Question about Samsung Spinpoint M HM121HI 120GB SATA 5400 RPM 8MB Buffer Mobile Bulk 120 GB SATA Hard Drive
Samsung SAMSUNG Spinpoint M HM121HI 120GB SATA 5400 RPM 8MB Buffer Mobile Bulk 120 GB SATA Hard Drive will this hard drive work with a mac n if so how do i format it
  • 666cds May 12, 2010
    May 12, 2010 - its a extrenal hard drive my macbook laptop my hard drive is fine we use to use it for hp laptop and satalite system as soon as i plug it in it says " The Disk you inserted was not readable by this computer initailze ignore eject
    May 12, 2010 - and to be honest if i dont figure it out soon i'll eject it alright right out the f**king window on the street ! ! ! ! !!!!!!!!!!!!!!
    Genius:
  • 1,354 Answers
Yes it will work
just go to folowing link you will get all your anser along with all details
http://www.samsung.com/eu/business/semiconductor/downloads/ProductGuide_2008_HDD.pdf
Posted on May 12, 2010
  • then you have to do one thing just formate in amy windows then try to conect with your mac
  • Samsung Master
  • 11,800 Answers
All hard disks will work with whatever OS you decide to use, the only limitation is that it has to be formatted to a file system supported by that OS.
This is a disk for laptops, so if you are replacing the disk of your laptop and reinstalling OSX you don't have to do anything extra - the format is performed automatically the install disk detects an empty hard disk as a target disk.
  • 5 more comments
  • Azrael SRL May 12, 2010
    In that case you must format it following this procedure
    1. Go to Finder -> Application -> Utilities
    2. Double click for Disk Utility
    3. Select the external Hard Disk you wish to format at the left column
    4. Click on the Erase tab
    5. At the “Volume Format” select “MS-DOS File System” if you intend to use it both on PC's and Mac's or Mac OS Extended (Journaled) if you will use it only on your Mac
    6. Confirm to format your hard disk , Click on “Erase” button.
    7. Pop up window will ask to verify the erase procedure. Click the erase button again in the window to start the erase process and wait for it to finish.
    k i'll try it just the way you said but if it doesn't work i'll post wat it says
    disk erase failed
    Disk erase failed with the error:
    POSIX reports: The operation couldn't be completed.
    Cannot allocate memory
    any other suggusions
    Either ask a friend with a pc to format it for you in FAT32 file system or do the following commands
    1. open Disk Utility and select the drive device itself.
    2. click the "info" button and note the name of the "Disk Identifier" field.
    3. open Terminal and enter the following command
    diskutil eraseVolume HFS+ "NAME" "IDENTIFIER"
    replacing "NAME" with the desired name of the drive, and "IDENTIFIER" with the drive's ID found in Disk Utility.
    I'll try it when I get back home thanx
I have removed the MK2546GSX. What can I connect to it to back up the files on this drive?
You should be able to plug a SATA connector cable in to it and plug that in to your desktop PC board and there is power cord adapters. I do it all the time when i am repairing them.
Feb 05, 2011 | Toshiba MK2546GSX 250GB SATA 5400 RPM 8MB...
I have a hp dv pavilion laptop and I want to upgrade the hard drive. i have a Samsung ATA HM121HI ATA drive. Is there a natural upgrade and who does this
LINK
Click link and choose the rpm and size that you want.You can swap it out yourself and apply a fresh Operating System. If you've never installed a OS, or you don't have a genuine copy of your OS, you may need to take it to a computer repair store. If you need more help or need more questions answered, respond and we'll see what we can do.
Jan 11, 2011 | Samsung Spinpoint M HM121HI 120GB SATA...
How to change a pcb board on a samsung hard drive
Remove the securing screws and gently unplug the ribbon cable. I do not advise doing this however, as even the same model of this drive may use a pcb board that is a different revision to yours
Jan 10, 2011 | Samsung SpinPoint MT2 HM100UI 1TB 5400 RPM...
If it is not visible in my computer
It is a SATA.
Ok so, when you purchase a new drive, will you have to also purchase a new operating system as well?
bcz, computer need a raid driver to visible your sata hard drive and also you can change your bios setup gohead you can do it.
Aug 13, 2010 | Samsung Spinpoint M HM121HI 120GB SATA...
Well me cd dvd romdose not work well the drive dose but it dose not read my cds
Please check the connection inside maybe it is just loose. If that is SATA connection that is prone to disconnection but if that is IDE cable inside maybe cable loose contack. Try to open the PC and then pull and insert the cable firmly. Restart the computer.
Jan 27, 2010 | Toshiba MK2546GSX 250GB SATA 5400 RPM 8MB...
Failure predicted on HM121HI, F1 to continue
The error you're recieving is a fair warning that the hard drive is about to die, if it were a "replace engine" light on your dash you would know what to do. Time for a new drive. If there's any dat on the old drive you need you have already comprimised it by re-installing windows, if so STOP using it and let me know your Country, state, city... from a different computer and I will point you to a data recovery specailist. If it's just a workhorse or you have it backed up, buy a new drive, re-install on it and you're back in business.
Chris
Jul 06, 2009 | Samsung Spinpoint M HM121HI 120GB SATA...
My PC detects the USB Drive but it doesn't appear in the My computer display
HI
PLEASE GO TO MY COMPUTER RIGHT CLICK ON IT AND GOTO MANAGE IN MANAGE U SEE DISK MANAGEMENT AS SOON AS U CLICK THE DISK MANAGEMENT AND YOUR HARD DRIVE IS CONNACTED UWILL NOTICE A POP UP IF NEVER BEEN USED BEFORE THE HARD DISK AND THEN FOLLOW THE INSTRUCTION...AND IF IT WA S USED BEFORE THEN U GO TO DISK MANAGEMENT U WILL FING YOUR DISK LISTED SO U JUST HAVE TO SAY CREATE VOLUME AND FOLOW THE INSTRUCTION...
IF ITS IDE JUST BE SURE FOR THE JUMPERS...
Jun 03, 2008 | Samsung Spinpoint M HM121HI 120GB SATA...
Samsung Spinpoint M HM121HI 120GB SATA 5400 RPM 8MB Buffer Mobile Bulk 120 GB SATA Hard Drive Logo
278 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
