I have a kichenaid dishwasher model #KUDL01ILBS2.The water drains fine after a wash cycle but while it sits a day or two it starts filling with water.I closed the water supply line and it has not filled with water.Is their a water valve that is not closing or opening after washing dishers that could be causing yhe problem?
Thanks Pete
SOURCE: Kitchen Aid dishwasher does not fill up with water.
yes, the problem is usually dirt in the valve or the water valve under the sink .
SOURCE: dishwasher fills but does not wash
Is your Kitchenaid Dishwasher a model KUDI02?
If yes, you need to order item 10 on the page link below:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5137276
Good Luck!
SOURCE: KitchenAid dishwasher allows water to drain while washing
Your dishwasher is siphoning the water out. The drain hose should turn upward, nearly to the bottom side of the counter top, before it attaches to the drain or disposal. If it has an independant drain it still needs the rise and also needs an air break to stop the siphoning.
SOURCE: My dishwasher starts fills water and never starts
If you hear a hum when it should be washing, the motor has seized. Replace motor. If it fills with water and stops quite, run it through a test using the tech sheet under the bottom panel to access. These dishwasher have had issues with the motor.
SOURCE: My KitchenAid dishwasher quit workin no light no
Hi
Thanks for using FixYa. Please check for the following if your dishwasher is not
working--
1. Fuse
(blown or tripped).
2. 120
VAC supply wiring connection faulty. Repair or replace wire fasteners at
dishwasher junction box.
3.
Electronic control board faulty.
4. Motor
(inoperative, check resistances).
5. Door
switch (open contacts).
6. Door
latch not making contact with door switch.
7. Touch
pad circuit defective.
8. No
indicator lamps illuminate when START or OPTIONS is depressed.
Please do rate the solution and revert for further
assistance.
Thanks
Rylee
