Question about Miele 24 in. G638 Plus Free-standing Dishwasher
Miele G892 SC Touchtronic
INLET DRAIN LIGHT FLASHING, WILL NOT START UP. CHECKED FOR STOPAGE. WHAT ELSE COULD IT BE?
  • christina34 Jul 07, 2008
    inlet/drain light n. cleaned the hose and the thing under the mesh that uplocks!
    Problem Solver:
  • 4 Answers
Check drain pump impelar is free, it can be found under the non-return valve below filter. also make sure drain hose and S trap is clear.
Posted on Apr 03, 2008
My Miele G892 SC Touchtronic dishwaser is leaving a powder soap scum over all the dishes. What do I do?
Make sure you have at least 125 degrees going into the unit. If your using detergent power make sure you don't over use rise aid. Many brands have rise aid already.
Hope that helps!
Dec 11, 2010 | Miele Dishwashers
Drain intake indicator flashing. We have cleaned all but the intake filter. How do you clean or check to see if cleaning is necessary of the intake filter?
After cleaning the drain, looking at the intake (no filter on ours) and the light wouldn't go off, I just decided to take the ctrl-alt-delete approach and hit all the lower four buttons all at once, bingo, it cleared the light and machine started.
Sep 25, 2009 | Miele Touchtronic G892 Built-in Dishwasher
Outlet/inlet light flashing on miele dishwasher G674SC
Usually indicates a intake or drain fault - could be a plugged drain line at the garbage disposal or insufficient water coming into the unit
Sep 22, 2009 | Miele Dishwashers
Miele intake light on since new sink,disposal installed
check and see if the disposer drain port plug was removed. intake/drain light means slow drain or no drain
Feb 04, 2009 | Miele Touchtronic G892 Built-in Dishwasher
G892-SC Miele water intake/drain light blinks
The intake/drain light blinks. How do I fix this problem?
Aug 11, 2008 | Miele 24 in. G665 Built-in Dishwasher
Drain light is on and program stops
clean your waster water output pipe,back side of your dishwasher.
This often gets full of food.
Aug 09, 2008 | Miele Touchtronic G892 Built-in Dishwasher
Miele Touchtronic G892 SC Water leak at base of door
check the rubber seal around the door to see if its torn or smashed. if it is replace it, could someone have set somthing heavy on the door while it was open that would have stressed the hinges. it is most likely one of these problems take a nail file and slid it gently between the door and the body of the dishwasher if it slides in easy where it leaks you know the seal is bad and replace it.
Dec 09, 2007 | Miele Touchtronic G892 Built-in Dishwasher
Miele G892 SC dishwasher not heating/cycle won't stop
Miele have cold inlet only. Either element is open circuit, or the relay that switches the element has failed. My money would be on the element first, then the relay. The machine will sit in that mode forever as it is waiting for the temperature of the water to reach a certain temp before telling the electronic unit to move to the next part of the wash. If you need assistance in how to test & how to get to these parts just let me know. But you will need an ohm meter to test the element. Regards
Aug 20, 2007 | Miele Touchtronic G892 Built-in Dishwasher
Dishwasher ran with wrong soap
add some salt in the cabinet and a bit of water. salt acts as a foam suppressant
Feb 18, 2007 | Miele Touchtronic G892 Built-in Dishwasher
Miele 24 in. G638 Plus Free-standing Dishwasher Logo
1,177 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
