Question about Samsung HLN467W 46" Rear Projection HDTV
TV: HLN437W Samsung. The projection lamp turns off after about 20 minutes of operation. The 'Temp" LED does not come on. After about an hour, I can turn the TV back on but the picture turns off again after about 20 minutes.
    President:
  • 3,130 Answers
Unplug the set for at least an hour or so see if this changes anything???
techman
Posted on May 12, 2010
Replaced the lamp in Samsung HLN437W and picture is brighter but not bright enough even after adjusting brightness. Also lamp LED still blinks
A few questions: was replacement just a bulb or bulb with housing and was it OEM lamp from Samsung?
If lamp light is still blinking the issue it has is there---other possible reason would be a ballast that is not bad but putting out low voltage to the lamp or the supply voltage to the ballast is low for some reason.
Actually the set should if the lamp light is still blinking shut off the lamp.
Also are you hearing any high pitched or fan like sound when the set is on?
May 16, 2012 | Samsung HLN437W 43" Rear Projection HDTV
Tip
Error code by led indicator samsung SP67L6HX1X
<img src="mas_baz.jpg" /><br />There are three LED indicators. LAMP, TIMER, STANDBY/TEMP. Each Led or combination leds indicated problem.<br /> <ul> <li>LAMP blinking : The picture will automatically appear in about 15 seconds.</li> <li>TIMER and STANDBY/TEMP blinking : A cooling fan inside the set is not operating normally.</li> <li>LAMP and STANDBY/TEMP blinking : Lamp cover on the rear of the set is not properly shut.</li> <li>STANDBY/TEMP blinking : Check if the ventilation hole on the rear of the set is blocked, because if the inner temperature is too high, the power will shut off.</li> <li>All LED blinking : Lamp may be defective.<br /></li></ul>It takes about 30 seconds for the TV to warm up, so normal brightness may not appear immediately. The TV has a fan to keep the inside lamp from overheating. You'll occasionally hear it working.<br /><br /><br />
on Mar 29, 2011 | Samsung HL-R6167W 61" HDTV
Samsung dlp HLN437w (GREEN lamp and RED temp)-same time flashing. lamp and housing has already been replaced whats next?
If the Ballast board is not working Lamp will not come on,if the Lamp Fan is defective Lamp will not Light or stay on.
Go to Encompass Parts Distribution and Look up your Model#
they have free service manual for this TV.
Dec 28, 2010 | Samsung Televison & Video
Samsung TV: lamp out
Yes,tries websites like Tvrepairworld.com,Partstore.com,Ebay.com to buy a projection lamp for the replacement.Tv have "LAMP"indication LED light is flashing or staying on.If the projection lamp on the tv now,been in used 4 or 5 hours a day watching the tv.The projection lamp has not been replace the last 1 1/2 or 2 years on the tv.The projection lamp life is over,require changing.The tv also making clicking noises,the Ballast board also dead,require changing too.The Ballast board help to ignite the projection lamp.
Aug 02, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Tv comes on for about two minutes then shuts down. The lights stay lit.
Any LED light indicators on the screen panel said "LAMP"stay lit or blinking?The projection lamp life is over,require a new lamp,if "LAMP" LED light lite or blinking?The projection lamp in the tv now,been in use for at leat 2 years and tv on about 4 to 5 hours a day?The Lamp life span is over,require a new lamp.
Jun 11, 2010 | Samsung SP 56 K 3 HV 56" Projection...
I have a Samsung HLN437WX DLPTV. The problem that
no if the lamp works fine for hours , could be a signal problem check signal connection and wiring
May 04, 2009 | Samsung HLN437W 43" Rear Projection HDTV
Samsung HLN467W 46" Rear Projection HDTV Logo
107 people viewed this question
Jerry Greenberg
Jerry Greenberg
