Question about Sub-Zero Bottom Freezer Refrigerator
Temerature is set at 37 degrees,but only cooling to 57degrees
We've vaccumed the coils, but it's still not cooling.
    Brigadier General:
  • 3,917 Answers
Hi
It's possible that the compressor is dead or not working properly.
Please check the bellow link to have a detailed idea about your problem…..
http://www.repairclinic.com/Refrigerator-Troubleshooting#Itsnotcool
Let us know if you want to know something more else please accept the suggestion.
Thanks for contacting fixya.com
Posted on May 12, 2010
MY AMANA AQF1613TEW WON'T COOL BELOW 37 DEGREES.
Sounds like it has a leak and it is low on coolant.
Jan 18, 2018 | Amana Refrigerators
HOW DO I SET THE TEMPERATURE ON A SAMSUNG MODEL SRS615DP REFRIGERATOR
5 for both freezer and fresh food side. This corresponds to about 37 degrees in fresh food side and 0 - 5 degrees in freezer. Check for blocked vents from and to the fresh food side and return to freezer. Most problems occur because these vents are blocked and/or overstuffing of freezer and fresh food side. The air has to have room to circulate. Another thing to check is if the condensing coils are dirty. Normal access to the condensing coils if yours has one is inside the cardboard cover on the lower back side of the your refrigerator.
Hope this helps
Dec 15, 2014 | Samsung 29 cu. ft. French Door with Cool...
Vaccum door lnot working replacing cooling coil
be looking at connections as well as emissions controls see if hoses were left off somewhere..
Dec 23, 2013 | Mercedes-Benz S-Class Cars & Trucks
I have a GE refrigerator model number PSC25SG SA SS which has Problem that in every couple days the freezer and the refrigerator display panels display out of their setting ranges. For example, the...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Aug 24, 2010 | GE PSC25SGSSS Stainless Steel Side by Side...
Freezer side will not cool below 18 degrees. The fridge side is cooling at the set 37 degrees. What could be the problem as to the freezer not cooling to 0 degrees?
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Aug 23, 2010 | GE PSI23SGM Side by Side Refrigerator
I have a GE Profile PSW26PSW. I bought it new in
If the condensor is dirty, the frig will have to work like the dickens to to stay cool. The condensor coils are either under the unit, or on the back. the newer units tuck them neately under the unit and a good toilet brush, degreasser soap, like "Dawn" works great. If she still is heading south, My first guess would be the compressor, or the thermostat. Try the Condenser coil cleaning first. Lloyd
Jun 01, 2010 | Refrigerators
Need to set differential on my ct 1540 thermostat, the furnace kicks on at after it drops 1 degree this cant be right
Yes this is probably correct the newer thermostats will kick on with a 1 degree temerature drop. This is better since the furnace only has to make up one degree of temerature and has a shorter run cycle saving you money.
Dec 24, 2009 | Honeywell CT3600 7 Day Electronic...
Vinotemp wine cooler temerature won't stay on 54 degrees
If the unit is a thermoelectric unit it can be the cooling system.
If the unit is a compressor unit it will be the thermostat.
Aug 28, 2009 | VinoTemp 32 Bottle Stainless Wine Cooler
What is the coldest setting on an old zanussi fridge freezer 1 or 6
hi there......the coldest setting on your fridge is 6
the normal accepted working temperature of a domestic fridge is usually between 0 and 8 degrees........the numerals on your thermostat are not temerature settings ...but a guide to coldness setting....the actual temerature must be checked with a reliable thermometer...usually best done in the morning after the fridge has ran throiugh the night without the door being opened.....
regards Sir Galahad
Aug 12, 2009 | Refrigerators
Sub-Zero Bottom Freezer Refrigerator Logo
177 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
