Question about Motorola Mobility RAZR V3
Screen has gone black, all other operations work fine....
My screen just went black (well it started to fade in and out) but all other mechanisims work just fine - I can hear all indicated tones, receive calls, make calls and the keys light up and charges as needed, what can or what am I to do @ this point?
  • Motorola Mob... Master
  • 641 Answers
I would imagine that the screen has gone bad.sense you said it started to fade..screen replacement is very easy on the V3. There are 4 screws on the cover under little rubber pucks.Then gently pop the back off.and you'll see the camera and the ribbon cables ..undo them carefully, the rest is very self explaining.
Posted on May 13, 2010
It went from fading picture to black screen
IS THERE ANY SOUND?? IF YOU HAVE SOUND BUT NO PICTURE, THE TV'S LAMP HAS PROBABLY GONE BAD. EASY TO REPLACE. ABOUT $120.
Oct 02, 2013 | Mitsubishi WD-73827 73" HDTV DLP TV
Iphone will not turn on! Shows Apple logo then fades out?
Leave the phone plugged into the car charger with the "plug into itunes" screen long enough to build a charge. It sounds like the phone is dying before it gets a chance to connect to itunes and start charging through the computer. If this does not work then the store clerk was correct and your battery will need replacing
Feb 09, 2013 | Apple iPhone Smartphone
Toshiba TheaterView fades to black after turning it on. Sometimes it seems to work fine. This has started 2 days ago and is getting worse. I shut it off for a few minutes then it is fine. It either...
There is a possible poor connection of component in your TV or poor solder or that would be the result of Power IC which is already defective...call a technician to fix the poor solder and or replace the IC that cause the problem
Sep 19, 2011 | Televison & Video
Dell inspiron screen went black when i booted up the system
check it with external monitor if you get display then lcd is gone bad otherwise if you get dell logo then restart the system , press Fn key and power on the button it will start psa test
check for any hardware failures.
if hardware is working fine hen you will have to reset the system back to factory settings or reinstall fresh operating system.
Mar 06, 2010 | Dell Inspiron 2200/6000/9200/9300 8x DVDRW...
Hp dv9000 switches on to show coloured lines on screen.
Hello
My first guess is that the screen circuitry has gone bad - although fixable. Use an external monitor to verify this. If the external monitor is fine then the screen circuitry is bad, if the external screen shows the same problem then the video chip or associated circuitry has gone bad. My company fixes these all the time.
Jul 28, 2009 | HP L1702 17" LCD Monitor
Sound but no picture
hi sir
as it is not giving the perfect picture so it might have gone wrong in the screen pixels better to check the lcd screen and me sure the pixels went wrong it can be also coz of the water vapours please keep the tv away from water or windows etc.there might be a circuit problem which may not be working .
thank you
Jun 29, 2009 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
My toshiba satelite L-35 screen fade to black and
The LCD ribbon convector is loose or damaged or the LCD is damaged
Apr 23, 2009 | Toshiba Satellite A100-S8111TD Notebook
Motorola razr phone
It sounds like the backlight in he LCD display has gone bad in the phone. Most displays now have an integrated backlight, so the entire display will need to be replaced. Its not considered to be a user replaceable component. Unfortunately, you'll have to take it to be repaired. The fact that you said it was "fading" before it completely went black tells me that it was going bad and about to fail.
- Jim
Feb 12, 2008 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
56 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
