Confifuration of level one
Configuration of level one router
    Guru:
  • 523 Answers
Hi Friend,
Please follow the below link to configure the Level 1 Routers
http://www.fixya.com/support/r4364415-configure_brand_new_belkin_routers
Regards,
Aysaam
Posted on May 14, 2010
What is the default password for cisco
There are two main methods to return a Cisco router to its original factory defaults. These two methods are described below.
Method 1
1. uses the config-register 0x2102 command in global configuration mode.
2. Check the configuration register on the router by issuing the show version command.
3. The configuration register setting is displayed in the last line of the show version command output and should be set to 0x2102. If this is not the case, enter the config-register 0x2102 command once in global configuration mode.
router#configure terminal
router(config)#config-register 0x2102
router(config)#end
router#
4. If the show version command is issued again, the same line in the command output will have '(will be 0x2102 at next reload)' appended to the current register setting.
5. Erase the current start-up configuration on the router with the write erase command.
Reload the router with the reload command. When prompted to save the configuration, DO NOT save.
router#reload
System configuration has been modified. Save? [yes/no]: n
Proceed with reload? [confirm]
Once the router reloads, the System Configuration Dialog appears.
--- System Configuration Dialog ---
Would you like to enter the initial configuration dialog? [yes/no]:
The router is now reset to the original factory defaults.
Method 2
1. uses the config-register 0x2142 command in global configuration mode.
2. Enter the config-register 0x2142 command in global configuration mode.
router(config)#config-register 0x2142
This causes the router to ignore the start-up configuration on the next reload. If a show version is issued, the last line in the command output will have '(will be 0x2142 at next reload)' appended to the current configuration register setting.
3. Reload the router using the reload command in enable mode. It is not necessary to save when prompted to save the system configuration.
router#reload
After the router has reloaded, the System Configuration Dialog appears.
4. Enter no to the question "Would you like to enter initial configuration dialog?"
5. Change the configuration register setting to 0x2102 by entering the config-register 0x2102 command once in global configuration mode.
6. Issue the write memory command in enable mode to overwrite the existing start-up configuration with the current running configuration.
7. Reload the router with the reload command in enable mode.
Once the router reloads, the System configuration Dialog appears.
Note: The configurations below are stored in ROMMON, and cannot be reset to Factory Default Settings by the write erase or config-register 0x2142 commands.
warm-reboot
memory-size iomem <not default>
Jun 18, 2013 | Computers & Internet
My D-link router (dir 615) saying is connected but have no internet access
Wired or wireless? Check all cables, have you tried to connect with a Ethernet cable to the ISP modem, if it connects, try connecting via the cable to the D-link. Work you way through the devices one by one.If it connects via the cable, it's the computer's wireless adapter. Will other computers connect? Or contact your ISP to verify the signal, have a tech come out to analyze the signal. It may be outside. It's happened before, to me.
Dec 26, 2012 | D-Link DIR-615 Wireless Router
Need the wireless configuration pass pharse
If you have never used the "wireless" capability of your router, then there won't be a pass-phrase.
Instead, you need to run the "wireless networking setup wizard" to configure the router:
* pick an SSID (the 'name' you want to use for your network)
* select an encryption-level (hint: use 'WPA')
* pick a password for your network.
Jan 19, 2011 | NetGear WGR614 Wireless Router
New sony viao has been confifurating for a day now....is this normal
NO it is not normal-- power down and reboot into set-up then choose last known good configuration
Jan 29, 2010 | Sony VAIO VGC-RB42G PC Desktop
VPN tunnel between two DLINK VPN DIR-130
- Logon to the configuration page of your D-Link.
- Go to Advanced tab
- And Click on Firewall Settings on the left side
- Under that look for Application Gateway Level at the bottom and you must uncheck at the box on it and click on save settings at the top.
Mar 02, 2009 | D-Link (DIR-130) Router
OUT SIDE LINE ACCESS PROBLEM
how to configuration out line acccess & confifuration procedure
pls pdf format shown
Feb 06, 2009 | Panasonic KX-T7730 Corded Phone
My netgear adapter sometimes cant find my 2 wire dsl signal
What signal strength do you get when you connect?
Is the router buried underneath or inside a cabinet or anything?
Consider relocating the router away from other objects (particularly metal items), or on the outside of any type of cabinet.
Jan 23, 2009 | NetGear WG111 802.11g/b Wireless Adapter
Avaya VPN phone behind a DIR-655
- Logon to the configuration page of the router
- Select Firewall Settings at the left side
- Uncheck the boxes under Application Gateway Level at the bottom part
- And Click on Save Settings at the top.
Jan 19, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Setup and confifuration of my linksys befsr41 ver 2 router
Since you did not include your exact model number and type of internet provider I cannot give you more specific instructions. Although you can refer to the links below on how to set it up. If you require further assistance just reply to this and give me the model number of your ISP and the model of your router. Also answer this question " When you plug your computer to your modem do you get online automatically or do you need a username and password"
DSL
Cable
Dec 17, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Wireless conections
Try the http://192.168.1.1 to access the router config page (needs Ethernet cable to be connected to the Router)
If config page still does not appear, then check your Internet Explorer settings> Security Level (not set to custom) If it is, then choose RESET ALL ZONES TO DEFAULT LEVEL and then try this address again. It worked for me.
Dec 26, 2007 | Zyxel Prestige 660HW Wireless Router...
Computers & Internet Logo
51 people viewed this question
David Payne
David Payne
