Question about Biostar GeForce 6100-M7 (890552602711) Motherboard
I get no video signal, processor does not seem to be running. I did change the 3300uf 6.3v capacitors at pct2,pct4,pct5, pct6 & pct7.
    Genius:
  • 1,584 Answers
Replace mobo.
Posted on May 13, 2010
Onkyo sr600 memory problem
I had the same problem with my TX-SR601 receiver.
Solution: I changed the capacitor C766 (100uF/6,3V) on the "DSP and main microprocessor" or "U1" board. This capacitor is responsible to keep the settings in the memory. It is directly next to the SRAM ICs (Q705-706) (type: CY7C1019BV/CV33-15VCT).
Now the receiver works properly again.
Mar 04, 2012 | Onkyo TX-SR601 Receiver
P4M900T-M2 Motherboard cant display anything on display, Power supply fan & CPU fan is running. I changed processor, RAM, Power Supply, Capacitors around CPU, but am still getting nothing on the...
It seem that changing the mother board was needed to confirm as there seems to be a problem related to non communication of the mother board with the CPU, RAM and sections.
Swap and confirm.
Aug 08, 2011 | Computers & Internet
When powered on I can hear the hv supply fire up and sound comes on, after a few seconds a relay clicks before video and shuts off until it's unpluged. The red indicator flashes three times over and...
Hi
A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this helps
Jun 09, 2011 | Televison & Video
The screen went blank with a pop sound. Now when you try to turn it on there is no audio and no video and and there is a funny sound that comes out of the TV
Hello, good day.
Hope this helps
May 21, 2011 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Toshiba tp48d51 projection tv is making a clicking sound. how do I fix it. It begins clicking as soon as it's turned on. The red needs adjusting and I can't seem to get it right. How do I adjust...
Hi
Hope this helps in solving the problem, also take caution, because it contains high voltage
May 12, 2011 | Toshiba Televison & Video
Shutdown after video comes up the green power light stays on but the set will not shut down while changing channels. (philips 27 pt543s) ic702 eeprom and ic7200 control/signal processor has been...
Re:"shutdown after video comes up the green power light stays on but the set will not shut down while changing channels."
Hi.
I do not think this has anything to do with logic circuits and video processing. When you stay on one channel the horizontal and vertical alignment circuit works more than if you change channels all the time.
This is just a guess, but have a look at convergence ICs. when you keep changing channels the power amp ICs (or transistors) go on and off, if one of them is defective it will overheat and shut down.
Other possibility is an internal tuner failure. Also test using a DVS or VCR.
Nov 01, 2010 | Philips 27PT543S 27" TV
VIEWSONIC PJD5111 SHOWS VERTICAL LINES
Hi... Projector show vertical lines... Issue in your logic board filter's missing on logic input board check for fail signal on video input logic board,,, check input connector for broken pin inside connector... also check capacitor & resistance arround video logic processor, possibility of over heat conponent
Oct 25, 2010 | ViewSonic PJD5111 Projector
Can i replace a 3300uf 10v capacitor with a 400v 22uf capacitor
The short answer is no. You can replace a 3300uf 10V cap with a cap of similar value but a slightly higher voltage (3300uf 16V or 25V).
Changing the capacitance value will significantly alter the circuit. Please note that the value listed suggests that it is a component in the power supply, specifically a filter cap.
Dan
Feb 26, 2010 | Mitsubishi WD-52525 52" Rear Projection...
D3V3 Trouble code on Phillips plasma
I had the same problem with the same Model TV. after doing some research i found that i had 2 bad 3300uf capacitors. I made a video of the repair and posted it to youtube. the TV works great now! Check out my video! i hope this helps.
Dec 11, 2008 | Philips 50PF9731D/37 50 in. Plasma...
Biostar GeForce 6100-M7 (890552602711) Motherboard Logo
126 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Jerry Umali
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
