Question about Mitsubishi WS-55513 55" Rear Projection HDTV
Won't turn on
Turned off - went to bed- turned on next morning... NOTHING...flashing green light.. tryed the reset- nothing... is this a piece of junk now or is there a way to fix it inexpensively ????
  • kshin Dec 21, 2008
    I have the same problem with blinking green light and not turning on.  I have located the DM module but would like to know how to remove the module to access the caps.
  • Anonymous Dec 22, 2008
    I tried to turn on the TV, but all i have is the flashing green light. The reset button does not work nor does turning power off and back on. I would like to fix myself if possible but I do not know where to start.
What is two red lights and three green light on a sharp tv power light mean.
Posted on Nov 02, 2008
Is this the same process for the WS-65511. I have the same problem green light does not stop blinking. I removed the DM power board #935c986002 which postings show replacing the 7 caps. I also found the board that has the 4 caps under it. Which is the more likley cause? None of the caps look to have any issues.
Posted on May 12, 2008
To those who have tried replacing the four capcitors on the DM board without getting the desired results... take heart! When my WS-55513 developed the "blinking green light of death" syndrome, I embarked on a project of fixing it myself based on info I had gathered from others experiencing the same problem. Went down to Radio Shack and got the closest thing I could (1000mf/35V) and crammed them into the availble space. Hooked it all back up and... nothing. Pulled it apart and resoldered the connections just to be sure and... nothing. Pushed it into a corner and went down to Wal-Mart and bought a brand new RCA 50". After months of trying to figure out what to do with the old TV, I finally found a place that would take it off my hands for $50. But... being the frugal and persistent mr fixit that I am I decided to give it one last shot, and went down to the only remaining electronics shop I could find in town and got 4 new capacitors that appeared to be a better fit. Replaced the Radio Shack ones, put it all back together and plugged it in... only to see the blinking green light again. BUT.... after about 30 seconds the light went off. Hit the power button and miracle of miricles... IT WORKS! I don't know if the issue was due to the choice of capacitors, or perhaps a soldering issue, or not reseating the DM board properly or what.... but the moral of the story is... don't give up!
- Steve
Posted on May 09, 2008
    Genius:
  • 1,694 Answers
    Problem Solver:
  • 5 Answers
Do a search and you will find a lot of us that had the same problem. The issue is probably 4 bad capacitors on the DM board. The parts to fix it cost about $2.
There used to be a "how-to" detailing how to do this repair, but I can't find it anymore.
These are the capacitors you need..
part number - P13119-N
get them here..
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=P13119-ND
Posted on Apr 03, 2008
My Motorola electrify won't turn on or charge. It
maybe your battery or your phone os .... try a new battery if nothing happens... try re flash your phone
Jun 02, 2013 | Cell Phones
Just downloaded new books. Was reading one that night. Turned it off and went to bed. The next morning, I tried to turn it on to read more and it wouldn't come on. It was charged - not the problem. ...
Probably the its a frozen reader issue, try these steps:
1. Connect the reader to the computer
2. While the reader is connected hit the reset button for 3 seconds, and make sure the redlight comes on.
3. Leave the reader connected for 15 minutes, then disconnect it and see if operational now
4. If the reader still not turning on, try the reset and slide the power switch.
GoodLuck!
eBookBoy
http://digialreader.freeforums.org
Jun 23, 2011 | Sony Reader Pocket PRS-300
WD57732 purchased 12/06 and has worked fine. Turned off at 11 pm last night. No indication of trouble. Tried to turn on this morning and nothing. Did TV Reset, green light flashed for a minute like it...
Now,tv on?.Tv "LAMP" LED light indication flashes or stay on?How long the Lamp been inside this tv,been inside like 1 1/2 or 2 years and tv been on each day like 4 or 5 hours a day in used.The lamp life are over.Should replace another lamp.
Dec 10, 2010 | Mitsubishi WD-57732 Projection Television
My HTC Touch Dual have not turn on..
to do a hard reset you must hold down power/ send/ disconnect at the same time.
Jul 27, 2009 | HTC Touch P3450 Smartphone
Monitor Will not come on
bad capacitors inside the monitor they need to be replaced, or if the power light is blinking then there are transistors that need replacement
Mar 22, 2009 | Dell E198FP LCD Monitor
Panasonic PTAE 900U with new lamp and counter reset shut off
Reseat the lamp.  I had a similar problem.  Replaced the lamp and everything worked for about 3 hours.  Then, turned the projector off.  Next morning, when I turned it on, nothing.  Stanby/On light flashed green for a minute then the lamp light came on and the projector went into standby.
Jan 27, 2009 | Panasonic PT-AE900U Multimedia Projector
PLasma wont turn on
Unfortunately you need a repair man. The power supply is bad.
Nov 12, 2008 | Televison & Video
Light flashing and tv won't turn on
Hi there, I have a Mitsubishi HDTV 1080 and when I tried to turn it on the tv this morning it wouldn't turn on and the power light is flashing green. I pushed in the reset button but it just keeps flashing and still won't turn on.
Oct 05, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Green light flashes 3 times will not operate
Its may be the thermistor is defective or out of range or the board itself, the unit will not operate unless the defective part is not replace.
Mar 04, 2008 | Fujitsu 18C1 Air Conditioner
Sylvania 6432gg
I've got the same problem too. TV is approximately 10 months old... I think it's a piece of junk.
Aug 08, 2007 | Sylvania 6432GG 32" TV
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
194 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
