Question about Coleman Powermate Premium Plus 6250W Portable Generator
Need to rebuild my portable generator - Coleman Powermate Premium Plus 6250W Portable Generator
The first thing you need to do is Find out what load you what to connect it to. Only then as per your load you can rebuild it.
Posted on May 13, 2010
I have a rural king generator 6500 E It starts fine but after a few Minutes it dies?
It sounds like it is starving for fuel. You probably need to rebuild the carb.
Oct 21, 2014 | Sigma Powers Inc Rural King 6,500 Watt...
Why is my generator not starting
Check for fire to the plug. If so, the give it a shot of starting fluid. If it runs initially, then most likely the jets on the carbureator are clogged. You should remove the carb and clean/rebuild it.
Sep 06, 2014 | Steele Products 6000 Watt Portable...
Why does my generator pulsate while running, what's wrong with it?
This action is called governor hunting which generally means the carburetor needs resetting ,a complete internal cleaning or a rebuild
then adjust the high speed and low speed settings by the adjusting screws on the governor spring system (manual may be required for these settings)
Jun 23, 2014 | Honda 3000 Watt Portable Generator
Honda eB5000 generator has no a.c. after sitting couple years . It does run but no power at output for tv.
You need to flash the rotor to rebuild the residual magentism so it can induce in the stator.
Sep 01, 2013 | Coleman Powermate Premium Plus 6250W...
McColloch 7800 generator leaking fuel from the carborator.
rebuild carb using new needle and float if float is full of gas and sinking
Sep 17, 2012 | McCulloch 13HP 338 Cc Portable Generator #...
I need a diagram of the carb for my powermate 1750. I need to clean and, well you know!
nah, you don't need a diagram. Very very simple. Just make sure that all pieces stay where you lay them down.
If you are already cleaning it, consider putting in a rebuild kit. That will also (usually) have a diagram as well.
Jan 01, 2010 | Coleman Powermate Premium Plus 6250W...
Coleman generator not putting out enough volts
What can happen with these generators is there is a shield built into them to devert the heat that is produced but it is still released into the surrounding components and causes a plastic rain guard to melt slightly around the edges and the melted plastic fuses to the armature and causes voltage drop through the brushes due to lack of contact. It is a relatively simple fix but it requires a rebuild kit that can be purchased aftermarket through your local generator dealer. It provides instructions for the rebuild but are often times confusing and it is usually cheaper in the long run and less hassel to let the dealer install the rebuild kit for you. If you do decide to attempt this yourself there is an 800 number provided where it can be registered and it will allow you to access schematics online for this rebuild. Hope this helps, good luck!
Sep 01, 2009 | Coleman Powermate Premium Plus 6250W...
Coleman Powermate Premium Plus 6250W Portable Generator Logo
276 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
