Question about Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX
Poulan 2150 - starts and stops almost immediately
    Brigadier General:
  • 4,088 Answers
Is the saw setting 'fast idle' when starting? Does the primer pump fill with fuel when pumped several times? Is the fuel mix fresh? Have you checked the fuel filter, air filter, and muffler for plugging? Inspect the fuel lines for decay or other damage. Check the carburetor fasteners for tightness. Hope this helps!
Posted on Jul 23, 2010
Poulan 2150 fuel line diagram
you can start by adjusting the air fuel intake by turning the adjustment screws in all the way then out 3 full turns then do half turn adjustments until its right
Jul 23, 2014 | Poulan 2150 Chainsaws
Poulan woodsman 2150 starts & runs for a few
This is fuel starvation, start by replacing the fuel filter inside the fuel tank, use a piece of bent wire to hook the fuel line and filter out of the tank, check the condition of the fuel hoses up to the carb, any signs of leakage and you will have to change the hose. See if this works before we go into the carb to locate the blockage.
Jun 09, 2013 | Garden
Poulan 2150 chain saw starts and dies after 5 seconds or so then wont start
Try a few easy things first, hook the fuel hose out of the fuel tank through the filler hole and replace the filter on the end, follow the fuel hoses up to the carb and check foe any signs of fuel leakage, replace the affending hose if cracked.
Dec 14, 2012 | Poulan 2050 2055 2975 2150 2155 2175 Air...
Poulan 2150 chain saw starts after priming and dies after a few seconds
Take the exhaust off so you can see the side of the piston, if it is scored or damaged it means it has probably been run without oil added to the petrol.
That can cause the problems you are having, if it is throw it away, its not worth repairing
Poulan 2150 Woodman Chain Saw When I release the throttle(idling), the chain doesn't stop.Shouldn't it stop for safety reasons? I don't have the maual.
Yes, the chain should stop. There is a metal ring inside the chain housing cover that either broke in half or cracked off the mounting location.
Nov 13, 2010 | Poulan Garden
How do you re assembly brake handle poulan 2150
Hello Larsens;
A Poulan "2150 Predator Gas Type 6" IPL follows (may not be your saw)(the LE suffix is a Wood Shark) http://www.ordertree.com/modelinfo/PWE/2150-Predator-Gas-Saw-Type-6/75.2150-Predator-Gas-Saw-Type-6.1.59.1.html
There is no breakdown, they want you to order a new cover $20±. The cover appears on different print names with different models (Handle & External Assembly) above.
Poulan.com (all)
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
Do you have a friend with a cover you can look at? The brake will need to be lached open (enlarged) to refit the clutch cover on your saw.
Detail A here is a good representation of a Husky chain brake, they are all similar and this may be helpful.
http://weborder.husqvarna.com/order_static/doc/usa/2006/I06000/I0601077.pdf
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Apr 24, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Carburetor initial adjustment for Poland 2150
Both about two turns or so. Engine must be warmed up to properly set the running adjustments. H adjustment to get four-stroking with no load, but immediate smooth out with light load (cutting wood). Idle set for smooth idle, but allows immediate pickup from idle when throttle applied.
Jul 04, 2009 | Poulan Pro Chain Saw 46cc 20"
Need a diagram of the fuel lines on a poulan 2150. what lines go where?
You can View a Diagram of the Chainsaw here http://hayward.arinet.com/scripts/EmpartISAPI.dll?MF&app=ASP⟨=EN&TF=Mainfram...
Select the Catalog Poulan/Weed Eater. Then Select Poulan. Then Select Gas. Then Select Saw. Then Scroll Down to your Model Saw i.e 2150.
Regards
Marc
Apr 17, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX Logo
383 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
