Question about Sharp AR-5316 Advanced Digital Imager Copier
Error on screen number 4 - Sharp AR-5316 Advanced Digital Imager Copier
  • 328 Answers
No 4 with H .ENTER CODE 14
Posted on May 23, 2010
My ifb washing machine top load is got error in timing display as number 4
If the error comes up as E:04, then that is an error code that the washing machine is overloaded.
Try this:
Remove the clothes from the washing machine.
Unplug the machine from the power receptacle for 1 hour.
After 1 hour, plug machine back in and run the machine without the clothes in it until it completes the cycle.
On the next load, do not load the machine with as many clothes.
Please reply to me if this works.
Thank you!
Jun 13, 2016 | IFB Washing Machines
Tip
Fix all your PS3 Problems
Send Your Console to Sony = $150
You need a PS3 Repair Guide = less than $35
THE NUMBER 1 GUIDE IS YLOD REPAIR WIZARD
This guide has proven permanent fixes for the following errors:
In order of the most common:
1.YLOD (Yellow light of death)
2.Green/Red/Blue Flashing errors
3.Disk Read Error/Blue ray Drive Error
4.Hard Disk Corruption
5.No Display Error
6.Red Screen Error
7.Freeze ups
8.Fix All error codes (8001050F)
9.Sync error
10.Blank Screen error
Need More Info On PS3 Repair guides and the YLOD repair wizard
on Aug 25, 2010 | Sony Playstation 3 (PS3) Console
Treadmill error code 4
You will need to give more detail, like make and model numbers? without that information there is really little help anyone can give except contacting the manufacturers website for the manual to download.
Mar 01, 2014 | Exercise & Fitness
A minolta bizhub c-6500 error code c-3804
Fuser Unit Code Sensor (TEM-4)
Get into:
1."Service Mode Menu screen"
Press [03 System Setting].
2. "System Setting Menu screen"
Press [01 Software SW Setting].
3. "Software Switch Setting Mode screen"
Press [3] In the left box. Press in the middle box [1] or numeric buttons after pressing the "DIPSW number" and "Bit number" buttons.
4. In the right box change Press [On(1)] to a [Off(0)] to specify ON/OFF of the selected bit numbers.
IF THE CODE COME BACK GET A TECH OUT TO LOOK AT THIS RESETTING OVER again CAN CAUSE A FIRE AND THAT WILL RUIN A PERFECTLY GOOD DAY!!!!!!!!!!!!!!! Sensor TEM-4 may need to be replaced or cleaned or the Fuser rollers replaced
Jan 25, 2013 | Konica Minolta bizhub Office Equipment &...
Tk2 error
TK2 is for the secondary transfer unit located on the side door. The code will come on after a certain number of total prints, depending on the model. Enter service mode by pressing # * C *, enter number 24 and press the copy button, then enter number 4 and press copy. Highlight everything that says TC2 and press execute on the touch screen. CA will reboot.
Sep 07, 2012 | Sharp Office Equipment & Supplies
Turn the console on, displays the xbox screen then screen goes off and a red light starts flashing on console, says system error
is this a single red light? if so, it is a E code error. if there are 2, it is a overheating problem. if its 3, it is a general system error which could be a number of things which you need to figure out the secondary error code to narrow down the problem.
to find the secondary error code:
1. after the red lights start flashing, hold down the "controller sync" button.
2. push the "eject" button 4 times and count the amount of red lights that flash. the red lights will begin to flash rapidly. secondary error codes are only 4 numbers. 1 light = 1, 2 lights = 2, 3 lights = 3 and 4 lights = 4.
after you get the code go to this website, and on the right hand side of the screen under "Xbox Repair Guide" select your PRIMARY error code (1,2,3 or 4 slow flashing red lights). then it will ask you to enter your SECONDARY error code, which is the one you discovered in the steps above.
this will give you a very narrowed down idea of what is wrong with your console, and will give us "questions answerers" a better idea on how to help ya out!
Jan 01, 2011 | Microsoft Xbox 360 Console
Clean unable 46 error on dcp 135c brother printer
the proper reset code sequence to reset DCP printers without numeric keypad should be as follows:
1. press buttons OK, Menu, Mono Start one by one, followed by up arrow key four times. this should all be done as short a time as possible, around 3 seconds.
2. enter maintenance mode 80 by pressing the up/down arrow key and set key to select numbers 8 and 0
3. press blue MONO start button to select PURGE which requires it to be pressed a number of times before PURGE appears on the LCD screen of the printer
4. then use the up'down key and OK button to enter the reset code 2, 7, 8 and 3 keys to reset the counter : Note this does not overwrite the number next to PURGE on the LCD screen but once the last number is added it gets reset to 0000
5. press Stop/Exit key to go to root of maintenance mode
6. enter 9,9 to exit maintenance mode
May 19, 2010 | Brother DCP-350C InkJet Printer
The screen reads unable to init. and then see trouble shooting and rotine maintanance i tryied it and doesnt work
If there is no jam it is generally a mechanical issue such as...
1. The planetary arm assembly not engaged correctly
2. Ink cartridge/purge switch harness not connected correctly
3. Purge cam switch broken
4. Gear(s) on maintenance unit broken
5. Paper feed motor broken
6. Main PCB defective
I find that if there was a paper jam, and the user pulled the paper out, option 4 is most likely. It is the smallest of cracks but ruins everything!
You will need to contact your local ASC for repair, find it here.
Thank you for using FixYa! – Don’t forget to rate our service.
Nov 12, 2009 | Brother DCP-110C All-In-One InkJet Printer
Dell 5150 Start-Up Problem.. beeps
Beeping on startup is a memory error. The blue screen you got was most likely caused by a memory error as well. First, take out then re-install your memory. If the error persists and you have more than one stick, test each one singly to find out which stick is bad.
Jun 27, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Blue Screen
There are several problems for which blue screen can appear:
1) Memory problem,
2) Operating system problem,
3) Application problem etc.
Generally an error code is also displayed with the blue screen. You need to tell the error number to know more about your problem
Nov 24, 2008 | Intel D845EPI (INTELKD845EPILPAK10)...
Sharp AR-5316 Advanced Digital Imager Copier Logo
21 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
