Question about Jenn-Air JED8430 Electric Cooktop
I presently have an original 30" Jenn-Air cooktop which was installed in 1995. I believe it is a model C1200C, C2000C, C2200C, C3200C, CR 2200C series from he use and Care Manual that I have. The vent grill is in the middle with the controls on the right side. I have 2 elements on the right side, and I can put a grill or griddle on the left side. I believe it is radiant heat- where the element heats up and glows very red and then drops down to nothing. I am trying to replace this unit which is built into granite, without having major repairs and am having some difficulty. I need to have the opening width 31" in overall measurements, not cut-out, and the depth needs to be 21 and one eighth". My installer found one that would work and it is called the 31" Expressions Corrections Modular cooktop. I do want glass, not metal element. Can you help with the BIG problem? Thanks so much May McConaghy
  • mayjoyce May 12, 2010
    Thank you very much. You were very helpful, even though I had hoped to find a cooktop that was not metal.
    May McConaghy
  • Jenn-Air Master
  • 3,247 Answers
Wonder if this meets your requirements..hard to understand difference between 31" overall measurement and not cut-out.
http://www.jennair.com/assets/product/JED3430WS_Dimension%20Guide_EN.pdf
Though I am not sure if the down draft feature will fit your existing cabinet.
I think your installer has found
http://www.jennair.com/assets/product/CVEX4270B_Dimension%20Guide_EN.pdf
which is with metal element.
But you will need to be sure the cut-out size is consistent with the granite profile that you have.
The Jennair cooktops are also compatible to Maytag and Whirlpool cook tops - you may find a match.
Posted on May 12, 2010
Uninstallation of Jenn-Air JED8430BDB cooktop
There are 2 clips under the cooktop, attached to the counter.
Remove the drawers under the cooktop to see the clips.
Jul 05, 2013 | Jenn-Air 30 in. CVE3401 Electric Cooktop
I have a Jenn-Air radiant cooktop, two of the burners run on high no matter where the control knob is set?
This is usually the infinite switch has failed. They are easy to check and inexpensive. Here is a video that will walk you thru testing an infinite switch. It may be a different model but the testing will be the same. You can also enter your model # for diagrams and illustrations for your specific model. Not all models are available. All parts come with installation instructions.
Oct 03, 2010 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Right front burner fails to heat (at all) Jenn air
I suspect a faulty element or electrical connection to the element.
Mar 21, 2010 | Jenn-Air 30 in. CCE3401 Electric Cooktop
The Grill side on my electric cooktop doesnt seem heat up enough
I had the same problem with the 45" Jenn Air downdraft cook top. The installation of the ductwork from the stove to the outside of the house was not properly installed. The stove is appr 18' from an outside wall and the flow of air was hampered by
too great a bend in the ductwork at the point below the stove on the underside of the house and the pipe going to the outside wall. I believe that was corrected with more curve in the vent work, making for a smoother flow of air. Make sense?
Jan 07, 2010 | Jenn-Air JED8230 Electric Cooktop
What is the cabinet cut out for a Jenn-air 30" prostyle cooktop model# jcp430adp. The manufacturers specs are not specific
The pictures that are posted on the Jenn Air site are confusing. I waited until I received the unit to make the cuts. I am glad that I did.
Jul 18, 2009 | Jenn-Air 30 in. Pro-Style CCGP2420P Gas...
I want to replace my Jenn-Air cooktop model 89890. What is the easiest replacement cooktop?
Greetings!
I tried to look up your cooktop and only found it mentioned in several places, and thus did not get a complete description of your unit. What I got leads me to believe that yours is a downdraft model. Whether or not this is correct, you'll need to measure the underside (cutout) measurements of the cooktop and the physical dimensions of your unit within the cutout. Armed with this information, you should be able to make an informed decision. I recently replaced a Jenn-air (downdraft, with switchable cooking modules) and selected a GE profile modle JP 989SK1SS (stainless steel). We also considered Frigidare, Jenn-air and some of the higher enders as well. Our preference boiled down to features, keeping all of the appliances (mostly) in the same brand, and reliability. Ours swapped out very close deminsionally, and the installation was easy and neat. Decide on a brand. Most dealers have a brochure that list all of the critical dimensions of their appliances, and you should be able to decide what's best for you.
Hope this was of some small help. Regards, and good hunting!
--W/D--
Jul 17, 2009 | Cooktops
Just installed a new Jenn-Air Model JED8430. Burners work well but fan will not turn on. Two black wires and a ground coming out of my wall....presumedley no neutral. Any suggestions
I suspect that the two black wires were attached to a wall switch or a wall times, along with the ground.
Check to see if you have a hot wire there. then temporarily wire the two black wires together and see if the fan comes on, i believe it will.
Jun 13, 2009 | Jenn-Air JED8430 Electric Cooktop
Need To Replace the Cooktop of my Jenn-Air downdraft
Here is a blowup diagram of the cooktop.
CLICK HERE
Looking up the service manual - it is no longer available.
Hope this is helpful.
Thanks for using FixYa!!
Apr 25, 2009 | Jenn-Air 30 in. CVE3401 Electric Cooktop
Jenn-Air 30 in. JGD8130 Gas Cooktop
Yes. Buy a burner module. Sears sells them also most appliance part stores. (I am assuming you have the model with 2 knobs on the grill side) The electric version of burner modules is around $100 Gas should be similar price.
Jun 08, 2008 | Jenn-Air JGD8130 Gas Cooktop
Jenn-Air JED8430 Electric Cooktop Logo
190 people viewed this question
Top Jenn-Air Cooktops Experts
Paul Carew
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
