Question about Maytag MSD2542VE Side by Side Refrigerator
Freezer isn't working
The food in my fridge isn't cold and the food in my freezer is defrosting.
  • Maytag Master
  • 1,606 Answers
You have no gas leak ! Replace the overload / relay , which is plugged onto the side of the compressor with 3 wires going to it . However , if a compressor pin is burnt off ( there are 3 pins ) , then the compressor will have to be replaced ( rare ) . Maytag has a problem with burnt overload / relays , so this is probably the problem with yours . Maybe 30-49 dollars for the part .
Posted on May 12, 2010
    Problem Solver:
  • 13 Answers
Check the compressor relies weather power is going through,the could be some loose connections.
The fridge could be having gas leakage which you will
have to fix and charge it with gas and may also be required to change the compressor.
Hi, I have a kenmore coldspot 106.56152500 and the fridge has stopped working. I can hear it running but it is not cooling at all. The freezer is still working, however, not as cold as it should be. I...
Yes the most likely reason for not defrosting is your=> W10135901 Defrost Control Board
The defrost control board can be found inside the fresh food compartment behind the control panel where you adjust temperatures for the refrigerator and freezer. To gt to the control board you need to unplug the refrigerator and disassemble the control panel. Look over the control board sometimes you may see signs of heat damage but not always. If you have questions I will be here so please ask, Thanks Sea Breeze
106.56152500 Parts
Jul 03, 2012 | Refrigerators
The freezer side is cold & food is frozen, but the refrigerator side isn't keeping food cold. Its warm!!
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 28, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Coolzone compact fridge freezer works for a while (a day) then totally defrosts and will not come back on. I turned it off and switched backed on later and it came back on again but keeps doing the same -...
Fan Problems
One of the most common reasons for the freezer to start failing is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food.
You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them.
It's also possible that the fan is not running at all. If the fan is burned out or the motor isn't running, cold air can't circulate through the freezer and everything will melt. You can normally hear the fan motor switch on and off from time to time. Listen for it and if you can't hear it coming on for an extended period of time, the motor may need repair or replacement. The wires connecting to the fan may be the problem, preventing the fan from receiving electricity.
Other Causes
Several other problems could be keeping your freezer from freezing:
There could be leaks in one or several of the hoses in the refrigerator, which results in the cold air being lost instead of circulating properly throughout the fridge and freezer.
If you have the freezer so full that the cold air can't circulate, your food will thaw even though the freezer isn't malfunctioning. Always leave some space open in the freezer and try to not store food right up against the cooling vents.
The thermostat might have shorted out, which means the freezer can't accurately determine how cold it is. If this is the case, the refrigerator would probably not be working, either.
If your defrost drain becomes clogged, the water in the line will just refreeze over and over again, which could damage the lines as well as the fan. Always check the drain and make sure no sludge is building up in it if you have a self-defrosting refrigerator.
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster than the fridge can cool it, which will thaw your food.
Hope this would help.
Have a nice day : )
Aug 17, 2011 | Refrigerators
Hotpoint (GE)CTX18GJB not cold enough. Just had serviced - tech replaced defrost timer and defrost terminator. The top located freezer gets cold and can hear the fan running - but still not cold enough...
I agree with the tech. if the refriderator isn't frosting it isn't working,their is only 1fan and its in the freezer,The tech could have missed some frost build up that is blocking the air flow into the fresh food section,if he removed all the frost it could take up to 24 hours to get cold ,it should slowly geta bit colder throughout the day,if by tomorrow its still not working have the tech come back and check for frost build up on the vents for air flow into fresh food compartment.
To reiderate their is two types of refrigerators,one that you have to manually defrost and a automatic defrost type where the defrost system which is comprised of the defrost heater,timer&termination t-stat will automatically melt the frost
Jul 28, 2011 | Refrigerators
Wont cool
you didn't specify if it is the fridge or freezer that is not cooling. Whichever the case maybe, I would diagnose both the fridge and freezer.
Let's start by diagnosing the freezer;
Fan problem is one of the most common reasons for the freezer to start failing, this is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food. You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them.
As for the fridge, the same solution but for more details. If refrigerator is not cooling properly can be due to a defrost timer, which is causing the fridge to go into defrost cycle. Usually it takes 45-60 minutes for refrigerator to come out of defrost cycle. If the timer goes bad then it will not come out of defrost cycle and can result in this kind of issues. It can also occur due to defrost thermostat, it allows current to pass through it at temperatures of 20 to 30 degrees Fahrenheit and prevents current from passing through it at 40 to 60 degrees. This is difficult to test, though, because it takes a prolonged, very-cold temperature to turn it on. The defrost thermostat is snapped onto the top portion of the evaporator. The thermostat sends temperature information to the processor. The defrost heater must be replaced when replacing the thermostat.
1. Remove the lower fan duct work from the evaporator cover. 2. Remove the 1/4-in. evaporator cover screws and remove the evaporator cover. 3. Disconnect the defrost thermostat wiring connector. 4. Remove the defrost thermostat from the evaporator.
I hope the above helps.......
Good luck.
Jul 11, 2011 | Refrigerators
I've recently been having trouble with my american fridge freezer. The freezer isn't freezing and the fridge is barely cold. The motor is working and there is some cold coming from somewhere but...
Good luck.
Jul 10, 2011 | Refrigerators
Samsung RSH1 power onto unit ok as lights working but no cooling in either fridge or freezer. This followed a power trip to the main electrics.
Regards.
May 02, 2011 | Samsung Freezers
Fridge section of fridge/freezer not working .
Take care.
Apr 07, 2011 | Zanussi Refrigerators
Had a fridge freezer in garage. Just found that
more than likely the defroster inside the freezer has gone bad. This defroster is located in the space between the fridge and freezer and activates to defrost the freezer and stop build up of ice in the freezer.. If it is bad the freezer will not keep the fridge nor freezer cold.
Dave
Jan 08, 2010 | Zanussi 3.46 cu. ft. / 98 liter Upright...
Maytag MSD2542VE Side by Side Refrigerator Logo
132 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
