Question about Dryers
Set timer dryer worked; next time tried but did not start
  • Dryers Master
  • 43,501 Answers
There can be many reasons why your dryerset timer dryer worked; next time tried but did no - 2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryerset timer dryer worked; next time tried but did no - 2_bing.gifng
Dryer2_bing.gif Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on May 12, 2010
Dryer has power to timer, but won't start...I have an Amana electric dryer that allows me to set the timer and I can hear it running, but when I push in the the timer knob to start the dryer (drum
The fuse is mounted on the heater element. When it blows nothing in the heater or motor circuit works but the power to the timer is not interrupted therefore you can hear. Service manual
Feb 11, 2013 | Amana Dryers
Timer will not advance even after replacement. What next ?
Does the timer advance in timed dry setting or will it not advance no matter where its set??
If it does advance in the timed dry (or air fluff setting) but just does not advavce when dryer is set to autodry setting the problem is going to a poor air flow problem and the lint filter/blower housing should be checked for lint build up also the vent tube should be checked for a blockage
If the timer does not advance at all on any setting ya need to check the wiring of the dryer for a possible burnt wire on the neutral side
GENE
Oct 12, 2011 | Estate TEDS840JQ Electric Dryer
Hi The timer isn't working so I tested it, to make sure I did it right here's how... Turned breaker off (220v) Removed one lead, put the clips on both power leads, set multimeter to ohms, turned timer on...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
No, actually it should have some resistance and not be shorted... it is bad...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Sep 06, 2010 | Whirlpool Dryers
I have an older Kenmore 70 Series Dryer, but when I set the timer to dry it doesn't move, it stays in the same place. Any ideas?
do you have heat in the dryer?is it on time dry or auto dry?when the heat shuts down then the timer will advance in auto, when the heat starts again the timer stops.let me know if you have heat or not and send the model next time,will start with 110. or something like that and eight numbers after the dot
Aug 29, 2010 | Kenmore Dryers
Hello...i have a whirlpool dryer ler7646eq1...the dryer will not start...i can hear some action near the switches but dryer will not start at all...any idea where to start....it is getting proper power...
Here are somethings to check.
Make sure you have power and inspect power cord.
Check the door switch when you push in the door switch does it click? Try setting the timer to a different setting see if it works there. The next thing to check would be the thermal fuse but this would require opening up the cabinet.
Apr 08, 2010 | Whirlpool Dryers
My 400 series Kenmore dryer's timer is not working
if the timer will not advance through the cycles and the dryer is getting hot try the timed setting not the sensed setting and if the problem continues on the sensed side only it is not the timer it is the sensor , the sensor is what senses the temperature inside the dryer that is what advances the timer on the sensed side it could be that the timer could be good and the sensor be bad try that
Apr 03, 2010 | Kenmore 400 6943 Dryer
Dryer stops but the timer continues on
Fixed! The "push to start" button was stuck. Must have been some dust. I pushed the knob a few times and that's all it took. Works fine now.
Dec 12, 2009 | Kenmore Dryers
Kenmore dryer dial doesn't advance
That looks like a thermal shut off to protect the dryer if it overheats.
I am assuming that the timer never advances - even in timed mode (as opposed to some automatic drying setting).
Most likely you need to buy an inexpensive multimeter and start testing. There should be a schematic on the back of the dryer either on the outside or on the inside of the back panel.
Since timers on dryers are just mechanical devices that use a small motor (and yours is brand new), it looks like your timer is not getting power. The switch itself is mechanical, you should be able to rotate it to the different settings, press the start button and the dryer will work in the correct mode. Without electricity, the timer won't advance.
Check for loose or burned connections. Dryers use a lot of amperage so occasionally the wires can get burnt and corroded.
Sep 19, 2008 | Kenmore 62602 Electric Dryer
Dryer will not start
when you turn the select knob, you set up the internal cams of the timer. when you press to start or pull to start, you energize the timer motor (buzz) the timer opens the water solenoids. the diaphragm switch senses the water level and moves the timer to the next step. agitate starts for the timed cycle. when its finished the motor kicks in in opposite direction to drain and pump water out.
Dec 10, 2007 | Kenmore 63942 Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
