Question about Microwave Ovens
MY KITCHEN SINK HARDLY DRAINS , ESPECIALLY ON THE SIDE THAT HAS THE NON-WORKING DISPOSAL. I HAVE TRIED DRAIN CLEANER, AND ALSO VINEGR AND BAKING SODA, BUT CAN'T SEE IMPROVEMENT. I WOULD LIKE TO REMOVE THE DISPOSAL. WELL,.. ACTUALLY I WOULD LIKE MY SON TO DO IT. HE IS REASONABLY HANDY. IS THIS FEASIBLE? HOW WOULD HE GO ABOUT IT, AND WHAT TOOLS WOULD HE NEED?
    Genius:
  • 1,341 Answers
Before you go ahead with removing things try concentrated acid which normally solves these types of problems. They are available in DIY stores or plumbing shops. Hope this helps.
Posted on May 12, 2010
My dishwasher didn't drain the water out on the end of the clicle? What could be the problem?
Hello, Thank You for using FixYa. I will be helping you today.I would start where your drain line connects to the house drain,This is where most blocked drains happen. Disconnect the drain line and put it in a bucket and try to drain the dishwasher. Chances are its blocked somewhere you just have to find it.
Thank You and please ACCEPT my answer and Rate my answer if it was helpful..
Jul 02, 2011 | Microwave Ovens
Never have used a garbage disposal, now after 4 month and using it only about 30 times the water in the sink will not drain. When I turn on the garbage disposal the water in the sink swirls so I know it is...
hello fowl..... you have a blockage in the garbage disposal. you can use a chemical drain cleaner and pour it into the sink where the disposal is located. you should also look into that drain with a flashlight to make sure that there is not a fork or some other object causing the blockage. If you do not choose to use the chemical, you can also disconnect the disposal using the wrench that should be under the sink where the disposal is located. if you choose this method, have a pail handy to catch the water. also unplug the disposal before you work on it. Joe
Apr 24, 2011 | Microwave Ovens
My dishwasher is leaving water in the bottom after finished. The dishes are not cleaning. Are the two related?
Yes more than likely you have a restriction in your pump/drain. you will need to remove the drain cover in the bottom of the dishwasher and clean it out
  • Empty the dishwasher and remove the dish racks so that you can easily locate the drain inside your dishwasher. The drain is under a drain grate, usually at the back of the dishwasher.
  • Remove the drain grate by either popping the grate out, or by unscrewing the screws holding it in place. Different types of dishwashers will have different options.
  • Use the soapy water and the toothbrush or scrub brush to clean inside the drain area and the grate.
  • Rinse the drain area with clean water. Then replace the drain grate.
  • Pour ½ cup of salt, 1 cup of baking soda and 2 cups of vinegar into the drain (in that order). The mixture will bubble. This will clean the drain and the drain hose.
  • Wait until the vinegar/baking soda mixture has stopped bubbling. Then pour 1 cup of bleach into your detergent dispenser. Replace the dish racks and run the empty dishwasher on a regular cycle. This will clean the entire machine
  • If this does not solve the issue your drain hose may be plugged or crimped and lastly your pump may be failing.
    Feb 11, 2011 | Microwave Ovens
    When my dishwasher drains both sides of sink fill with water...then they both eventually drain back into the dishwasher.
    Sounds like your sink drain trap or line is clogged. When the dishwasher drains, the sink drain can't keep up, the water backs up, then backs down the dishwasher drain line into the dishwasher. You may not notice the slow line when you run a little water into the sink, but with the amount of water coming from the dishwasher the problem is worse. You can try taking off the trap under the sink and making sure it's clear. If the problem is farther down the drain line, you can try snaking it yourself, or call a plumber. I don't recommend using Liquid Plumr or Drano because if those don't work, they leave the line full of caustic chemicals for the next person who works on it. That can be dangeerous.
