Question about Samsung NV10 Digital Camera
I have purchased several sd memory cards and every time i insert one it gives a message "card error"
  • kakima May 12, 2010
    Are you sure you have SD cards? How big are they? The NV10 is specified to use SD cards, not SDHC cards. Cards bigger than 2GB are SDHC cards. They will fit into SD devices but will not work in them.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Samsung Master
  • 102,366 Answers
Having received no response in over a month, I assume this is no longer a problem.
Posted on Jun 16, 2010
PHOTOSMART 2575 DISPLAYS "MEMORY CARD
Insert a memory card (in my case a SD CARD) and SLOWLY extract card until error message clears and normal screen images appear.I had to do this several times but it worked for me but cannot guarantee it will for everybody.GOOD LUCK.
Jun 10, 2011 | HP Photosmart 2575 All-In-One InkJet...
My camera is giving me a "no memory card" sign, but the card is inserted correctly. I have taken it out, cleaned it, and put it back, replaced the batteries, and everything. However, to no avail....
If the camera displays Memory card error, No Memory Card, or takes an abnormally long time to write an image to the memory card, when a memory card is inserted or any of the above error messages, make sure that the card is inserted properly. For SD card, make sure that the card lock switch is in the correct position and not stuck in-between.Try formating the memory card ,if after formatting the card in the camera the error persists, try another memory card. If this occurs with only the one card it is likely that the memory card is defective, if the error persists over more than one card the camera may require service.
Mar 19, 2011 | Canon PowerShot S51S Digital Camera
Memory card error
Having gone over a month with no response, I assume it was just a matter of SD versus SDHC cards.
Jul 17, 2010 | Canon PowerShot SD550 / IXUS 750 Digital...
C190 does not read the sd card even when sd card format is ok . it is giving a message 'memory card requires formatting' 'please format memory card or insert another card' however inserting a new...
Hi sir
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • May 20, 2010 | Kodak Easyshare C190 12MP Digital Camera...
    Memory card Sandisk 4GB gives error memory card
    The S50 uses SD cards. Your 4GB card is actually an SDHC card, and will not work in the S50. You will have to confine your choices to cards 2GB and smaller.
    May 15, 2010 | Pentax Optio S50 Digital Camera
    Bought a memory card for my Kodak 'EasyShare' C530 and I don't know if it's the right one. I bought a 2GB Memory card with MMAGFQ2WDCA-D8 on the back of the card itself. The error message I get is...
    There are regular SD cards and high-capacity SD cards (HCSD). Some devices are not compatible with HCSD cards. It sounds like your camera is not compatible. You may still be able to purchase 2G & 4G regular format SD cards that will work fine.
    I hope that helps.
    Mar 20, 2010 | Kodak EasyShare C315 Digital Camera
    Memory card unformatted
    If there are sd card error, you cannot format your sd card. you may get messages like
    "No SD memory card inserted" messages appears when using digital cameras,
    "A media card hard been inserted that contains errors. Do you wish to repair the Media Card now?"
    You can read the files on SD memory card, but you cannot write new files or you cannot edit files on SD memory card,
    "Access denied", when SD card is corrupted or broken,
    you can fix sd memory card errors first and them format you sd card.
    Nov 05, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
    Optio E10
    Hello
    OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
    If the error is still displayed after you did the above, you might want to try the card in another camera.
    If the card works in another camera . the problem is with your card reader in your camera.
    If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
    1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
    2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
    Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
    It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
    If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
    Please feel free to contact me if you need further information
    Kind regards
    Andrea
    Oct 11, 2008 | Pentax Optio S7 Digital Camera
    Memory card
    hi
    try formating once. may be the card is okay but formated in diffeent format.
    also, try using on other camera or pc to find is it working
    Apr 01, 2008 | Electronics - Others
    Samsung NV10 Digital Camera Logo
    79 people viewed this question
    Top Samsung Cameras Experts
    Kazim ERGUNEY
    Kazim ERGUNEY
    Computer Links
    Are you a Samsung Camera Expert? Answer questions, earn points and help others
