Question about Foxconn 661M03-G-6EL Motherboard
I need audio pin jumper and motherboard manual for audio
  • 111 Answers
Jumper setting vor motherboard setting in computer
AsRock Support > P4i65G > Main Support page,
http://www.asrock.com/mb/Intel/P4i65G/
In the top left column under the green AsRock name, click on - Manual in the list.
To the right of - User Manual - click on the country NAME nearest yours.
When the PDF file comes up........
Hover your mouse cursor at the bottom. The ghosted out navigation guide will appear.
Go to the far right, and click on the Adobe PDF icon.
(When you hover your mouse cursor over it, "Show Adobe Reader toolbar" will briefly appear)
Click on the Zoom Out icon ( - ) at the top, to Decrease the view size.
Use the Zoom In icon ( + ) to Increase the view size.
The Adobe Reader page number box, is to the right of the Down Arrow, at top.
Page 9 shows a Motherboard Layout, and the jumper locations.
Page 15 has the details about the jumper settings.
Motherboard installed in computer case;
A) At the Top/Left corner is PS2/USB/PWR1 jumper
There are 3 pins.
Starting on the LEFT side going towards the Right;
Pins 1, 2, and 3.
Jumper cap on Pins 2 and 3 for +5VSB
+5 Volt StandBy power.
It is for PS/2 or USB Wake-Up events.
Suggest leave on Pins 1 and 2.
B) To the Top/Left corner of the top white PCI slot, is the JR1JL1 jumper.
4 pins going across.
From the LEFT side going towards the Right;
Pin 1 and Pin 2 for JR1.
The next two pins are Pin 1 and Pin 2 for JL1.
If there is a jumper cap on those pins, your Front Panel audio ports, and Rear panel audio ports will not work.
(JL1 = Front Panel JR1 = Rear panel. The rear panel is also the I/O area. Input/Output. Where the mouse, keyboard, monitor, etc hook up)
C) Right below the round CMOS battery on the right side, is the
CLRCMOS0 jumper.
Clear CMOS jumper
NO jumper cap on those 2 pins to operate the motherboard.
"CLRCMOS0 allows you to clear the data in CMOS. The data in CMOS includes system setup information such as system password, date, time, and system setup parameters.
To clear and reset the system parameters to default setup, please turn off the computer and unplug the power cord from power supply.
After waiting for 15 seconds, use a jumper cap to short two pins on CLRCMOS0 for 5 seconds."
Regards,
joecoolvette
Jan 03, 2013 | Asrock P4i65G Motherboard
Please clear cmos system no display after overclocking
You can clean Cmos By Using the Motherboard Jumper method
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
if you think this was helpful?then pls.rate and if further question about it,i'm always open to help..goodluck and godbless
Feb 22, 2011 | Biostar G31-M7 TE Motherboard
Hello i have a toshiba a205-s5880 labtop and the its asking for a bioas password, so i went on line i need the jumper cable number
Hope this helps
Dec 29, 2010 | Toshiba Computers & Internet
I need to Reset bios
Hope this helps
Dec 29, 2010 | Toshiba Tecra A2 Notebook
Where is jumper reset
The reset jumper is labelled JBAT1 (circled in red below). Pins 1+2 are jumpered/shorted right now, just turn the machine off, move the jumper over to short pins 2+3, wait 5-10 seconds, move it back to pins 1+2 and fire it back up. Have fun!
May 25, 2010 | MSI K9N6SGM-V (7309-020(K9N6SGM-V))...
I pulled the jumpers off the audio pins on the
Go to this page on the via website, towards the bottom you'll find a link UM_EPIA-M_150.pdf
which is the manual for the epia motherboards
Apr 12, 2010 | VIA Epia M10000 Motherboard
How to connect audio from motherboard p5s800
It is Asus P5S800-VM motherboard. Download the manual from Asus, click the link provided;
http://www.asus.com/Search.aspx?SearchKey=P5S800-VM
You'll need to download and install Adobe reader to view the manual;
http://www.adobe.com/products/reader/
Turn to page 1-29. Section 11. Front panel audio connector (10-1 pin FP_Audio1). Notice there are two jumpers. One across pins 9 and 10. Another across pins 5 and 6. Pin one is marked, AGND and pin two is marked MIC2. ECT.
This is default setting when using the rear audio jacks. You can not run rear audio and front audio at the same time. (So pick one or the other). To run front case audio remove the jumpers and connect the I/O cables to the FP_Audio1 pins. There is a work around. You can buy an adapter that will split the audio from the rear allowing you to connect secondary audio and mic ports. Open the link provided;
http://www.cablestogo.com/product.asp?cat_id=2009&sku=40422
You can buy these locally. To connect the FP_Audio remove the jumpers and connect the I/O cable to FP_audio pins. Use Adobe reader and zoom in. You'll find each pin is marked.
Cheers'
Mike
Mar 08, 2010 | Computers & Internet
MSI motherboard, Front Audio Panel for headphone don't work.
On this motherboard you can enable or disbale the rear panel audio using jumpers on the motherboard. The jumper is labelled JAUD1. I'm assuming that if you select the rear panel, then the front panel will not work. This info is on page 36 of the PDF manual which can download from MSI. Good luck, the link to the manual follows:-
http://www.msi.com/index.php?func=downloadfile&dno=4117&type=manual
Sep 30, 2009 | MSI K8N Neo4-F Motherboard
Intel d865 glc mother board sound card is not woking
you first verify that front audio pin jumper place in motherboard
if you are not using front panel audio so insert jumper in front side audio attachment see manual for more detail
Feb 02, 2009 | Intel D865GLC Motherboard
On board sound
Hi nrls14, it can get pretty confusing with Gigabyte.
Go to page 9 in your manual or Pg 13 if using Adobe Reader. Motherboard layout. If you download the manual which is in pdf format you'll be able to enlarge the manual which will help you to see everything much better.
Download manual from here: http://china.giga-byte.com/FileList/Manual/motherboard_manual_7n400pro2_e.pdf
This is the English manual. (Downloading from china is a faster site).
Find SUR_CEN located between PCI slots 2 & 3 on the motherboard. Than go to pg 32 in manual or pg 36 in pdf. Set the pins SUR_CEN. Set a jumper over pins 1&2 & 5&6.
Front Audio Connector, leave a jumper across pin 5&6 & 9&10 (Default). On page 22 in manual, pg 26 pdf. Follow Method1:
Instructions. (Test your speaker system). You may need some tweaking & this can be done with the software included on the Gigabyte CD by installing the sound effects manager. Go to page 78 in your manual or pg 82 in pdf. Page 80 in manual, pg 84 in pdf. For six channel 5.1 sound. If you decide to use the Advanced 6 Channel Analog Audio Output Mode (using Audio Combo Kit, Optional Device). Follow the instructions on page 81 in manual or pg 85 in pdf. (Do not let the picture on pg 81 spook you). Pg 81 shows a set of pins not located in-between the two PCI slots. You make this connection by removing the two jumpers on SUR_CEN & plug in the SURROUND-KIT on to SUR_CEN pins. Lastly, both motherboard manuals are the same for the GA-7N400 & the GA-7N400 Pro.
Good luck nrls14!
Mike
Aug 25, 2008 | Gigabyte GA-7N400 Pro Motherboard
Foxconn 661M03-G-6EL Motherboard Logo
191 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
