Question about Symbol LS2208 Handheld
Symbol Bar Code scanner LS2208 won't scan small font 39 bar code 46 characters long alpha numeric the font is AdvC39b and font size is 3.5 my question is the Symbol LS2208 scanner cable of scanning that bar code? If it is are there setting that need to be adjust on it to do it? If it's not can you provide a recommendation?
  • ehockey2000 May 12, 2010
    The LS 2208 symbol bar code scanner works on bigger font 39 barcode labels so I know the scanner works. I need to know if it should be able to scan a font size 3.5 3of9 barcode. If not what is a solution?
  • 4,924 Answers
It should scan any code bar no matter the font ...cause those are on the standard used for all bar code scanners..So if it do not scan it ..it is just a one case exception and those that print it is to blame ...anyway try to reinstall the driver and look on the manufacturer site for updates...maybe its a newly standard and there are updates available..
Also try more than one code of the same font to see if some of them have imperfections or something ..
Posted on May 12, 2010
  • 3 more comments
  • Catalin Turcu
    Catalin Turcu May 12, 2010
    The greatest
    strength of the LS2208 lies in the scan engine designed by Symbol. In
    testing wide barcodes, we were able to get it to read barcodes 7”
    wide, with about 50 characters encoded. For density, our LS2208 was capable
    of reading barcodes as small as 4.9 mil, excellent for retail use. This
    scanning robustness means the LS2208 will easily scan any barcode you
    will encounter in general use, and has the capability of scanning more
    complicated linear barcodes as needed.Light resistance
    is the bane of a barcode scanner’s existence, and the LS2208 is
    no exception. When scanning from a standard range of 4 inches, the scanner
    could not easily read barcodes in direct sunlight or with our 250w spotlight
    within 12”. The LS2208 does act as a contact scanner, which can
    eliminate the problem, but only for barcodes about 1.5” wide.
    Smallest
    Density Barcode Scanned
    4.9mil
    Good
    Largest
    Barcode Scanned
    187.9mm
    Excellent
    Shortest
    Barcode Scanned
    38 mm
    Good
    Range
    Ideal Conditions (Standard 100% UPC-A)
    0 inches
    – 17 inches
    Great
    Multiple Barcodes in close proximity
    Relatively
    accurate, but can have problems with densely populate barcodes
    Average
    Scan through plastic layers
    2 Layers
    Good
    Multicolored Barcodes Successfully Scanned
    Blue,
    Grey, B & W Inverse
    Good
    Multicolored
    Barcodes Not Scanned
    Red, Yellow, Black on Dark Grey
    Average
    Simulated
    Sunlight Test
    Correct
    scans until spotlight was at 12”
    Averagethis is from its review...so I believe it should scan the 3.5 with no problem ...the issu emay be in settings ..I understood that it does have a interface that allow to make changes...
    this is the actual text :
    If further configuration
    is required, the LS2208 comes with a quick start guide to change some
    basic functionality of the unit. A full configuration guide as well as
    scanner configuration software are available both at POSGuys.com and Symbol.com.
    So check the guide..also on the manufacturer site for special settings that will enable it to read them ..if still will not be able..it means it is either damaged or they just brave out when said it can..
  • Catalin Turcu
    by the way ..it did say that failed some tests on some colors...maybe this is to blame ..and not the actual font.or size..
    this is the actual bar code i am trying to scan with the Symbol LS2208 scanner but it won't read it.
    the bar code font is AdvC39b
    *GGAD8364Y/250*
    GGAD8364Y/250 QTY: 250
    TI*ADS8364Y/250
    *TI*ADS8364Y/250*
    REC'D 05-12-10 QA ID: 52129 PKG 2 of 3
    AdvC39b
    AdvC39b
    1/4" (.25") or .6cm
    ok... this is the actual bar code I am scanning with the symbol LS2208 scanner.
  • Catalin Turcu
    if it is just one it may be the possibility that it has an issue or is damaged or something ..cause from what it is said in the review it should read it ...try to enlarge it ..or something ..if you need to store the info in something ..
    Genius:
  • 1,354 Answers
Hi
symbol bar code is plug and pay there is no software along with it may be some proble with cable only
just try in excel sheet to scane your code if it's scaning it meance there is no problem with your scanner there will be some setteing with your pos software wich your using for bar code
  • What are GTIN, GTINs, GS1, GS1-US?
    Starting in 2005 there was an introduction to a new barcode type, the GS1. The GS1 is a new name for EAN International and GS1-US is the new name for the UCC or Uniform Code Council. The new barcodes are GTIN barcodes UCC.EAN-13, UCC-12, UCC.EAN-8. Which are variants of other barcode types.
