Question about Bounty Hunter Land Star Digital Metal Detector with Ground Trac Re-Tune - LSTAR w/FREE UPS
Micronta 4001 metal detector , how does it work ?which sides for which metal?
IS THER A VIDEO THAT SHOWS ME HOW TO DO THE SETTINGS ON A MICRONTA 4003 VLF
It is one of the simplest ones to use. My niece used one for a while. I could not find a video but here are the instructions;
Instructions
    • 1Turn the metal detector on with the "Volume" knob. This also adjusts the level of sound.
    • 2 Check the batteries. Turn the "Test" knob to the Battery 1 or Battery 2 position and confirm that the needle points to the green area. Then turn the knob to "Nor" for normal operations
    • 3 Hit the red "Auto Tune" button on the carrying handle with the head portion of the detector away from any metal objects, and turn the "Tune" knob until the needle hits 0.
    • 4 Turn the "Sens" knob to the middle position.
    • 5 Turn the "Mode" knob to VLF (very low frequency), and turn the "GND" knob to account for the type of ground (such as dirt or sand) you are using the metal detector for.
    • 6 Turn the "Mode" knob to either the TR1 or TR2 position. To set the detector to find metals such as gold or silver, set the "Discrim" knob to Non-ferrous Metals. You can also set it to find Ferrous Metals if you want to search for iron or steel.
    • 7 Hold the detector with the search coil parallel to the ground. You can adjust the angle of the search coil by loosening the wing nut on the end of the shaft and swinging it to the desired position.
    • 8 Swing the detector in wide sweeps about 2 inches from the ground.
Read more : http://www.ehow.com/how_5011582_use-micronta-metal-detector.html
Jan 30, 2015 | Retail Supplies
Is there such a thing as metal detectors for kids?
Yes, you can get special metal detectors that are suitable for kids. They are smaller in size, lighter and easier to use than some of the more complicated metal detectors.
Check out this link where the metal detectors are characterize by age;
http://www.metaldetector.com/learn/buying-guide-articles/kids/best-kids-metal-detectors
Feb 21, 2013 | Retail Supplies
Do you need to buy an expensive metal detector in order to find things?
No - even the cheap basic TLF/VR metal detectors will find stuff but usually the more expensive the metal detector and better the quality - the greater amount of things you will find.
I am very curious about metal detectors; how they work etc. Can anyone explain it to me in simple terms but with a diagram?
Take a look at the Indepth Info Site - they have a fairly basic explanation but with a diagram that might help. But you're right - metal detectors are fascinating!
http://www.indepthinfo.com/gadgets/metal-detector.shtml
How does a basic metal detector work?
The simplest type of metal detector contains an oscillator which produces a current through a coil which in turn creates a magnetic field. If a piece of electrically conductive metal is close to the coil, it will produce an electric field of its own which is then measured and detected by the metal detector.
Jan 10, 2013 | Retail Supplies
Need manual for Radio Shack MICRONTA 63-3003 VLF Metal Detector
Go to http://www.scribd.com/doc/38611721/63-3003-Micronta-VLF-Metal-Detector-Manual
Sep 23, 2012 | Vehicle Parts & Accessories
Precision Gold Metal Detector With Digital Display Set Up
instruction manual for the precision gold metal detector: go to www.maplin .co.uk. then type in L24BK into the product search. the metal detector will come up.then go to bottom of page where it states "media" if you click here a pdf of the instruction manual will come up for download.
Paul
Jul 30, 2009 | Bounty Hunter Digger Metal Detector
Bounty Hunter Land Star Digital Metal Detector with Ground Trac Re-Tune - LSTAR w/FREE UPS Logo
1,295 people viewed this question
Top Bounty Hunter Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Bounty Hunter Optic Expert? Answer questions, earn points and help others
