Question about Hitachi 43FWX20B 43" Rear Projection Television
Colors run; curvature to picture
Bright green and red "shadows" on picture. Picture seems to curve slightly up on the left side of screen. Happened very suddenly. Things were perfect Tuesday night turned it on Wednesday morning and problem ocurred.
  • 1,476 Answers
Your convergence is bad and needs fixed. I have a tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which explains the problem, how to fix it and where to get the parts.
Let me know if you need more help.
Thanks for using FixYa and for the generous rating.
hardrocko
Posted on May 12, 2010
Red & green shadowing on the right side of picture
First thing to try is a convergence but with the red shadowing seems to me that you may have your color gun going. Convergence can be found in your video menu on your setup screen. Once in the menu you can adjust the colors to line up. This usually has to be done on a tv that has been moved.
Nov 11, 2012 | Hitachi 60EX01B 60" Rear Projection...
I have a Phillips 60" rear projection TV. recently
Tv have a problems known as a convergence problems,it is dead.The tv convergence board it is dead,that why ur tv picture are R,G,B colors lines mis alignments,have colors shadows picture or 3D picture lood alike?The tv convergence board require changes 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
Jun 01, 2011 | Philips Televison & Video
Red color convergence issue; Red lines are curved
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Nov 24, 2009 | Televison & Video
Blue, green, red parallel curved lines at top of screen
hello sorry but it sounds like the chip have gone again when you replace these chips you might have to change the resistors and the 2 capacitors as well
shaun
May 08, 2009 | Mitsubishi WS-55905 55" Rear Projection...
Will not show red color in picture, magic focus shows red though
You have a projection light element out. I had the green element go on mine. I had a service agreement so a repair tech changed it.
Feb 07, 2009 | Hitachi 43UWX10B 43" Rear Projection...
My samsung cr32z30 32" hdtv turns off automatically after running for about 30min to an hour. also the picture is curved on both sides when watching tv in 4:3 ratio. the curve is most prodominate at...
Linearity coil (there are several) shorted causing HV to increase and causing HVSD, no replacement parts available. Replace sweep module to fix.
Nov 10, 2008 | Samsung Televison & Video
Yellow hue
1)Please verify your model # from back of set......
2)Reduce the color to minimum or tune in a black & white chan.
you should see gray, not yellow hue
3)Remove lower front grill cover & access panel.....locate the
focus / screen control block...turn blue screen control slightly
CW......red,green and blue must mix to equal gray
4) reset color to normal level.......reassemble
Dec 22, 2007 | Toshiba 57H82 57" Rear Projection...
Pictue is dark as hell
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Oct 27, 2007 | Hitachi 65F59 65" HDTV
Hitachi 43FWX20B 43" Rear Projection Television Logo
381 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
