Question about Kenmore 24032\24036 Top Load Washer
Top load 80 when spin is complete and drum noise
Top load 80 when spin is complete and drum is slowing down it sounds like flat tire
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
KENMORE top load, direct drive, neutral drain washers are made by Whirlpool.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Assuming that the springs are OK and that the vibration pads are in place and not worn, (See the Sears diagram or the following Whirlpool Service manual)
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
the problem points to the brake.
The washer uses a brake system to stop the basket at the end of the spin cycle.
Just like a brake on a car, it's designed to slip a bit so that the basket / car doesn't come to an abrupt halt.
Over time, the brake shoes can jam against the brake drum and bring the basket to a halt too quickly with a lot of noise.
A way to solve this (that I tried and it works) is to pull the basket tube / brake assembly and if the brake shoes look OK, spray a small amount of silicone spray on the inside of the brake drum.
Following is a description of how to remove the cabinet, pump, motor, transmission and basket drive tube on Whirlpool / Kenmore / Roper direct drive washers.
As an aside, you don't need a special spanner wrench to remove the spanner nut. I've found that a short (10") pipe wrench hooked over one of the spanner nut tabs and tapped with a hammer will usually loosen the nut. Also, rather than hitting the Drive block directly with a hammer, put a short piece of wood under it first to protect it.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Following are the Whirlpool Service manual for this type of washer and the Whirlpool parts list for their commercial washers although the consumer models are basically the same. Whirlpool (and Sears) have replacement brake pad / spring sets.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Posted on May 12, 2010
Testimonial: "done deal on the money"
My washer/dryer combo Frigidaire washer dosn't spin water out of clothes completely after spin cycles the clothes is still very wet. On the 1st spin cycle drum dosn't spin just makes noise,the 2nd and...
Good Afternoon Friend,
I understand your Frigidaire laundry center, model# FGX831CS, is not spinning water out of your clothes completely. I see that on the first spin cycle the drum is not spinning and is just making noise, and on the second spin cycle the drum spins to the left very slowly and loudly. First check to see if your washer is overloaded. Try taking some clothes out and spinning them again. Secondly, make sure that the load is not out of balance. Try rearranging the clothes to allow for proper spinning. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 19, 2014 | Frigidaire FGX831CS Top Load Stacked...
My dryer is making a squealing sound
Your drum bearings are wearing out or the belt driving it is spinning. The drum could be binding up and causing it to slow down and brake itself. The belt will continue run at regular speed and cause a loud noise as at literally slides across the drum. Kind of like spinning your tires on the pavement.
Feb 22, 2013 | Maytag SDE4606A Electric Dryer
2002 impala front end noise when accelerating/decelerating
Black the rear wheels, put the car in neutral with the parking brake on, jack up the front end and spin the tires. Once you locate the source of the noise, you can pull the tire off and check the brake pads and rotors.
Apr 03, 2017 | Chevrolet Impala Cars & Trucks
Loud screeching noise on spin cycle
I have the same problem...during SPIN it make a LOUD SCREECHING sound.
Apr 20, 2009 | Maytag PAV2300 Top Load Washer
Kenmore 90 series noise after spin
You need to replace the drive block and basket drive. You can download a tutorial to get you started at www.shop.washermd.com. The gearcase replacement tutorial will put you in the right direction. Dave
Mar 01, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Loud noise in slow down spin mode.
when it is in high spin then you stop the washer it makes a thumping noise until the basket stops sort of like a flat tire sounds to me like you need a drive block
Dec 18, 2008 | Kenmore 24032\24036 Top Load Washer
Squeak in Kenmore HE 2plus front load washer when drum spins
Squeaking noises are hard to find unless u open it and pin point where its coming from.. you can open the back cover if you are comfortable doing so.. let it run to see if you can heard... sometimes the bolt holding the pulley to the drum is loose and need to be tighten. Other possible is the shocks came loose or when install new.. the shipping materials were not remove..
Dec 13, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore dryer sounds like flat tire
take the top and front off your dryer and check the front drum slides. The top slide usually wears out.
Nov 17, 2008 | Kenmore 93142 Gas Dryer
Washing machine
it could be the break above the transmission. it engages what looks like break shoes when the machine is not spinning. if these are worn down to the rivets then it will make this noise. it requires a special tool to replace.0de7df9.jpg
Jul 14, 2008 | Kenmore 23822 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
98 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