    Are both EAN and UPC necessary on products sold in North America?
    Starting in 2005 both Canada and the USA require to have both EAN and UPC barcodes types label on products being sold at a retail level.
    How small can my barcode be?
    IT Depends on the barcode type you're using. For EAN-128 and code 3of9 it is recommended to use 8 millimeters or 3.2 inches. For UPC, the dimensions cannot be an less then one inch in width. If your barcode is too small the scanners will have a hard time reading them.
    How do I get a bar code number for my product?
    If you plan on selling your product to end users at store level through a distribution channel, retail, you'll need the UPC barcode type. If not, the barcode type is determined by the industry you're selling to o.
How to program a bar code scanner to have 3 "TAB" in prefix
In the appropriate manual (see link)
https://portal.motorolasolutions.com/Support/US-EN/Mobile+Networks+RFID+and+BarCode+Scanners/Bar+Code+Scanning/General+Purpose+Scanners/LS2208_US-EN
Go to the proper symbology page scan the prefix start then find the tab character and scan it three times to add the prefix then scan the complete barcode for the prefix
May 16, 2016 | Zebra LS2208-SR20007R-UR
How do I get my Symbol LS2208 to recognize EAN128. I need it to prefix [C1 when a EAN 128 is scanned.
you need to scan some of the bar codes found on the manual.
Find the product reference manual -usually found on the cd with the scanner or download from motorola site - and in chapter "symbologies" scan "ENABLE CODE128" barcode.
To have prefix when a code is scanned, scan "SCAN OPTIONS" then " then "ENTER"
Last set the preffix value by scanning "SCAN PREFFIX" then four digits that correspond to the character you want to use as preffix.
If you need more than one character for preffix then you will need the Advanced formatting manual, which ican be downloaded from motorola. In this case you need to create a "rule".
Let me know if you need further assistance
Nov 11, 2010 | Symbol LS2208
How do I disregard the last character on a UPC bar code?
In general you can create an Advanced Data Programming Rule which will say: If you scan an UPC barcode, please send only the first 11 characters of the barcode.
There are programming barcodes in the manual for the scanner or you can use the 123Scan2 application provided at support.symbol.com to create the rule and print out an config sheet.
Aug 26, 2010 | Symbol LS2208 Handheld
Hi, i am trying to configure my barcode scanner LS2208 to put a {TAB} in when scanning
There should have been a sheet or book of bar codes that came with your scanner. These codes will allow you to program your scanner to do most anything, including adding a tab. You simply look at the bar codes and read what they do. you simply scan the one that adds a tab and it will forever add the tab unless you re program it.
If you have lost your book/bar code page, you should be able to go to the manufacturer website and download/print a document with the programmable bar codes.
Feb 26, 2010 | Symbol LS2208 Handheld
What is the bar code for the tab key
Hi paulajoy. I believe I can help, but I'm not sure what you mean. What are you trying to do? Configure your scanner to put a {TAB} keystroke in when scanning? Or are you just looking for the code for a {TAB} keystroke? If you are just looking for a code to identify it, the ones I know of are: ^I for Character, 09 for dec, and 09 for hex. If you're trying to configure your scanner, let me know and I'll be happy to help you find the right barcodes in the manual.
Jan 01, 2010 | Symbol LS2208 Handheld
I have symbol LS2208 handheld, Keyboard Wedge what is the setting to make my handheld recognize "Ctrl + S" ? I have tried this but still not work : *1st trial : Enable Convert to Code 39, Enable Code 39...
If your barcode is $V scan the following barcodes from the LS2208 Product Reference Guide.
Begin New Rule
Specific String At Start
$ (from the Alpha-Numeric section of the guide)
S (from the Alpha-Numeric section of the guide)
End of Message (from the Alpha-Numeric section of the guide)
Send Control S
Save Rule
That should do it.
Jul 09, 2009 | Symbol LS2208 Handheld
Program Symbol LS2208 scanner
Hello this requires advanced data formatting which you will have to scan some bar codes to program it. If you give me your email I can send the codes to you.
Jun 19, 2009 | Symbol LS2208-7AZK0100S Handheld
Can not scan Code 128 bar code
you should have a code book with the scanner setup barcodes in it, you need to enable code 128 by scanning the appropriate codes in the code book.
Sep 26, 2008 | Symbol LS2208 Handheld
Symbol LS2208 Handheld Logo
3,084 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
