Question about Bose 901 VI Main / Stereo Speaker
Will Bose 901 active equialiser connect to SONY AV1100 Receiver
Will the Bose 901 active equalizer connect to modern Home Theater Receivers.   Most do not hav e'Tape 2 Out' or room for a pre-amp.   What should I do with mu SONY STR-DG 1100 AV Reciever to connect it to a Pair of Bose 901s?
  • Anonymous May 18, 2008
    I have basically the same problem: How do you hook up the 901 series VI active equalizer to a stereo receiver so it works for all source inputs (cd player, radio, ipod, etc)? I used to have a Pioneer SX-950 receiver. It had an aux input that was switched in or out of the circuit with a switch on the front panel. When the equalizer was in circuit, it was applied to all input sources. I can not find a receiver with something similar on the market today. Any suggestions? Thanks for any help you can provide.
    Problem Solver:
  • 18 Answers
Http://www.bose.com/pdf/customer_service/owners/og_901.pdf
Posted on May 22, 2008
  • 43 Answers
AFAIK, most modern AV receivers DO have tape in/out. I just looked at an image of the back of the Sony STR-DG1100 and it absolutely does have a Tape In/Out. It also has a Video 1 In/Out and you could use just the audio part of that if your Tape is being used by something else. I don't have a Sony so be sure to check the manual to see how to engage the "tape Monitor" so that the Bose EQ is in the loop.
Posted on Sep 03, 2015
    Problem Solver:
  • 18 Answers
Look for some older higher end Yamaha units on ebay for pre-main couplers. I have a Yamaha rxv3300 that works like a charm for home theatre.
Posted on Apr 07, 2009
SOURCE:
How can i hook-up a 901 series vi equalizer to a str-de897?
I own 901's(since new) with the active equalizer powered with a non-Sony surround sound receiver.
Basically, you use the MD/Tape in/out jacks to route the signal to the Bose active equalizer. Switch the Tape Monitor switch if no sound is heard.
Here are some references.
https://docs.sony.com/release/STRDE897.pdf http://products.bose.com/pdf/customer_service/owners/901_guide.pdf
Connect equalizer cables (4 total) to the MD/TAPE section of your receiver. OUT from the receiver to the equalizer IN and Out from the equalizer to IN on the receiver.
One issue with the equalizer running through the MD/Tape jacks is that it may affect any other speakers hooked up to your system.
Mar 15, 2016 | Audio Players & Recorders
Will the NAD T748 drive the bose 901 speakers?
Yes, the Bose user manual
http://worldwide.bose.com/axa/assets/pdf/owner_guides/StereoSpeakers/901vi_guide.pdf
says that any amp with 10-450 WRMS is OK. The speakers impedance is given as 8 ohms, so the amp is compatible.
Note that Bose say you have to have the Bose equalizer connected as well.
Sep 04, 2013 | NAD T748 Home theater receiver with...
Amp out and amp in for bose eq.hook up
  • 1
    Examine your receiver to be sure it has a tape monitor loop. Receivers with a tape monitor loop will have a button or switch on the front for "Tape Monitor," and have two sets of RCA connections on the back, one labelled "Tape In," and the other "Tape Out."
  • 2
    Take the two cables that are provided with the 901 speakers and insert one end of the first cable into the "Amplifier Input" jacks of the equalizer. Connect the red connector to the R input and the other connector to the L input. Connect the other end of this cable into the "Tape Out" connections on the receiver. Again, hook red to R and the other to L.
  • 3
    Connect the second cable between the "Amplifier Output" jacks of the 901 receiver and the "Tape In" connections on the receiver. Follow the guidelines in Step 2 for R and L connections.
  • 4
    Plug the 901 equalizer into a 120-volt electrical outlet. Your 901 equalizer is now installed.
  • Read more: How to Install a Bose 901 Equalizer ' eHow.com http://www.ehow.com/how_4813156_install-bose-equalizer.html#ixzz19vfsJTQu
    Jan 03, 2011 | Bose Audio Players & Recorders
    I want to connect the Bose 901 speakers and accompanying equalizer to a modern home theater receiver.
    Short answer from personal experience.
    If you have Front Left and Right Pre-outs, you CAN swing it by getting a separate power amp for the 901's. Connect the EQ between the pre-outs and the amp input. Run speaker assignment, levels, etc and have fun.
    If you don't have the between-speaker room for proper reflection off the front wall you CAN turn them around and you won't believe the amount of air these things push! I have actually felt it ten feet away after explosions or crashing ocean wave sounds. Now THAT is multi-media.
    Dec 20, 2010 | Bose 901 VI Main / Stereo Speaker
    Bose 901 series speakers to Bose 901 Equalizer
    There is no direct connection between the 901's and their Active Equalizer. It is designed to be inserted between the source and the DEDICATED amplifier driving the speakers. Typically, this would be in a Tape Monitor loop on a receiver.
