Question about General Electric Stove/Oven/Range Chrome Timer Knob Set - WB3X459
GE Stove model no. J SP28G OJ3BG. Our timer is
Our timer is making a horrible whining noise. Is there a way to make it stop? Banging next to it helped one other time, but not this time. I don't care if the timer is still working after the noise stops. GE Stove model no. J SP28G OJ3BG
Why is my tumble dryer making a loud banging noise when on its a white knight model CL3A
Most of the time a tumble dryer will work like a dream but, as with all appliances, occasionally there will be technical problems.
If your tumble dryer is making a banging, whining (or other strange noise) it's best to diagnose and sort out the problem. It could be the result of a number of things, but what you certainly don't want to do is ignore it.
Here are the most common reasons for your tumble dryer making odd noises.
Coins and keys
One of the most common reasons for a banging, rattling or clanking is keys or coins left in pockets - so always check them before you put any clothes in the tumble dryer. More often than not you won't hear anything until the dryer cycle is in full spin.
Uneven surfaces
If the dryer is vibrating or shaking during spinning, check to make sure the dryer's sitting on a level surface. If it's fitted with height adjusters on the front legs, adjust them accordingly to ensure the machine is level as this will often reduce or eliminate the banging sound.
Drum bearings
If the tumble dryer is noisy when its turning and the whole appliance is shaking and rumbling, it could be indicative of a problem with the drum bearings, which help the wheels turn freely and easily.
The drum
If the banging noise is continuous when the drum is turning then it might be problem with the drum itself. If the noise is a metallic one, it could be the result of the drum scraping on something inside the machine. You could always check the drum visually for any marks or dents.
Motor bearings
If the tumble dryer is emitting a high-pitched screaming or whining noise it could be a sign that the motor bearings are wearing out.
Tension pulley wheels
If there's a squeaking noise coming from the dryer it could be the result of wear on the tension pulley wheels. This occurs more frequently on older models...or try this link..
Common Tumble Dryer Problems
Dec 09, 2016 | Dryers
Service manual for GE DPSR473EW0WW dryer
the timer may be stuck at a certain place as they have points that at times tend to burn out and stick when the timer gets to that point. do the other settings work? some times the moister sensor will not sense dry clothes and keep running? as for ur drum noise that may be due to bad rollers or bad tensioner and belt depending on ur model and hopefully not bad bearings also a possibility
Jan 22, 2015 | GE Dryers
GE pdw9980lss dishwasher makes a horrible squealing noise when not in use.
The dishwasher control panel must be defective, nothing else would cause this.
Apr 04, 2017 | GE 24 in. PDW9980LSS Stainless Steel...
Hi, our washing machine started making very loud banging and whining noise in the final spin cycle and the machine was shaking. We have taken off the back. The springs look ok. any suggestions?
Loud banging is usually an unbalanced load. whining noise is some times debris trapped in drain pump causing it to squeal like a fan belt on a car. Strings, threads and hoses tend to get wrapped under agitator and cause noise, too.
Jul 24, 2009 | Frigidaire Affinity ATF6000F Front Load...
GE JVM1650 Microwave Making Loud Noise
hello Frank. Sorry to tell you that the magnetron is going bad and making that terrible noise. Since the inside of a microwave, even unplugged has up to 2000 residual and deadly volts of electricity I recommend either calling a pro or replacing the unit.
Jul 12, 2009 | Microwave Ovens
Buzzing Noise coming from GE Stovetop.
It could be a loose transformer that needs to be remounted. Pull the stove out, remove all of the screws at the top and visually inspect the transformers and wiring. This should be an easy fix, but if you leave it too long then your stove will malfunction. I hope this helps at least get you to the next step.
Jun 21, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
When my GE refrigerator's motor stops it makes a banging noise
these are the early signs of compressor motor failure. i would make a service call before it completely stops and renders the fridge inoperable. the internal windings of the motor are becoming separated and lose.
Mar 13, 2009 | Refrigerators
General Electric Stove/Oven/Range Chrome Timer Knob Set - WB3X459 Logo
180 people viewed this question
Top General Electric Hardware & Accessories Experts
jdthefixer
Craig Butler
Craig Butler
Are you a General Electric Hardware and Accessory Expert? Answer questions, earn points and help others
