Question about Enlight Combo (5601908) (Beige) (5601908) CD-RW/DVD-ROM Combo Drive
12v power point not working. which fuse is it? dont have a handbook with van, all my fuses are numbered, anyone know which number is for the cigarette lighter ? many thanks.
  • 5,603 Answers
Usually there is a diagram INSIDE the cover for the fuses. It is OFTEN hard to read because it is molded into the plastic and is the same color.
Posted on May 12, 2010
Ford transit van 2007 right hand parking lights not working
The left and right are typically fused separately with one side providing dash illumination and the other number plate lights, though there might be minor territorial variations, which is why the first point of reference should be the vehicle handbook.
There might be an override where when the ignition is off and the key removed the indicator stalk can select left or right hand parking lights.
Your van will not have an entirely conventional electrical system with most systems being switched by computer so there is a limit to how much an owner could or should attempt.
Apr 26, 2017 | Ford Cars & Trucks
What number fuse controls the cigarette lighter and the 12v adapter There is no reference to cigarette lighter in the owners manual for 2013 Ford Expedition XL
They are listed in the manual and here is the information, the fuses are under the hood in the power distribution box.
FUSE# 71 20A** Auxiliary power point/cigar lighter
FUSE #72 20A** Auxiliary power point (right rear quarter panel)
Attached is the pdf owners manual, in the document the fuses are listed on page 294.
http://www.fordservicecontent.com/Ford_Content/catalog/owner_guides/13exdom3e.pdf
Feb 08, 2017 | Ford Expedition Cars & Trucks
Saab centre consil lighter not working
interior fuse box lower dash drivers side the lid will give the fuse location etc . the rear 'lighter socket ' is usually for 12v auxillary input lead ie tyre compressor , unless it had a lighter in it, don't use this as a lighter socket as will blow fuse , the same may be for the front as most cars i've seen post 2008 dont have cigarette lighter's only 12v AUX sockets . check with your drivers handbook
May 13, 2014 | 2010 Saab 9-3
Ecm fuse location 2001 chevy astro van
The power for the data link connector is from a 25amp fuse Number 7 in the IP fuse box. As long as the check engine light is on the computer has power.
The main computer power is from two ECM fuses in the box near the battery.
The fuse locations should be in the back of your owners manual.
Dec 20, 2012 | 2001 Chevrolet Astro
No check engine light fuel pump dont work
That is a very involved answer. First I would disconnect the fuel pump and apply 12v directly to the wires to the fuel pump to rule out whether or not it is toasted. If it runs when you supply power to it, you'll need to isolate which wires are grounding to blow the fuse. Think about recent work done on the van as this may give you a clue where to start. Good Luck!
Jul 18, 2012 | 1993 Chevrolet Astro
I have a Chevy Express van that starts but has no motion help?
check the fuses and see if you have a blown fuse for the gearbox computer but please do not ask me where they are as i have no idea because i have never seen one here in spain but look in handbook for location and what the fuse numbers are for is what i would do first
Mar 14, 2011 | 2006 Chevrolet Express
12v charger dont work, what fuse is it
The cigar lighter is fuse # 41.
The 12 V power plug ( Ford calls it a power point ) on the dash is fuse # 39
The rear power point is Fuse # 37.
Oct 08, 2009 | 2006 Ford F-150
Fuse for rear wiper blade 1995 ford windstar van gl
The rear wiper fuse number is 24 in the passenger compartment fuse box.
Nov 04, 2008 | 1995 Ford Windstar
Car interior lights dont work
The easiet way to check the fuses is to buy a 12v circuit tester.
You connect the circuit tester to ground (any bare metel on the car, like a bolt into the firewall, or door latch etc) and then put the tester to the metal contact point on the fuse (each fuse has 2 contacts on the top)
Test one of the points, if it lights, you have power, if you test the other side of the fuse, and it's out (this is while the fuses are plugged into the fuse block) then the fuse is bad, if it lights, the fuse is good.
The testers only cost a couple of $ and you can find them at any auto parts store.
Note, there are a number of fuses that don't have power unless the key is turned on.
You can also pull the fuse out and do a visual inpsection to see if it's good, but this isn't always easy to see.
Make sure to replace any bad fuses with the same size fuse that you took out of it.
Aug 01, 2008 | Jeep Cherokee Cars & Trucks
Enlight Combo (5601908) (Beige) (5601908) CD-RW/DVD-ROM Combo Drive Logo
277 people viewed this question
Top Enlight Computers & Internet Experts
Larry Maranto
Jerry Umali
David Payne
David Payne
Are you an Enlight Computer and Internet Expert? Answer questions, earn points and help others
