Question about Avaya MLS 12D Corded Phone
Telephone ringins in all 4 stations
After a good number of years with the phone system having all calls ring in on one central telephone, the ringing started and continues on all telphones, which is inconvient for a law office with separate offices
, and is distracting. We have lost of misplaced the manuels that may tell us how to correct problem A download of the ATT&T Communications Release 4.0 did not give us the answer and a telephone call to AT&T indicated that they wouldnm't help us. Ours is a MLS-12D system with four active phones.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please download the user guide for Avaya in which every aspect has been covered including the programming from the link - Avaya MLS 12D Corded Phone programming and use. This guide is consisting of 263 pages which you can get printed and use for future information and troubleshooting as well. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on May 12, 2010
  • 2 more comments
  • rdp718 May 12, 2010
    Unable to download manuel, and really don't need full 263 page manuel. just answer to how to set or change ringing devicwe. Can we get a just that portion \? or someone explain what to do?
    Did you receive my comment. I erased same unintentionally. Can't download for some reason and think all I need is how to correct the ringing device. Can someonw explain or can I just get the portion dealing with the setting or correction of the ringing??
  • Rylee Smith
    Rylee Smith May 13, 2010
    Inconvenience caused is regretted. As it is a length procedure
    and can’t be posted here please select the relevant page like 2-2, 2-4, 2-15
    and more and make out a print of these for future guidance. However, you can download the guide from the link---
    Avaya
    MLS 12D Corded Phone Programming Guide
    Thanks
    Rylee
  • rdp718 May 13, 2010
    Second day. Trying unsuccessfully to download so as to read section dealing with ring set up, but unable to download. response is that may have "timed out" on your web site. When I try and "rerfresh" I still can't download and read. Please advise.
How do I reprogram the phone to ring when a new call comes in, default to a certain line, and show caller id when a call comes in.
The answer to the Caller ID question:
Depend on the type of system that the phone is connected to. Late model Partner ACS equipment will display Caller ID info between the first and second rings, provided that the telephone line is plugged into a module that supports Caller ID.
The answers for the other 2 questions are taken directly out of the Partner ACS Programming Guide which is available for free download at Avaya's website.
Ther answer to the incoming call line ringing question:
Again, depends on the system. For the Partner ACS:
1) Press FEATURE 00 at extension 10 or 11.
2) Enter the number of the extension to be programmed for Line Ringing.
The green lights next to the line or pool buttons show the current Line Ringing settings for all
lines or pools assigned to the extension. (If a line or pool is not assigned to a button, the green
light next to that button is off.) The following ringing options can be shown by the green light
next to the line or pool button:
? Immediate Ring - on steady
? Delayed Ring - flashes slowly
? No Ring - flutters quickly
3) Press the line or pool button until the button light shows the correct setting (the setting for the
currently selected line or pool also appears on the display).
4) Continue programming, or exit programming mode.
Line selection:
For incoming calls, the line selection (hunt sequence) is set by the local service provider). For outgoing calls....again....it depends on the system. For the Partner ACS:
1) Press FEAURE 00, SYSTEM PROG, SYSTEM PROG, CENTRAL PROG at extension 10 or 11.
2) Enter the number of the extension to be programmed for Automatic Line Selection.
3) Press **.
4) Press the line, pool, or INTERCOM buttons in the desired order. The valid entries for Automatic
Line Selection
depend upon the type of extension:
? Key Extension: Outside system lines, Left Intercom (the factory setting)
? Pooled Extension: Pool 880 button 1, button 2, Left Intercom, Right Intercom (the factory
setting), Pools 881-883, individual lines
For each button pressed, a display similar to the following appears:
5) To exit Automatic Line Selection, press **.
6) Press CENTRAL PROG and enter a new extension number, or exit programming mode.
Changing line ringing and line selection are tasks that are normally reserved for the Administrator of the telephone system.
