Help me please
My internal dvd/cd driver in device managment keeps unistalling so I cannot burn music or anything this has been happening a lot over the last few months can anyone help me it is a Philips SPD2412TATA Device I have tried everything I can think of and Philips I cannt get through to them as I am a oldie but know quite a lot about computers as I have been using them since they started but this has got me tearing my hair out I need the driver as I burn lots of music for our tap dancing seniors school in queensland australia so I would be most grateful if someone could advise me on this
thank you
Annie
  • 33 Answers
HI,
Have you tried unplugging the drive inside the computer turn it on and let it load then turn it off again and plug it back in it should work as the computer recongines it as a new dirve and it reinstalla it.
God Bless,
Braydon
Posted on Mar 29, 2008
6ya staff
SOURCE:
Cd/dvd player palys audio discs but if put dvd in says disc importer has stopped. have vista basic
That happened to mines all I did to fix it was to unistall the drivers and reinstall
Apr 06, 2015 | Computers & Internet
My dvd drive can't recognize any dvd or cd .this problem came after I burn some software for the first time
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
or you might have to unistall your burning software restart your computer then reinstall it
hope this helps you
Aug 17, 2011 | Dell DVD-rom DVD Drive
My pc doesnt detect my HL-DT-ST-DVD-RAM-GSA-H55N LG super multi dvd/cd-rom, i tried checking ide cables but still it doesnt read, i cant even see the dvd/cd-rom on device manager------there is no...
you might have to uninstall both the dvd/cd + its drivers then reinstall them actually unplug the cd/dvd from its power cable then restart your computer plug it back in your computer should activate found new hardware or
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
Oct 31, 2010 | LG GSA-H55N DVD-RAM Burner
Dvd drive not detected
Try unistalling the cd drive using your device manager. After removing it from there reboot and see if it is correctly identified and installed by Windows. If not you can manually install the driver or firmware from the drive manufacturers website. Hope this helps.
Jul 26, 2009 | IBM (33P3227) CD-RW/DVD-ROM (Combo) Burner
Cd/dvd wont play burn or anything /emachines el1200-05w
hi there.
have you check driver of the dvd room,on control panel click,click system,click hardware,click device manager,on device maneger click cd/dvd coom,then left click your cd room,click properties check driver,if no driver update,or if you have cd installer
install the driver.have a nice day
Jul 07, 2009 | E-Machines eMachines Desktop PC
Disappearing DVD driver
Use device manager to remove the dvd/cd unit, and then reboot the computer. Vista will locate the unit and install the driver.
It is possible that the dvd/cd unit has failed and requires repair or replacement
Jul 05, 2009 | HP Compaq Presario V6000T 15.4" Notebook...
DVD Drive = JLMS DVD-ROM XJ-HD166
Hello I am looking for a driver for a JLMS DVD-ROM XJ-HD166S.
The system thinks it is a HD166.
I keep getting sent to DriverDetective. What a pain!
Jul 15, 2008 | Lite On XJ-HD166S Internal DVD Drive
I have a cd/rw and a dvd drive both internal,plus a external dvd drive new,the external one was ok yesterday but now it tells me to put in disc,when it is allready in, and that applys to the other two...
Hi charles.It sounds like a Windows error and not the drives so no jumpers or firmware must be changed/flashed.
Instead try to go to device manager and unistall all the CD Devices. Then you have two options. Reboot and the system automatically installs the drives again.
Alternatively you can scan for hardware changes in the device manager immediately after you unistalled the devices.
Hope this helps.
Mar 27, 2008 | Computers & Internet
Toshiba dvd burner problem
Try unistalling the dvd drive in device manager. Go to my computer click on view system information. Then click on hardware, then click on device manager find your dvd drive then right click and unistall a warning window will popup click ok. Once you unistall it restart the system and windows will find new device and reinstall the device driver. Then check if this fixes the problem. if this dosnt fix the problem try removing the dvd drive from the laptop and reinsert it. Sometimes the connection losses contact with the terminals.
Jan 19, 2008 | Toshiba Satellite A105 Notebook
AOpen DUW1608/ARR - DVD Problem
it's a classic drive failure problem where the laser can no longer burn or read dvd's, and show rhr writer as a cdrw, but may still be able to read or write cd's only. You will have to replace the drive, they are quite inexpensive, and very easy to fit.
Aug 10, 2007 | AOpen DUW1608/ARR (914ID37204) Burner
Open Questions:
Computers & Internet Logo
37 people viewed this question
Ekse
Marvin
Marvin
