Question about Philips (PA1012) (DBPA1012) Keyboard
Keyboard is powered up, but phillips monitor will not accept text
  • 64 Answers
The monitor only displays what the computer tells it to; so the monitor is not part of the issue. Assuming it is plugged in, you need to restart the PC. I would recommend only changing the plug with the PC off. You either have an issue with the keyboard or the keyboard port. You can either try another keyboard on your machine or take your keyboard to another PC.
Posted on May 12, 2010
Why does my keyboard keep dissappearing
The keyboard goes away once you are not in an edit field where text is accepted. If your keyboard failed to pop up automatically, usually tapping into a text field will cause it to come right up.
Jan 07, 2015 | Apple iPad (16 GB) WiFi Tablet PC
My keyboard producing wrong keys
You probably have the wrong keyboard code. For Win XP or newer version of WindowsOpen CONTROL PANELDouble click REGIONAL AND LANGUAGE OPTIONSClick the LANGUAGES tabClick the DETAILS button for Text Services and Input LanguagesIn the new window verify the input language and click the Add button to choose one that matches your keyboard.
Dec 10, 2011 | HP w1907 LCD Monitor
LCD screen totally white when turn on
The HP is a flat screen monitor used with many desktop computers. When the LCD on your HP monitor goes white, it is an indication that your monitor's inverter board has gone bad. The inverter board is a small circuit board that transfers power from the monitor's main circuit board to the LCD screen. Replacing the inverter board means dismantling the HP monitor.
1. Power down your computer and unplug the HP monitor cable from the back of your desktop. Disconnect the power cable from the back of the monitor. Relocate the monitor to a flat work surface. Place the monitor with the screen facing downward.
2. Remove the Phillips-head screws from the monitor's base stand and from the back cover. Lift the base stand off of the monitor and remove the back cover. Peel away the foil from inside the monitor around the internal circuit board.
3. Locate the inverter board near the bottom of the monitor's casing. Unplug the power cables from either side of the inverter. Loosen the Phillips-head screws from the inverter board. Lift the old inverter out of the monitor's casing and set it aside.
4. Place the new inverter inside the monitor. Replace the Phillips-head screws and fasten it in place. Reconnect the power cables to the connectors on each side of the new inverter. Replace the foil around the outside of the main circuit board.
5. Replace the back panel and base stand, and their retaining Phillips-head screws
I hope you find it very helpful.
Thank you for choosing fixya.com
Aug 11, 2011 | HP Computers & Internet
Thinkvision monitor is in power save mode. It is not connecting to Thinkpad laptop
There are 2 possible reasons for this:
- Your Laptop resolution is not supported from the monitor. Solution: reduce the resolution to something smaller (e.g. 800x600) and then gradually increase it untill you have the maximum accepted resolution from the monitor.
- You have not switched the Laptop display to point to the external monitor. Solution: do that b pressing the corresponding shortcuts in your Thinkpad keyboard. (usually a bottom left key together with a top key).
Jul 28, 2011 | IBM ThinkVision L200p 20.1" LCD Monitor
I have a Phillips PC i bought in 2006 and around a year or so i rebooted to its original state and consequently I forgot the password to the only user account. SInce then I have rarely used the PC and...
to remove the hdd password do the follwing
1) Restart your computer. Note that during computer restart, the screen goes blank for 3 to 5 seconds. Text then appears and the operating system boots up.
2) As soon as the first text lines appear on the screen, press the "Del" key on your keyboard to enter the BIOS setup
3) Navigate to "Security" in the BIOS menu using the arrow keys on your keyboard
4) Navigate to the option "Hard Disk User Password" and press "Enter
5) Navigate to a hard drive, press "Enter" and select "Disable" to remove the hard drive password.
6) Press "F10" to save and exit the BIOS settings. Computer booting resumes.
this will remove the hdd password
Jan 17, 2011 | Philips Computers & Internet
BLACK SCREEN AND POWER BUTTON WILL ONLY BLINK OFF AND ON
This sounds like the signal coming from the computer may be out of sync. Do you see anything on the screen while the computer is starting up, showing the POST text (testing memory, etc.)? If so, try connecting another monitor and set the resolution to something low.
Then, reconnect the monitor in question and set your preferred resolution. If this doesn't work, slowly increase the resolution until you reach an acceptable one.
I hope this helps.
Dec 20, 2010 | Dell Computers & Internet
When I try to type it makes a beep sound for every stroke and nothing is displayed?
You must be running a program that accepts text as input such a 'Word' or an E-mail program. The 'beep' means that each input (text) is not recognized by Windows.
Nov 12, 2009 | HP w1907 LCD Monitor
Apple cinema 30" turn off after boot
a button could be stuck on the keyboard. unplug it take the battery out if possible. if not . its ok you got this. first look at the keyboard keys to see witch ones look like there stuck in. now if they look good to you. get a soft cloth moisten it LIGHTLY ............now wipe your keyboard gently. you can dry up any thing with a napcan. look at the keyboard an see if ant thing look different. a good wiping helps every now an than. lol. let it dry up good an turn it on. if that did not help you. your table screen is malfunctioning because of your power button or vol. control
Mar 27, 2017 | Apple Cinema HD 30" LCD Monitor
Acer flatscreen won't accept signals from G-Byte cpu -
found that using an older screen and 9 pin plugs for mouse and keyboard worked - no idea why it wouldn't before.
Mar 19, 2009 | Acer Computers & Internet
Phillips monitor 150b3 no dispaly just power on
monitor on position and display show "AGING..."
plz solution
urjant
thanx
Feb 26, 2008 | Philips 150B3T 15" Flat Panel LCD Monitor
Philips (PA1012) (DBPA1012) Keyboard Logo
93 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