Jan 06, 2011 | Lucent 18D Corded Phone
When calls come into the office ext. 10 rings. It's the receptionist's desk. However ext. 29 rings too. How can I stop ext. 29 from ringing on all incoming calls?
Changing ringing on a Partner system is done on either ext 10 or 11.
At one of those ext's press the feature key and "00"
Next press the left hand intercom twice
The display should say system programming
Press the right hand intercom once. The display should say Central telephone Programming.
Enter in the extension number that you want to program.
Press the line that you want to ring.
A solid light on the line means immediate ringing
A slow flashing light means delayed ringing (meaning the phone will wait 3 rings before starting to ring.)
A fast flashing light means no ringing.
When finished with that station press the right hand intercom and enter in the next extension to program and set ringing accordingly.
Press feature "00" to logout
Oct 26, 2010 | AT&T Lucent MLS-12D Phone
How Do I for some of my lines only to ring on certain phones? I dont want the rest of my phones to ring.
Sep 30, 2010 | Lucent PARTNER18 Corded Phone
Line is on "no lines rings"
Sep 22, 2010 | Lucent PARTNER18 Corded Phone
How do I turn off the ringer for the fax line?
I'm guessing that the fax line also appears on the telephone sets and rings on them.
Aug 24, 2010 | Lucent PARTNER18 Corded Phone
I would like to turn off the ringer on this phone for incoming calls.
Aug 20, 2010 | Avaya Corded Phone avaparp18d
Caller id not working on only 1 phone
It's a good bet that that telephone doesn't ring therefore the system won't pass on the caller id information.
Press the right hand intercom once. The display should say Centralized Programming.
May 26, 2010 | Avaya 700340193 Corded Phone
Can not hear the telephone ring on one of the main phones upstair
You will need to know which line(s), and on which station(s) (extensions) you want each line to ring.
Programming is accomplished as follows:
Default Installer Password = INTERCOM *746
You can enable different ringing assignments for individual lines and stations.
You must program ringing assignments on a per station/per line basis. You can control ringing for every line that has appearance at a station assigning immediate, or direct, ringing to some lines and delayed ringing to others. NOTE: Do not program direct ringing for lines that you assign to the direct department calling feature.
To Program: 1. Dial 54. “STA/LINE CONFIG.”
2. Dial 1 “DIRECT RING”
—OR—
Dial 2. “DELAY RING”
NOTE: For no station ringing, skip step 3 and make no line selection.
3. Select line ports for ringing (LED On = Selected Ports).
—Line port 1–14 = Dial 01–14 or press A1–A14
—Line port 15, 16 = Dial 15, 16 or press B1, B2
—Line port 17–24 = Dial 17–24 or press HOLD then press A1–A8.
4. Dial # when all line ports are selected.
5. Select station ports (LED On = Feature Assigned)
—Station 10–57: Dial 10–57 or press C10–C57.
6. Dial * when all station ports are selected
—OR—
dial ** for next station/line ringing assignment
—OR—
dial ***for configuration mode.
To clear current setting, repeat procedure.
Use an LCD speakerphone and a DSS/BLF console at station port 11 or 13 to see which features are assigned to individual stations. While you can install any non-LCD digital telephone and use it for programming, visual feedback of the programming operations will not be available. You must always keep the handset of the LCD speakerphone on-hook while you use this telephone to program the system.
Mar 26, 2009 | Comdial Impact 8024S Corded Phone
Change number of rings on Comdial Impact
Thsi change needs to be made in sys programming. Usually with a pc and vmmi software.
If you have that, call up your station and there is a setting for station fwd to vm setting you can adjust.
Dan
Mar 12, 2009 | Comdial Avaya Partner ACS Phone
Avaya MLS 12D Corded Phone Logo
29 people viewed this question
Top Avaya Lands Phones Experts
george  peters
george peters
Cabanaboyz
Cabanaboyz
Level 1 Expert
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
