Question about Hotpoint TDC32 Electric Dryer
Machine making grinding noise when turning - Hotpoint TDC32 Electric Dryer
  • Hotpoint Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryermachine making grinding noise when turning - 2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
Posted on May 12, 2010
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Brother sewing machine noise
Sound like the whole unit needs a good cleaning.
My rule is "if it moves give it a lube", be careful not to get oil on electric boards or in the motor. What is the make and model of your machine. I will try to help you more.
Feb 26, 2013 | Sewing Machines
Grinding washing machine agitator
more than likely the pump is the part that is making the noise. You can verify this by leaning the machine back where you can see the pulleys, your pump will be the one in the back. Remove the belt and each pulley should turn smoothly. The part number for the pump is 35-6780
May 28, 2012 | Maytag Washing Machines
Grumbling Noise on Spin Cycle
If there is any form of grinding at all when the drum is turned than the rear bearings in the machine is going bad. This will only progress an get worse, then eventually start leaking and grinding and finally lock up.
Apr 26, 2012 | Bosch Washing Machines
The machine is making strange noises when grinding
when first started up turn the steam valve open to get out air ... job done i hope or you need it repaired ... bsc appliances 07779933829 we repair via postal service anywere .
Jul 20, 2010 | DeLonghi EAM3400 Espresso Machine
Washer won't pump out water makes a grinding noise when turned on
Here is a tip that will help you with the not spinning or agitating problems....
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
heatman101
May 13, 2010 | Washing Machines
Machine won't drain, or spin and makes a grinding noise
This problem sounds like it could be serveal different thing. A motor that has a broken coupler will make a grinding sound. This machine does not use a belt. A gearcase can aslo make a loud noise when defective. Once I found a wire bra inside a pump and it made a grinding noise. All these things must be check in order to figure out what and where the problems lies.
Mar 23, 2010 | Kenmore 23822 Top Load Washer
Loud grinding noise Toshiba 1550
It is one of three problems,
1- the developper is starting to go bad, unfortunately with toshiba it is a common problem the seals go bad in the unit the gears are very hard to turn giving a loud grinding noise, although you can rebuild the unit by changing the seals, it's VERY messy and they don't always work ( after spending all that time cleaning and changing the seals and gears and it didn't work, I just started to change the DV unit.) Test by taking out and turning the gear by hand, if you need a plier to turn it, it's bad.
2-the toner itself is a problem, take out the toner and look at wherre it sits there is a gear that turns the toner to feed it in the machine, if it's dirty and has toner it will make noise, test by taking out toner and close machine, does it make the noise without it?
3- cleaning section where the drum is, this is what turns to feed excess toner into the small pastic container, aggravating but not a mechanical problem. And also check the fuser ( where it gets hot)
I think I've covered everything for that machine.
Good luck
Nov 30, 2007 | Office Equipment & Supplies
Hotpoint TDC32 Electric Dryer Logo
220 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Dan Webster
Dan Webster
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
