Question about JVC AV-27530 27" TV
No sound on several channels.
I have just recently experrienced a problem where I get no sound on seveal cable channels. Those same channels work fine on the other tv's in the house so I have concluded that it is not the cable signal. I have gon through and reprogrammed each channel, checked the mute, etc, and nothing has helped.
Any ideas, or is the TV just worn out.
  • Jon Word May 12, 2010
    I'm not using a cable box. cable plugged directly into TV. other TV's work fine using the same feed.
    President:
  • 3,130 Answers
Switch the cable box from one tv to another one see if the box you changed works on the tv set you removed the cable box from on all channels if it does work after you swap out the box then it has to be bad!!!
techman
Posted on May 12, 2010
  • Larry  Dillon
    Larry Dillon May 12, 2010
    try taking a tv to the spot where the bad audio set is you may have a bad spitter?
    techman
Sound robotic on samsung ln22a450c1d
change the sound volume in channels settings /avc and try
Jan 01, 2014 | Samsung LN32A330 32 in. LCD TV
No picture or sound on some channels
we cannot get a picture or sound on several channels. Otherwise the TV works fine. Any solutions? as you get p&s on several channels so your ser is ok the problem 1 loose contact near tuner or it is defective. 2 tuner signal line .
Sep 16, 2007 | Toshiba 20AF44 20" TV
Hi, I have an AVR-1906, and the sound does not work for cable. Tuner, etc sound works fine, but alll I am getting is a clicking noise similar to a heartbeat from the speakers when I try to watch cable....
Since the other inputs are working normally, there's probably nothing wrong in the receiver. I'm assuming you have a cable box and are feeding the audio from that to the receiver. If so, the settings there may have changed so that it's not outputting audio correctly (set for a different audio channel, for instance) or something has gone wrong with the box. (Recent storms in my area have caused problems with cable and FiOS boxes for several people I know, and they needed replacements.) If you're using an HDMI cable, try using the RCA audio outputs and see if they have the same trouble. I suspect you'll need to contact your cable provider to resolve this.
Jul 29, 2011 | Denon AVR-1906 Receiver
My Sunfire Cinema Grand used to be working fine, and I stored it away but recently I dusted it off to use. All channels are working for except for the Front Right. Both the Voltage and Current Source...
Crackling is not good. Sounds like it needs to be serviced if all of the connecting cables are in good working order. It can be repaired by Rita's Vintage Audio in WA state. They are expensive but good.
Mar 27, 2011 | Sunfire Cinema Grand 200 Five 5-Channel...
One of my speaker channels has no sound
reinstall the speakers driver or your sound card driver. doing that select what kinda speakers do you have (5.1 , 2.1, 2).
Apr 06, 2010 | Cyber Acoustics A5640 Computer Speakers
NES console - intermittent, varying static sound
Your possibly using a wierd RF channel, try putting your tv at channel 3 or 4 and use the channel selecter on your NES accordingly
Mar 30, 2009 | Nintendo NES Console
Sound on 2 channels a problem
I diconnected a recently acquired Panasonic DVR which was hooked up between my TV and the cable signal source, but this had no immediate effect on the two channels. I then reset the TV by unplugging it over night, and by changing the settings on the sound menu. These actions removed the problem. Is it possible that the DVR caused the problem?
Dec 08, 2008 | Digimate DGL32 32 in. LCD Television
No sound on 3 channels
Check if the sound adjustment is in STEREO-SAP-MONO mode
Change to STEREO mode
Jun 02, 2008 | Mitsubishi VS-50705 50" Rear Projection...
No sound
have you check with other input like a vcr?...good luck
Aug 10, 2006 | RCA F32649 32" TV
JVC AV-27530 27" TV Logo
65 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
