Question about LG 1.5 Cu. Ft. Full-Size Microwave - Black
Microwave not heating
The microwave is not heating and I am suspecting either the transformer or the radiator are faullty. What could really be the cause?
  • LG Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
sfgeq
Posted on Sep 30, 2010
Jenn-air jmv9169ba will not heat
I hope you are a technician as there are lethal voltages inside a microwave , you could also inadvertently expose yourself to microwave radiation if protective switches are disabled or the door seals are damaged .Open the microwave top cover, disconnect the two wires going to the Power Transformer (The Big one) and connect a Dummy Bulb and Power up if the Bulb goes ON and OFF according to your settings, the control Panel is OK, or else replace .Check the High voltage diodes, Protector Diodes and the high voltage capacitors , if they are OK the magnetron is suspect. The high voltage transformer rarely fails. If the microwave is of the inverter type , forget it, it is not for amateurs to repair.
Jul 08, 2014 | Jenn-Air JMC7000 Microwave Oven
Spacemaker (JVM1871SK) 1800 Microwave doesn't microwave
Remove the case and see if you can localize the smell. Likely suspects are a shorted high voltage diode (replace) or a shorted stirrer bearing (replace stirrer)--a fan-like device located within the sheet metal waveguide near where the microwaves enter the cooking cavity. Make sure to have a cup of cold water in the cooking cavity when looking for problems. The problem could also be the high voltage transformer or the high voltage capacitor, but these are more rare problems. There are no radiation problems with the case off, but there are high voltages associated with the magnetron and it's power supply.
Oct 08, 2009 | GE Profile Spacemaker 1.8 Cu. Ft....
Model JVM1860CF001 not heating...
If you feel comfortable doing so, you may want to check the capacitor. Burning odors however are usually caused by either the magnetron or HV transformer.
Nov 09, 2017 | Microwave Ovens
Emerson Model MWG9111SL Microwave not always working
ok i just opened mine up on counter and found that the white wire on the high voltage transformer had been loose and melted so i put a new female spade connector on and it works fine. i suspect that from a year of use and humm from transformer had loosen it and gotten hot thus loosing connection and getting dirty causing it to overheat and burn off plastic sheilding. easy fix!!!
Feb 14, 2008 | Microwave Ovens
Frigidaire Microwave will not heat and is a little louder than usual.
High voltage parts are suspect. Need to put a voltmeter on the input (primary) side to the high-voltage transformer (big heavy iron thing in there) Should be getting 120Vac when it goes to cook cycle. Don't touch the other (high voltage) side of this transformer. If the power is there, you are looking at replacing either the magnatron or the high-voltage capacitor and diode. Its affordable if you do it yourself - buy the part on EBAY - lookup "universal magnatron"
Hope ya fix it!
Jan 11, 2008 | Frigidaire GLMV169D Microwave Oven
Microwave
Magnatron is suspect. Need to put a voltmeter on the input (primary) side to the high-voltage transformer (big heavy iron thing in there) Should be getting 120Vac when it goes to cook cycle. Don't touch the other (high voltage) side of this transformer. If the power is there, you are looking at replacing the magnatron. Its affordable if you do it yourself - buy the part on EBAY - lookup "universal magnatron"
Jan 02, 2008 | Microwave Ovens
Microwave
Jan 01, 2008 | Maytag MMV1153A Microwave Oven
Won't heat. Everything else works.
Magnatron is suspect. Need to put a voltmeter on it and see if the input (primary) side to the high-voltage transformer (big heavy iron thing in there) is getting 120Vac. Don't touch the other (high voltage) side of this transformer. If the power is there, you are looking at replacing the magnatron. Its affordable if you do it yourself - buy the part on EBAY - lookup "universal magnatron"
Dec 31, 2007 | Hotpoint RVM1435 Microwave Oven
Microwave won't heat.
Magnatron is suspect. Need to put a voltmeter and see if the input (primary) side to the high-voltage transformer (big heavy iron thing in there) is getting 120Vac. Don't touch the other (high voltage) side of this transformer. If the power is there, you are looking at replacing the magnatron. Its affordable if you do it yourself - buy the part on EBAY - lookup "universal magnatron"
Dec 30, 2007 | Maytag UMV1152BAS Microwave Oven
No heat
Dec 28, 2007 | GE XL1800 1100 Watts Microwave Oven
LG 1.5 Cu. Ft. Full-Size Microwave - Black Logo
71 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
