Question about Canon imageRUNNER 1670F Grayscale Copier
Have changed toner cartridge but alarm says check cartridge cannot clear the alarm or use the machine
  • 1,219 Answers
The toner tube has a small nose on front side that when you place toner in, and turn it, that nose and little triangle on copier cover needs to be one against other. If it is, then should work, but if the sensor flaper on sensor for toner is broken it would not work.
hope that helped.
Pls. rate
Posted on May 14, 2010
How to clear toner alarm indicator
change the toner sensor on the toner catridge
Jun 07, 2014 | Sharp AR-5516s
What code do i use to clear toner alarm indicator
it can't be cleared until you change the toner sensor
F2-40 error code on mx3110n
black toner supply trouble, try a different toner cart, remember to shake the cart before installing. power the machine on and off, if the code is gone then it was the cart if it doesn't clear your service tech needs to see the machine.
Jan 13, 2014 | Sharp "MX-3110N Color Copier, Printer,...
I change toner but alarm still on saying toner low
You may have to go into settings to clear the fault of low toner, depending on the year and make of printer. If that doesn't help then make sure that all packaging on the toner was removed and that it is the right cartridge
Oct 10, 2012 | Office Equipment & Supplies
I have a couple Brother Printers HL-1435 that are in alarm status and will not print. The Drum light will flash, and then the Drum, Ready, Alarm and Data lights all flash at the same time. How can...
This could mean one two things.
* The toner cartridge is nearly empty.
* You have a paper jam.
To replace toner cartridge:
Click this link to go to the Brother site where it will show proceddure with illustrations how to change the toner cartridge.
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000000/000065/faq000065_011.html?reg=us&c=us&lang=en&prod=hl1435_us&Cat=7
To clear a paper jam:
Go to this link for procedure. It also has illustrations to assist you.
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000000/000026/faq000026_005.html?reg=us&c=us&lang=en&prod=hl1435_us&Cat=113
I hope this helps.
Aug 04, 2010 | Brother HL 1435 Laser Printer
I refilled my sf 565 pr machine, but after refilling it is still showing me low toner
First time
I am not clear what was toner refill your printer.
Other brand I mean hp/canon.It is not supported toner for samsung.Try first time clean drum.If it not fix may be change toner cartridge.
Mar 04, 2010 | Samsung SF-565PR/XST Printer
Replaced toner alarm light is still on saying replace toner
The toner has a fuse in it. When you replace the toner the fuse blows and resets the toner counter/light. Sometimes it blows and fails to reset. If you can solider you can replace the fuse and try again. Otherwise you will have to exchange the toner cartridge for a new one.
Jul 03, 2009 | Muratec F-300 Fax
CC and drum Icon will not go out after changing toner cartridge
This Machine needs a copy cartridge. Replacing the toner will not clear it. The copy cartridge is the drum unit which is why the drum light is on. With the new copy cartridge a chip on the cartridge will reset the counter and clear the "CC" and the drum light. If you cant find this I can send you one. I believe on this model it is user replaceable.
Oct 31, 2008 | Office Equipment & Supplies
Samsung SF5100 has a loud buzzing noise
Hi there you might have a faulty toner cartridge is it a original or has it been refilled? I suggest to install a new toner cartridge and hopefully that will cure the fault. If this dosen't there maybe a small piece of paper stuck in the cartridge or after the toner cartridge within the heat section open the back of the machine (the jam door) and check there is no paper.
If the printed document is getting stuck just after the toner cartridge it will most likely to be the heat section will need replacing.
Hope this helps you and please rate me
Thanks J
Dec 31, 2007 | Samsung SF-5100 Plain Paper Laser Fax
Canon imageRUNNER 1670F Grayscale Copier Logo
56 people viewed this question
old marine
old marine
