Question about HTC G1
T Mobile G-1 headset jack not working
My T mobile earphone dosen't works when plugged in. The earphone and chord seems to be pretty ok. Most likely the problem may be with the jack. Iam not finding any service centre who agree to service it. Please help me to solve the problem.
The hand set does not work I can not talk or recieve. but it will ring when a call comes in and leave information
Ok, here's my theory you used an earphone but it didn't disconnect. To know if this so if you see the earphone icon on your phone then that is the case. This happened to one of my phones. Anyway here is how you can solve this plug in an earphone and shake the plug gently while still plugged in. Take out the earphone. If the icon comes off problem solved if not.... .... Try again. It is usually because of the switch in the earphone jack that switches between headset and handheld mode becoming jammed. :) hope this solution helps
Jan 19, 2016 | Cell Phones
Samsung galaxy s3 headset icon shows and when
try cleaning up the headset hole in the phone using a cue-tip for ears. dry . and if the headset icon doesn't disappear un-plug and re-plug the jack eventually power off / on restarting the phone. see if this helps ;) good luck!
Oct 02, 2014 | Cell Phones
Bought turtle beach z11 headset, cant get mic to work
The Z11 has a four-pole input/output plug to connect the mic and the earphone. The earphone needs to be connected to the earphone jack and the mic needs to be connected to the mic input jack on the back of the computer. In other words, you should have to 3.5 mm plugs. Plugging both into the same jack will disconnect one or the other. Check your adapter, It should have two separate 3.5mm plugs. If it does, be sure they are connected to the right jacks on the computer. The headphone jack will have a headphone symbol; the mic jack will have a microphone symbol. Go to System Preferences, Sound. Select the line in preference for input and the line out preference for headphones. Just may work.
Mar 14, 2014 | Apple iMac G5 Desktop
How can i connect my hipstreet bluetooth to my nokia x3 mobile
Look in both manuals (hipstreet, Nokia) under the chapter "Pairing"
In these chapters you will find the answer.
Good Luck
Aug 03, 2011 | Motorola Mobility Bluetooth Headset, Mini...
Earphones on my turtle beach x1's not working
Try using the headset to listen to your iPod or MP3 player. Plug the USB plug into your Xbox or PC USB port, then plug the X1 green plug into the Headphones jack on your iPod or MP3 player. Make sure the master volume is up on the X1 (inline volume control box). Play a tune on the MP3 player. Do you hear the music? If yes, the X1 is fine. If no, you should contact Turtle Beach tech support and tell them about it.
Jan 09, 2010 | Voyetra Turtle Beach Ear Force X1 Headset
Left side of earphone jack won't work. I have tried more than one headset.
Sounds like a bad headphone jack. Contact Apple at 1-800-APL-CARE.
-=/ Daft Tech /=-
Oct 22, 2009 | Apple iPod classic MP3 Player
Cant connect logitech bluetooth to phone,
the logitech head piece buttons must not be working, seems to charge ok but can't get to flash blue?
Aug 07, 2008 | Logitech Mobile Freedom Wireless Headset
Mobile Phone PDA
Hi. My son just had exactly the same problem from when he first started to use the handsfree / headphones socket.
It seems that there was a fault in the socket. The phone believed that the jack was in the socket even when it was not, so it disconnected the phone's speaker and microphone. We kind of got a clue as the handsfree jack did not give a very convincing 'click' when it was put in or out.
The solution was - he prayed hard and then repeatedly pulled the jack plug in and out rapidly until it the socket began to 'click' properly. He then took the jack out and it has been working fine ever since.
Hope this helps. Chris
Mar 10, 2008 | Orange SPV M600 Smartphone
Only one audio output working - not stereo!
It is the actual headset jack on the device. It wears out from plugging and unplugging the headset.
If its less than 1 year, call SanDisk and they will replace it.
Otherwise, if you are inclined, you can replace the internal headset jack.
SanDisk Technical Support 1-866-726-3475
Best of Luck.
Nov 11, 2007 | SanDisk Sansa e260 MP3 Player
Headset jack
Ok often this is caused by one of the cables in the earphones breaking.. try another set. Sometimes it can be the socket on the unit breaking at the solder joint on the PCB, if it is, and ya can solder? it is a pretty easy fix. But I would "Punt" for a broken earphone lead.
Aug 08, 2007 | SanDisk Sansa c200 MP3 Player
HTC G1 Logo
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
