How do i clean my lcd screen? - Televison & Video
    Problem Solver:
  • 7 Answers
Take a wet towell
Posted on May 12, 2010
Can I clean my ViewSonic LCD Monitor (VE510b) with water (using cloth)? Please tell me easy procedure of cleaning my ViewSonic LCD Monitor screen. email: amdesh1@gmail.com
Hi
Time Required:
Cleaning a flat screen (LCD) monitor usually takes less than 5 minutes Here's How:
  1. Turn off the monitor. If the screen is dark, it will be easier to see the areas that are dirty or oily.
  2. Use a dry, soft cloth and very gently wipe the screen. A great choice would be the microfiber type of cloth used to clean eyeglasses.
    See Tip #1 below for kinds of cloths to avoid.
  3. If the dry cloth did not completely remove the dirt or oil, do not press harder in an attempt to scrub it off.
    Pushing directly on the LCD screen can often cause pixels to burn out.
  4. If necessary, dampen the cloth with distilled water or with an equal ratio of distilled water to white vinegar.
    Many companies also sell small spray bottles of special cleaner for flat screen monitors but the vinegar mixture is usually just as effective.
    See Tip #2 below for products to avoid.
  5. The plastic edge that surrounds the screen can be cleaned with any multipurpose cleaner but take care to avoid contact with the screen itself.
Tips:
  1. Avoid using paper towels, toilet paper, tissue paper, or something like your shirt to wipe the LCD screen. These non-ultrasoft materials can scratch the screen.
  2. Avoid cleaning products that contain ammonia, ethyl alcohol, acetone, toluene, ethyl acid, or methyl chloride. These chemicals can react with the materials that the LCD screen is made of which could yellow the screen or cause other kinds of damage.
  3. Never spray liquid directly on the LCD screen or it could run inside the monitor and cause damage.
May 20, 2011 | ViewSonic VE510b (Black) 15" LCD Monitor
Tip
Tricks Clean an LCD Screen
Enhance. Turn off your LCD monitor can be spots or areas that need to be cleaned more observable.Dust it off. Then use the microfiber cloth and wipe carefully collected the dirt off the LCD display.Use a suitable cleaning liquid. You can buy a cleaning kit, which are usually manufactured specifically to keep your LCD screens in the best conditions. There are LCD natural cleaning products and take into account.Work with the correct tissue. When cleaning LCD screens, use a good old cotton shirt or a handkerchief or buy special wipes to thoroughly clean the LCD screen. Spray cleaning solution on the cloth and clean with gentle circular motions. Let dry. Make sure your monitor is completely dry before using again.
on Feb 08, 2011 | Computers & Internet
Tip
How to clean an LCD TV
<span>An LCD screens must be cleaned as it attracts dust like a magnet. Cleaning is risky as the screens are very sensitive and there are chances of you damaging the screen if you don't know the proper method to clean it. To help you in this read the article below to the various tips on cleaning the LCD TV.</span> <b>Tips On Cleaning LCD TV</b> <b>Basic Facts About LCDs</b> <ul> <li>LCD screens or displays should not be cleaned through normal methods, as they are not glass. LCD or liquid crystal display is a soft film and it can be damaged through improper cleaning agents.</li> <li>The popularity of LCD TV's is on a rise as they can be can be run on low battery power and also have<a href="http://lifestyle.iloveindia.com/lounge/how-to-clean-lcd-tv-8061.html#"><span>sharp</span></a> picture clarity.</li></ul> <b>LCD Screens Problems</b> <ul> <li>LCD screens regularly gather dust and smudges and sometimes fingerprints and ink markings.</li> <li>Cleaning the screens with a <a href="http://lifestyle.iloveindia.com/lounge/how-to-clean-lcd-tv-8061.html#"><span>paper</span></a> towel, dishcloth or tap water can do considerable damage, as the screens are very sensitive. It can cause clouding and can cause damage to the pixels.</li> <li>Tap water contains chemicals like chloride and wiping the screens with it can leave a residue on the screen.</li></ul> <b>Cleaning Tips And Guidelines</b> <ul> <li>The LCD TV must be cleaned regularly for you to enjoy the proper clarity of the display.</li> <li>First of all, turn off the LCD TV and examine the condition of the screen.</li> <li>Note the smudges and the areas to be cleaned.</li> <li>To remove dusts use a microfiber cloth and brush off the dust particles.</li> <li>It is best to use proper cleaning solutions that come with LCD cleaning kits. However, you can mix one part of isopropyl alcohol with one part of distilled water and using cotton or microfiber cloth, clean the screen. Another cleaning solution that can be made at home to clean LCD TV's is to mix one part of vinegar in one part of water. Pour this solution on a soft cloth and then wipe the screen.</li> <li>Take care not to spray any sort of cleaning solutions directly onto the screen. Instead take it on a piece of cloth and then wipe.</li> <li>Wipe the screen in a circular motion and be very gentle. Don't press hard.</li> <li>Also do not touch the screen with your fingers or there are chances of leaving oily prints.</li> <li>Rub a soft cotton dry cloth to completely remove excess liquid from the screen as the moisture may damage it.</li> <li>Before switching back the TV on, let the screen dry completely.</li> <li>If some stains or marks are hard to remove, don't apply pressure to remove it. Instead, repeat the cleaning procedure several times to get rid of it. For ink marks and other hard stains, you have to invest in special cleaners.</li> <li>To clean the dirt from the edges or corners use a Q-tip. Dip one end of the Q-tip in the cleaning solution and squeeze out the excess moisture from the cotton tip. Now gently drag this tip along the edges.</li> <li>Do not use cleaning solutions that contain ammonia, ethyl alcohol, acetone, toluene, ethyl acid, or methyl chloride. These chemicals can react with the LCD screen materials and damage it.</li></ul>
on Jan 18, 2011 | Televison & Video
HOW TO CLEAN GREASE LOOKING SPOTS OFF THE SCREEN
Hi, LCD screen is quite different with crt screen. You should be careful while do cleaning. Unplug the power supply before do cleaning.
