Question about HP PSC 1410 All-In-One InkJet Printer
[email protected] my printer is working fine, but i cant instal it to my computer which has windows vista. The disk only instals upto windows Xp. what should i do. Thanks
    President:
  • 1,950 Answers
SOURCE:
I WOULD LIKE TO INSTALL LEXMARK 125 ON MY COMPUTER BUT I DO NOT HAVE THE DISK ANY LONGER.
If you are trying to install your Lexmark x125 printer on Windows XP, you should be able to visit the Lexmark website http://lexmark.com/... and click download now, then run and open the file you downloaded. That should install the drivers needed to print from Windows XP.
If you have a newer computer and are running Windows Vista or some other operating system, you may need to replace your printer as there do not appear to be drivers available for other systems (there is a Windows 2000 driver available also though).
Jun 17, 2009 | Office Equipment & Supplies
I install the software.printer is works,but when i want to use scan,there is on the screen ocr software mising ,install the software.on the printer scan is failed.how can i scan?thanks
In this case please insert the disk to the computer goto My Computer in XP and Computer for Vista...... There u will see a icon which says DVD RW lexmark 5600 u need to right click on it and click on explore and then click on Abby and run the setup.exe file and then try to scan it will work fine................
Good Luck
May 17, 2009 | Lexmark X5650 All-in-One InkJet Printer
Will not install
If you are running Windows XP or Vista (not clarified in your post)? Then just start your computer, wait five minutes and connect the printer, without any disk in the optical drives. If prompted by Windows hardware configuration wizard to insert the CD/DVD then do so and only then. Continue with the wizard and all should be fine.
Feb 05, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
Cant install all in one
go to this site: http://www.xpvistaworld.com/lexmark_1200_series_1233.htm
If the hyperlink works you may be able to just click on the link below without going to the site.
http://www.downloaddelivery.com/srfilecache/cjs1200EN.exe
listed under Lexmark 1200 Series driver.
Jan 24, 2009 | Lexmark X1240 All-In-One InkJet Printer
How to format Satellite A200-24A
Sir,
Iam using toshiba Satellite A200-24A model laptop.already this laptop contain windows vista. i want to instal Windows 7.can you please help me how can i install Windows 7 and how can i download the 7 drivers.
Please Help me
and send me the result
[email protected]
Jun 04, 2008 | Computers & Internet
Hard Drive Problem
Greetings...
You have 3 paths to look at and you also need to think about the need to change out Vista for XP...
Vista has gotten a bad rap on being something that does not work... it works fine... unless you have some very old program that you have to have for your job, Vista will work just fine...
Now... 1. you can install a boot manager and have both Vista and XP on your computer... 2. you can reformate you HD and install XP, you have an XP disk and code??? 3. you can run Virtual PC on Vista and install XP, still need the disk and code...
Virtual PC will allow you to fire up XP and run it as a separate program on top of Vista... and it's a free download...
Still I would look at just why you need to change... I have been running Vista since before it came out and other than a couple of programs in the beginning were a problem, everything works just great...
Have a great day...
Ed
May 28, 2008 | Compaq (349239B21) 250 GB Hard Drive
Lexmark 4270 will not install
I believe this will fix it for you as it did for me. I have a Lenovo laptop that updated from XP to Vista and the Lexmark 4200 X4270 All in One Printer would not print or scan. I had to do the following:
1. Delete all printers in control panel.
2. Do full update with Vista install disk
3. Make sure cable to Lexmark is not attached to Laptop until Vista does full update
4. Download the updated Lexmark Driver for whichever version of Windows you are running from the link provided below.
5.Install item in #4
6. Plug in cable to Lexmark and put the Lexmark SW installation disk in and it should finish itself for you.
Link:
http://www.lexmark.com/lexmark/sequentialem/home/0,6959,204816596_1019285789_0_en,00.html
Apr 15, 2008 | Lexmark X4270 All-In-One InkJet Printer
I had bought this program My Maillist Deluxe worked great then my computer quit so I had to buy a new computer and this one has windows Vista instead of Xp like my old onewhen installed for a couple of...
Why don't you unstall the program and then go to him and ask
him to install it and then if it work then must have done something wrong then if it doesn't work that means vista can not run that program thing ok to respond back email me at [email protected]
ok.
Mar 06, 2008 | Computers & Internet
Installing Lexmark 6100 series all-in-one to new hp computer
There are some compatiblity problems between Vista and your printer. Check this web page to download a driver that may provide limited printing capability for your printer...you'll need to use Windows Scanners and Cameras or Photo Gallery for scanning.
Jan 18, 2008 | HP Pavilion Media Center a1330n - AMD...
HP PSC 1410 All-In-One InkJet Printer Logo
Clive
Clive
Ekse
Thomas F. Schneider
