Question about Poulan 14" Chainsaw
Saw is a 14 inch model 1950. Saw starts but won't run
I replaced fuel and return lines because fuel line had broken off. Now I can get saw to start ( sometimes) but not keep running. It amy run long enough to razz the throttle a couple times then dies and is hard to restart.
    Brigadier General:
  • 4,088 Answers
Check the fuel filter, air filter and muffler for plugging. Make sure the carburetor fasteners are tight. Does the primer bulb fill with fuel after several pumps? Hope this helps!
Posted on Jul 23, 2010
How do I get inside the fuel tank of my poulan 1950 to replace the line in it?
To replace line you use tag wire or similar item to pull the fuel line through the tank fittings.
First you install tag wire through the tank fuel line open and out the fill hole. Then attach this tag wire to the fuel line and pull the line back through the fuel line opening. You do this for both the pickup and the return lines. Mark your return line about an inch from the end so you can install it at the proper placement. As pull this return line through the fuel line opening stop when you reach the mark. Now with both lines installed cut them to desired lengths to connect to the carburetor and the primer.
Here is a picture of how connect the tag wire to the fuel line.
Dec 22, 2014 | Poulan Chain Saw. 14 in. 33 cc Gas Chain...
My chain saw will not start model #3314 14 inch I followed the directons on saw yet it will not start I also have the manual and followed the directions
How many hours on the unit?
Does it have spark?
Is it getting fuel?
Check the compression. If it has low compression it won't start.
Jul 05, 2011 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
14 inch, Factory refurb, FR2.0. After I replaced all fuel lines and primer bubble, won't start. Gas runs out the exhaust.
I did a lot of research but didn't find your problem.But I did find an online store that deals with your 2.0 Eager ****** chain saw. http://store.chainsawr.com/
and a way cool saw repair website. http://www3.telus.net/findNchoose/smallenginerepair.html
If this is not the solution that you are looking for please re post because when we pick a question to answer FixYa takes it out of the questions. I hope this is of some use to you.Thanks for choosing FixYa.com.
May 19, 2011 | McCulloch Garden
Fuel line is broken 2 inches short from filter in tank. How do u replace line? Do you need rubber grommets etc.
if you go to home depot you can buy a fuel line kit for a few bucks that comes with all of what you need
Mar 01, 2011 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
How to connect the fuel lines for Poulan Model # 1950 Chain Saw
The following link should be very helpful:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
A link to a Poulan model 1950 Type 7 follows (may not be your saw, there are 7 different Types and 2 Woodsharks (LE))
http://www.ordertree.com/modelinfo/PWE/1950-Gas-Saw-Type-7/75.1950-Gas-Saw-Type-7.1.59.1.html
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Jul 22, 2010 | Poulan 14" Chainsaw
Need to know how to connect the gas lines from the primer bulb to the carburetor on a poulan woodshark model 1950 chainsaw
The lines should be connected to push fuel into the carburetor. The output (overflow) of the carb is routed back into the tank. So, two lines in the tank, one is an overflow (return) and the other is the suction. On the primer one line from the tank and the other to the carb. Connect so as to "push" fuel into the carb when the primer bulb is pushed.
Jun 16, 2010 | Poulan 14 in. 2.0 Peak Horsepower Electric...
Change all fuel lines in a McCollough Chain Saw, new fuel filter. How far does line from the primer go into the fuel tank. Just on edge, barley or in a few inches? I get it started but it goes off after...
It should be as illustrated on the link.
Typical Fuel System (Primer Bulb and fuel lines may not apply)
The line with the filter needs to be long enough to reach all parts of the tank as the saw is moved. The return line is not a critical length probably mid tank. Do you have the filtered hose feeding the primer and not the carburetor? That will cause what you describe. HTH
Lou
Dec 28, 2009 | McCulloch 10" Electric Pole / Chain Saw
How do I install fuel lines on a poulan chain saw model 1950?From carburator to primer,from primer to fuel tank,two connections on each.
The smaller line comes from the fuel filter in the tank to the nipple on the side of the carb with the cover w/ 1large screw in the center, the other small line goes from the other nipple on the carb to the primer bulb, the larger line goes from the other nipple on the primer bulb back to the tank, and only gets pushed in about 1/2-3/4" into the tank. Hope this helps.
Feb 26, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Echo 452VL chainsaw won't start
yes it does.the filter is in the fuel tank on the end of fuel line.if it isn't the fuel line needs to be replaced and a new filter installed.there is most likely some of the fuel line in side the carb. there is a small filter inside and it usualy collects the broken fuel line there. take the carb apart oppiset of the diaphram.usualy it's the side with only one screw.carefully blow the **** from it and the saw will get fuel again and start
Feb 23, 2009 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Poulan 14" Chainsaw Logo
184 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
