Question about Electrolux EL7020A Oxygen 3 Ultra Canister Vacuum Cleaner Bagged Vacuum
The repair shop told me my Oxygen3 needs to have a sumo(?) board replaced...again. I am not willing to pay for another repair and am wondering whether an new hose and adjustable extension tube would solve the recurring problem. Is the sumo board located in those parts or is it a malfunction that transfers to somewhere in the canister?
  • 50 Answers
The Sumo Board, is housed inside the canister section, part # and discription below
E-1180136-56 SUMO BOARD
So replacing the hose and or wand will not fix the problem. Suggest you stay away from "big box", retail, discount stores if you want another one.
You can contact me via email, I am the Ralph
Nador of this business
bschwartz@govacuum.com
Posted on May 12, 2010
Vacuum will not turn on
You may need to change the hose or the sumo board on the machine. Please call eVacuumstore.com for more details. Vacuum Cleaners Parts and Accessories
Dec 25, 2013 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Need to replace the main control board
Your best solution is to call Electrolux Home Care and find your nearest warranty station, even if you are no longer covered.
They will know how to perform this fix conveniently...unless you already have the new SUMO board. If that's the case contact me here, if that's possible, and I'll try to lead you thru the steps.
Nov 09, 2013 | Electrolux EL7020A Oxygen 3 Ultra Canister...
I have an Electrolux Oxygen 3 vacuum I purchased rebuilt. After 1 month the power stopped working. I took it into Electrolux Authorized repair dealer, which was a horrible experience. When we received it...
Never have liked Electrolux doing any repair because it has been my experience that they don't do what they say they did....if you can read between the lines.....give me a picture of the unit and more details and I'll try and help you.
Aug 04, 2013 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Bad sumo board
HI There,
I have replaced quite a number of SUMO boards on the Electrolux Twin Clean Vacuums. We have them in our online store vacuumspot.com.au
I am a little unsure from your question if you are looking to buy one or hoping to repair the board itself. If you are looking to buy this Sumo Board (part number 2193235021) or any other Electrolux Z8240 Spares we can certainly help you there.
However as far as I am aware the board is not realistically possible to repair so if that is what you wanted to do I think you are out of luck.
Hope this at least clears things up a little.
Regards
Alec
Dec 11, 2012 | Electrolux Vacuums
Mine did the same thing
poor quality parts= problematic machines
Aug 29, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
9 month old electrolux oxygen vacuum just quit
my electrolux oxygen canister just quit- i think it's the sumo board and the whole fuse problem why does this keep happening over and over (my 4th time w/ this model) and where can I buy a replacement sumo board myself?
Jun 19, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Electrolux oxygen 3 fuse
The fuse on my ELECTROLUX Oxygen3's sumo board did have clear markings: F5AL250V - this is a 5A/250V 20mm fuse made by BEL FUSE, however, any other such fuse should work. The fuse on my board was blown (luckily, what caused it seems to be a glitch as replacing the fuse was all that I had to do). I got 5A/250V 20mm fuse from RadioShack and, expecting that this could happen again, I also installed a simple (5A/250V-rated) automotive fuse holder (also from RadioShack) (the only fuse holder that was available at a local store) and it works wonderfully now. Should the fuse blow on me again, I should be able to replace it in less than 3 minutes.
Feb 03, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Electrolux EL7020A Oxygen 3 dead!
There is a board in the back (called the "SUMO board") which has a fuse hardwired to it. Most of the "no go" problems with this machine are related to this.
In order to check it, you'll want to take a thin flat-head screwdriver, and gently pry up the silver panel on the top of the machine. The easiest place to do this is on the side of the panel, as far toward the rear of the machine as possible.
You will then need to remove the 2 Torx screws on the rear panel, and the top body of the machine should then be able to be removed. There are two clips in the bag chamber, directly under the back portion of the bag compartment lid, which can be pressed in to facilitate removal of the back cover.
The sumo board will be sitting directly on the top of the machine, and the fuse in question will be on the right if you are looking at it from the rear of the machine. Unfortunately, if the fuse is blown, you will have to replace the entire circuit board. (Unless you feel very comfortable with soldering a new fuse onto it, which I do not recommend for safety reasons.)
You can also check continuity of the cord reel from here. On the right hand side of the board are two spade terminals leading to wires running down into the cord reel assembly. One black, one white. Checking the continuity between these terminals and the ends of the power supply cord will allow you to determine if the cord reel is providing power to the machine.
Accessing the cord reel will require you to remove the six Torx screws holding the main body to the base. Two of these are on the rear of the machine, and are very deep inside; so you will require a very long-shanked Torx driver to get at these. Two more are inside the bag chamber at the rear, and the other two are on the front handle assembly. This will allow you to lift the main body away from the base, and if you are replacing the cord reel you can pull the wires from the spade terminals and the socket on the sumo board, and feed them back down into the cord reel chamber to remove the old cord reel.
Reassembly is simply a reverse of the previous. Beware, however: getting the cord reel to align is something of a chore, so make sure that you have the retraction system functioning before you put the whole thing back together, or you'll be bummed when you finish reassembly and the cord won't retract.
(I've definitely never done that. Nope. Never.)
Hope that helps, good luck.
-R
Jul 08, 2008 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Oxygen 3 will not turn on
This is often caused by a failure of a fuse on the Sumo board, or occasionally by a failure of the cord reel. I just posted a rather extensive set of instructions on how to check these things as a response to a different thread, but I will repost them here:
-R
Dec 31, 2007 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Electrolux EL7020A Oxygen 3 Ultra Canister Vacuum Cleaner Bagged Vacuum Logo
322 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
