooktop
Refrigerator won't get cold
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Oct 25, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
We have a 3-month old Whirlpool Gold side-by-side refrigerator. The power is on, but the compressor doesn't seem to be on or cycling. It there a reset switch or another way to get the compressor to run?
The compressor start relay may be loose.If the compressor fan motor is running, listen for a clicking sound at the compressor electrical terminal. Press on the relay for a better contact. If the compressor fan is not running and the compressor is not hot,you have a defective control thermostat.
Jul 16, 2009 | Whirlpool Refrigerators
Dishwasher does not complete cyele
Sounds like you might need a new Start button.
Mar 15, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Knocking noise coming from Whirlpool Gold refrigerator
I also have a new Whirlpool Gold fridge (bottom freezer with French doors) and it was making a knocking sound. The knocking sound would start when the fridge kicks in and starts running to cool, and would last for about a minute or less and be a slow knock.
I called Whirpool customer service since it is new and on warranty. They sent out a technician and he said the knocking is from gas/air built up in the copper tubing for the freezer because the copper tubing is too cold, and when the fridge first turns on it forces the air through, making the knocking sound.
His "fix" was to adjust the copper tubing so that it is closer to the heat of the motor/compressor and heat of another copper line so that the cooler line stays warm so the air/gas doesn't build up. His fix worked slightly, but the fridge is still knocking, just not as bad and not as long - it knocks fast for about 5 to 10 seconds instead of a minute.
Going to call customer service again soon and see where to go from here.
Dec 15, 2008 | Refrigerators
Whirlpool Gold does not spin. No error code.
sounds like the 2 posts are differant. harrison2008 if the coupler is broke it won't agitate.to check it you lean the machine back and look at the motor and gearcase the coupler is right between the 2.you can try turning it by hand with the machine unplugged and it may fall off.
Sep 15, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool gold accubake oven won't re-ignite
i have a whirlpool gas accubake range and only two burners will ignite. The other two burners make a clicking sound and release gas but never light. I have to use a match to light the other two burners and the flame is uneven on one. What should i do?
Feb 18, 2008 | Ovens
Whirlpool GC5SHEXNS Side by Side Refrigerator Logo
60 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
