Question about Intel Desktop Board D915PGN - Motherboard - ATX - i915P - LGA775 Socket - UDMA100, SATA - HD Audio
Need help hooking up some jumpers wire on intel D865PERC
NEED SOME HELP ON HOOKING UP JUMPERS WIRE ON INTEL DESKTOP D865PERC
  • softHemant Mar 28, 2009
    How Can We Change Jumper Setting For Attach DDR RAM To SD Ram
  • 111 Answers
My motherboard (intel DG41WV) is starting but not giving output to screen. I have cheked cables sokets. Even i have cheked to other screen. but problem is still. all peripherals (fan, cd-rom...etc) are...
Jumpers:
Motherboard installed in computer case;
A) Keyboard Jumper Block
3-pin jumper block, Top of motherboard/ left side. Near the mounting hole, and 4-pin ATX +12 Volt power cable connector,
GENERAL example of a 4-pin ATX +12 Volt power cable, and it's respective connector on the motherboard,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
[ This power cable MUST be plugged into the motherboard.
It is power for the Intel processor ]
3-pin jumper block.
Starting at the TOP coming down;
Pins 3, 2 and 1.
Jumper cap should be on Pins 2 and 3.
(Enables the Keyboard wake-up feature. Factory default setting is Enabled. Pins 2 and 3)
B) Clear CMOS Jumper Block.
BOTTOM right corner of motherboard. 3-pin jumper block.
It is to the Left of the bottom/left SATA connector.
It is immediately to the Right of the motherboard mounting hole.
Starting at the Top, and going down towards the bottom edge of the motherboard;
Pins 3, 2, and 1.
Jumper cap should be on Pins 1 and 2.
When you changed the SMPS, do you KNOW for a fact it is a good one?
Did you plug the 4-pin ATX +12 Volt power cable, into the motherboard?
What COMS setting/s did you change?
I would go back into BIOS Setup, and set that menu screen back to the factory default settings.
[ Load Optimal Defaults ]
BIOS Settings Glossary,
http://download.intel.com/support/motherboards/desktop/sb/biosglossary_v18.pdf
Regards,
joecoolvette
[Motherboard manual - http://www.intel.com/support/motherboards/desktop/dg41wv/sb/CS-031417.htm
Nov 11, 2012 | INTEL - MOTHERBOARDS Computers & Internet
I am having trouble figuring out the control panel jumpers
Hi, here is a few pictures of controlpanel connections.
Hope this will help you.
Apr 11, 2011 | Intel Desktop Board D845PT Motherboard
Intel front panel connection for D845PEBT2 motherboard i need the diagram for the front panel connection on the motherboard
You'll find the diagram in the manual on page 33, item C.
If you no longer have your manual you can click on the link provided;
http://downloadmirror.intel.com/15337/eng/D845PEBT2_ProductGuide_English01.pdf
You will Adobe Reader to view the .PDF file.
http://www.adobe.com/products/reader/
Case wire colors vary, unless your case jumpers are marked. Common colors for positive include solid blue, red and green.
Ground - negative color is usually solid white.
Except when connecting an internal speaker, red wire is positive and black is negative.
Hope you find this hepful!
Mike
Nov 02, 2009 | Intel Computers & Internet
I want to know power and restart button connection
Here is the information you require - look at page 11 and 12 for the jumper information
Please remember to vote kindly if this helps you!
Oct 08, 2009 | Intel D946GZIS Motherboard
I need audio driver for Desktop
Here you go. follow this link, choose your OS from the drop down list, then choose your drivers.
You'll have to agree to the terms and conditions before the download.
good luck
tony
http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=948&lang=eng
May 19, 2009 | Intel Desktop Board D865GBF (MBIND865GBF)...
Need a wiring diagram for a Intel D865PERC
Visit http://www.intel .com and find the manual of required motherboard from support or download section. (ehteshamhusain@gmail.com)
Apr 08, 2009 | Computers & Internet
GOT THE INSIDES OF AN AMD ASUS BOARD AND A TOWER DESIGNED TO RUN GIGABYTE INTEL BOARD NEED HELP CAN I SPLIT THE FRONT PANEL WIRES AS AM UN SURE
okay, first of all no tower is designed for a specific mobo,so I imagine that the front panel connections are keyed one way and the mobo jumpers aren't the same.You can do 1 of two things you spend hours trying different connections and if your luckey get the thing to start.You could also go to the perspective websites and get the jumper layouts and match them that way.re-keying is never fun.My suggestion is to get a custom box w/ each and every wire is labled for the jumpers.I bought one last week for my g.f. for 16 bucks.GET A NEW CASE
Feb 01, 2009 | Gigabyte GA-8SIML Motherboard
I need help hooking my mother board up
See here below and let me know if you need more help.
Oct 01, 2008 | Intel Desktop Board D845WN Motherboard
Jumpers
I hope this link can help you understand the position of jumpers where to place it.
http://support.intel.com/support/motherboards/desktop/d865perl/sb/CS-008962.htm
-mrsolution
Jun 11, 2008 | Intel D865PERL Motherboard
Intel Desktop Board D915PGN - Motherboard - ATX - i915P - LGA775 Socket - UDMA100, SATA - HD Audio Logo
170 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