    Dec 07, 2010 | Microwave Ovens
    My dishwasher is not draining. How do I fix this please.
    first open the access cover by the floor after turning off power,then remove the hose clamp on the discharge side of the pump and with a shallow pan catch any water that flows out of pump,then check the hose from the discharge side of the pump to the garbage disposal or where ever it drain to,if any of these are clogged the pump either wont drain or will not run to drain,then remove the 2 wires off the pump and check the motor windings for continuity,every unit is different so you need to get this motors resistance specs and check its resistance if its open replace it
    Nov 17, 2010 | Microwave Ovens
    The drain to my Blanco supreme 533 U sink has become loose and is clogged up. How do I remove the drain section to clean & reseal? There is no obvious screw holding it on.... Thank you!
    The center drain is held in place from under the sink with a large nut threaded onto the drain. You'll need to remove this nut using a basin wrench. A pair of slip joint pliers may work if the nut is not corroded and turn easily. Of course you'll need to keep the drain from turning while you loosen the nut. Depending on how the drain lines are fitted you probably need to remove them also.
    Nov 03, 2010 | Microwave Ovens
    I need to clean brown stain and scale (?) from two 'plastic' tea kettles, one a Chefmate, the other a Kitchen Gourmet. The latter is much more stained than the other, with entire interior incuding spout...
    If you can find this product: (Or order it online)
    el-4.jpg Picture: http://www.sanishieldproducts.com/images/el-4.jpg To find a distributor: 800.528.3149
    Shower Tub & Tile Cleaner
    • CLEANS everyday scale, calcium, hard water spots, soap scum & body oils on showers, bathtubs, tile and sinks.
    • EFFECTIVE on glass, fiberglass, clear plastics, ceramics, aluminum, stainless steel, brass, chrome, porcelain and cultured marble surfaces.
    • UNIQUE biodegradable, cherry-scented chemistry. 32 fl. oz. size (950 ml)
    ELIMINATE" TUB & TILE CLEANER 32 oz.
    • Non-toxic, non-fuming non-abrasive, non-corrosive, non-flammable
    • Biodegradable
    • Removes soap scum, scale, hard water deposits and body oils
    • Safe on plexiglass, plastic fiberglass, chrome, brass, gold, silver and ceramic
    It is carried by Ace Hardware $6.49 ea
    An awesome product that you spray on and let sit overnight. then simply wash it off. (Non Toxic / Non corrosive) No gloves required but does have an odd odor so I would let it soak outside. Heavy accumulations may require a second treatment.
    Also great on shower heads. Remove it.. place it in a glass overnight and then re-install the next moring. Does not discolor anything. Ditto for shower enclosures and tile. Why this product is not in great demand is a mystery.
    Link with picture: http://milo.com/32-oz-eliminate-shower-tub-and-tile-cleaner (out of stock!)
    THIS WILL Clean it.
    Kelly
    Sep 10, 2010 | Microwave Ovens
    All of a sudden, the water is coming back up on my garbage disposal instead of going down, it also swirl. I tried to see if the blades are moving and they are free, not stuck, also there is nothing that I...
    The drain out of the disposal is plugged up...
    Take the drain piping apart and clean it out and then you will be good again...
    heatman101
    Aug 29, 2010 | Microwave Ovens
    Dishwasher does not drain. Drain valve is very hard to work and has burned out the solenoid. Can you tell me exactly how to get these parts out of the dishwasher. Do I have to replace the pump to replace...
    Hi
    Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter. Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
    First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
    Please do accept the solution if the issue is resolved or else revert for further assistance.
    Thanks
    Rylee
    Feb 09, 2010 | Microwave Ovens
    Dishwasher doesn't drain
    Check air gap located next to faucet line is likely plugged, especially if the machine is not used often, Try running 1/2 cup bleach through cylce about once every few months. Also if new garbage disposal was installed, make sure knock out was removed at d/w connect point.
    Jun 13, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
    Microwave Ovens Logo
    15 people viewed this question
    Top Microwave Ovens Experts
    William Miller
    William Miller
    Devabhakthuni...
    Devabhakthuni...
    Are you a Microwave Oven Expert? Answer questions, earn points and help others