How to clean lcd screen: You can use isopropyl alcohol, hexane, petroleum benzine, glass cleaner with ammonia free.Apply the liquid to soft and clean cloth then wipe your screen. Repeat the steps until your lcd clean
Grease look on screen? Just use dampen cloth with water instead use above liquids as the may smear the contaminant across the screen.
Regards, Jay
Jan 20, 2011 | Hitachi 57F500 57" Rear Projection...
WOULD IT BE OK TO CLEAN THE SCREEN ON MY LG LCD SCREEN WITH DVD DISC CLEANING FLUID AND A SOFT CLOTHE
Soft dry cloth wipe frequently on LCD screen is the only way. Slightly damp cloth maybe use at your own risk of leaking water into the lcd screen and damge the tin oxide(turn black).
Sep 20, 2010 | LG 26LF10 LCD TV
My toddler has put toothpaste on the screen of our Samsung TV LCD HDTV LE40F71B, what is the best way to clean it off?
Monster Cable Screen Clean.
(you can buy it at every major electronics store)
http://www.monstercable.com/productdisplay.asp?pin=2350
Oct 09, 2009 | Samsung LCD-TV LE40S81B 40 in. HD-Ready...
Cleaning lcd monitor screen
use any soft clothe with liitle bit wet and wipe on screen.and leave it for 10 minutes .
Sep 08, 2009 | Computers & Internet
Cleaning lcd screen
It is recommended to use a simple alcohol solution to clean an LCD screen. This solution is made up of 1 part distilled water and 1 part 50% isopropyl alcohol. Be warned that isopropyl alcohol is flammable.
50% isopropyl alcohol is very common. If you find 70%, 91%, or 99% isopropyl alcohol, adjust the formula to use less alcohol and more distilled water.
By mixing these two in a bottle, you will produce a model cleaning solution. Remember not to use tap water -- only use distilled water.
Do NOT use tissues/Kleenex to wipe your screen. That is as ineffective, because they will leave little tissue partiels all over your screen . Try and find some microfibre cloth to clean your screen. Cloths that come along with prescribed glasses are usually good.
You may want to clean the rest of the actual screen before moving onto the LCD part. First dampen the cloth with the solution. You should never spray any sort of liquid directly onto the screen. Wipe the screen gently from top to bottom and wait for it to dry.
Be careful not to let the cleaning solution leak into the sides of the monitor. Also, be certain that you do not press hard on the LCD screen. You can permanently damage an LCD screen by pressing on it too hard.
DUST:
If there is just dust on your screen, there is no need to fully clean it. To remove dust all that must be done is to wipe it away with a microfiber cloth. Simply wipe your screen from end to end gently with the cloth.
Apr 07, 2009 | Sanyo Televison & Video
How do I clean the tv screen
Go to a Walmart computer department or any store that sells computers, TV's etc and get a product especially for cleaning LCD screens.
Mar 20, 2009 | Protron PLTV3250 32 in. LCD Television
Cleaning
Buy an cleaning kit with cleaning solution, and clean the display very carefully. If you apply too muck pressure you can damage the LCD display.
See also:
How to Properly Clean your LCD Screen
How to Clean an LCD Screen
How To Clean A Flat Screen Monitor
Dec 28, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
82 people viewed this question
Top Televison & Video Experts
