Hitachi 61SWX10B has no internal audio. I previously used it only with an external receiver, but now want internal only. Using the remote volume control shows increase or decrease on screen, but no sound. Internal is set in the audio menu. Any reset of software, or is it all electronics? Appreciate best troubleshooting thoughts.
  • jghernon May 12, 2010
    Yes there is. I said in the problem: Internal is set in the audio menu. Maybe I should have said, I set the internal audio in the audio menu already and triple checked the selection.
    President:
  • 3,130 Answers
Is there a speaker swich or audio you need to turn on in the audio menu???
techman
Posted on May 12, 2010
Remote sends tv crazy
The volume controller may have been damaged from a power surge or internal disturbance; not related to the a remote control. Your TV has a set of External Out connections, usually RCA jacks colored RED White and/or Black. Red and White jacks are relative to Right and Left Speakers when an attached cord with RCA male connectors are used and connected to an Amp or some type of receiver. You should be able to use the TV OUT Audio to a small Amplifier and connect to a set of inexpensive speakers or any external speaker set. This method bypasses the TV's Internal speaker system as an alternative measure.
Dec 23, 2013 | LG 42" 5700 Series LED HDTV - 42LN5700
No sound
check the simple things first:
In menu are speakers switched ON or OFF?
In set or a box if used is volume turned low or off? (unplug box if used and wait--plug it back to see if a reboot of the box cures the issue.)
If set has hookup for external speakers make sure the setting is INTERNAL.
If using a receiver inline check volume is not down low and unplug and reboot it also.
May 17, 2012 | Hitachi 50VG825 TV
RCA Model 27F520T - it has no sound everything else is perfect?
I'm not sure what options are available in your audio menu, but here are some things to check before having a repairman check:
Click on menu screen, then select audio menu.
If there is choice of external or internal speakers, select internal.
If there is a noise cancelling option, deselect this.
If you are using remote to increase volume, try the manual volume button on tv.
Does the volume bar at the bottom of the tv increase as you adjust volume ?
Hope this helps
May 17, 2011 | RCA TruFlat 27F520T 27" TV
Volume on tv is locked volume wont go up or down and not even able to put on mute
Go to Menu from remote.
Select "Audio" and confirm "Internal" speakers vs. "External". Internal is the built in speaker sna external is when you are using a surround sound or reciever for audio.
Check this and follow up.
Jun 29, 2010 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Hitachi ultravision model number 42hds69 cable problem.
Usually you need a decoder to receive "Cable" With your "Cable" usually you connect the Cable antenna, to the Cable "Box" form the "Box" to the Audio Visual EXTERNAL inputs, in the back of the TV. Now IF your TV can receive the "Cable" directly, then you would have to connect the Antenna, into the rear of the TV, now you would go to the "Tuning" section, and, the TV, would automatically "Search" for any available channels. They would then, be displayed at the end of the scan. Please find a user manual below, this will help you tune in, IF you can. If you cannot, you will have to get a cab;e "Box" and a remote. Hookup to the TV, from the "Box" to the TV, via, Audio and Video cables. You use the "Box's" remote to change channels and volume. You first must set the TV's Volume, & picture setting, the TV, is basically just used as a "Monitor" for the "Box". Hope this helps..
http://tv.manualsonline.com/manuals/mfg/hitachi/42hds69_55hds69.html
Apr 23, 2010 | Hitachi 42HDS69 42 in. Plasma Television
Can not adjust volume
Is it the original remote that came with the TV? If you're using a universal remote or one that came with your audio receiver or DVD player or whatever then you may have accidentally switched modes to audio or something. Be sure the TV mode is selected.
Was it working previously?
Jul 21, 2009 | iLO 3200 32 in. LCD Television
Zone 2 volume control
Sounds like the Zone 2 amp was set to external, see below for instructions on setting it back up.
How do I setup Zone 2 on the RX-V661 Using the internal power amp.
Setting the RX-V661 remote control to operate Zone 2
1. Using a ballpoint pen or similar object and press the Code set
button. The Transmit indicator on the remote should flash twice.
2. Using the numerical key pad on the remote and key in 9992, the
Transmit indicator should flash.
You will now need to assign the receivers internal amp for Zone 2.
1. Set the remote control selector to AMP. Selector is on side of remote.
2. Press the Set Menu Button.
3. Arrow down to Manual Setup.
4. Press the Enter button.
5. Arrow to the Sound Menu option and press Enter.
6. In the Sound Menu arrow to Speaker Set and press Enter.
7. Arrow to the EXTRA SP ASSIGN and select ZONE2. This may require using LEFT or RIGHT arrow.
8. Press the Return button to exit out and return to the Manual
Setup.
Apr 05, 2009 | Yamaha RX-V661 Receiver
Max. VOLUME on Samsung TVs Too Low
Some models have a volume limit setting, check the MENU and look at the audio settings.
If this has external speakers use other speakers. If it has audio output connect them to a external amp and useing the remote adjust the volume. Check if audio settings are set to internal, external and fixed or vairable output.
Jan 09, 2009 | Samsung LN19A451C LCD TV
Pioneer receiver sx-315
With persistence, I was able to program the Universal Remote Control provided with the cable box to control my new used Pioneer SX-315 receiver. I now can control the tv volume, cable box, auxiliary stereo receiver with speaker system with one remote. Thank goodness I did not have to resort to buying a Pioneer remote control.
I was able to program another previously unused universal remote which I purchased several years ago. However, since the other remote control did not list the Vizio TV. That brand is too new for the remote.
Dec 06, 2008 | Pioneer SX-315
Sound control is via TV remote only
You didnot mention wehther you selected external speakers on you tv. If your TV allows this then do that, first.
Also the sound input to your TV must come from some source, (cable/ Sat). You could remove the audio inputs to your TV and only allow the audio to go to your Receiver.
RCA cables will allow this to be easy just remove the red and white audio to your TV. If you have sent them to your reciever then you must balance the cable box volume (reduce to the lowest level , then raise your recievers vol until satisfied if you are to loud when you switch to a CD then raise TV vol until they match, so your CD doesn't play to loud when switching modes)
If you are using an HDMI cable to your tv than there has to be a setup for turning off the internal speakers on your TV.
Dec 03, 2007 | Onkyo TX-SR605 Receiver
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