    Tape Rec/Out to EQ In; EQ Out to Tape Play/In on the receiver. If you have a tape deck(s), it(they) would go into the back of the Bose EQ as if it was the receiver and you would use the Tape and 1/2 buttons for selection.
    Or,if you have access to any other point that doesn't use the Tape Monitor, like a Pre Out/Main In jumper set, place the Equalizer there. That way it's always in front of the speakers and doesn't take up the Tape Mon.
    Flip in the Tape Monitor and leave it on or the speakers will not receive the essential ACTIVE Equalization they require for proper frequency response. DO NOT place non-901's onto any amp using the Active EQ.
    Like any speakers, the 901's will attach to the speaker terminals in the conventional manner.
    Apr 12, 2009 | Bose 901 VI Main / Stereo Speaker
    Compatable receiver list for Bose 901 series VI
    I contacted the Customer support folks at Bose. Here is what they said: With a stereo receiver, the equalizer is run through the tape monitor section in the back of the receiver. The receiver's tape monitor output, left and right, runs to the amp input section of the equalizer, left and right. Then the amp output section of the equalizer, left and right, runs to the receiver's tape monitor input section. With a surround sound, home theater, type of receiver, the theory is the same, but the connection is through the preamp-out/ main amp-in section of the receiver. Not all receivers have this feature. Most, in fact, do not. Check the back of the receiver. There would be a connection made by two U-shaped clips. The plugs would be pulled out. Then connect from the preamp-out to the equalizer's amp input section; and from the equalizer's amp output section to the main amp-in. This effectively isolates the equalizer so that it is not affecting the other speakers in the system or the receiver's surround processing. Attached is a current list of known 901-home theater compatible receivers:
    Note: Specifications subject to change without notice. Bose Corporation is not responsible for any inaccuracies due to manufacturer changes. Inclusion in this list does not indicate an endorsement by Bose Corporation. When in doubt contact the manufacturer of the equipment.
    I have the list in a pdf document but do not see a way to attach it.
    Contact me at [email protected] and I'll forward the pdf.
    1-30-2009
    Dec 24, 2008 | Bose 901 VI Main / Stereo Speaker
    How do I connect my bose 901 active equalizer to a onkyo tx-sr506
    AV receivers are notoriously incompatable for Bose 901s. The problem is the EQ charges the entire system and could damage the surround processor. Some higher end AV receivers, including some of the newer Onkyo models have pre out power in inputs on main or all seven channels.which you could install your EQ directly between pre amp & power amp without damaging processor. You can also add a two-channel amplifier to the pre out jacks front channels and use your recever's remote to control volume.
    Nov 30, 2008 | Bose 901 VI Main / Stereo Speaker
    Connect Bose 901 VI EQ to a Harmon Kardon AVR 247 Amp
    Similar problem...I came up with a solution with help from Onyko. For my receiver, at least, the bottom line was that the output from the equalizer MUST go to 'Receiver, Tape In'! Since that is the ONLY input source from the equalizer, you must combine elsewhere. Part of my setup included the Radio Shack Audio/Video Selector box which costs $21.99...you might not need it, but in my case, I couldn't plug all components into the back of the receiver and have them go through the equalizer.
    Since I have a satellite receiver, DVD player and TV, that I want to route through the equalizer, here is the way mine is set up and working:
    Satellite receiver and DVD player out to Radio Shack audio/video selector
    Audio/video selector out to VCR in.
    VCR video directly to TV
    VCR audio red/white (audio) out to equalizer
    Equalizer out to Receiver Tape IN (Receiver Out not used)
    Hope this (or a variation of it) helps.
    Nov 17, 2008 | Bose 901 VI Main / Stereo Speaker
    Bose 901
    1-record out from receiver to to equalizer in.
    2-equalizer out to tape pb in receiver.
    Nov 05, 2008 | Bose 901 EQ1915 Home Equalizer
    How to connect bose 901 speakers to 5.1 setup?
    The solution is simple and cheaper than you think.
    The analog 5.1, 6.1, 7.1 outputs on your receiver should be active even with digital inputs that you want to hear. Your receiver turns everything it processes into analog output just before the speakers anyway so there's no loss of access to multichannel sound this way.
    What I did was to buy a separate amp for the 901's and feed the Front L&R analog audio out to the EQ which is directly in front of the amp. The Active EQ is only for the 901's which don't have woofers or tweeters so Bose flattened out its final response electronically with some serious boosting at both ends. Having it in line with any other speakers would feed them a grossly over-compensated signal.
    Your receiver will drive the rest of the speakers.
    This is the cheapest way to have your 901's and hear them, too. Since the 901's are really efficient you don't have to buy a big amp that would heat the room. I'm using a separate Carver amp with 2x100w for mine.
    Sep 09, 2008 | Bose 901 VI Main / Stereo Speaker
    Bose 901 VI Main / Stereo Speaker Logo
    1,609 people viewed this question
    Top Bose Audio Players & Recorders Experts
    Steve Allison
    Steve Allison
    Ekse
    Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
