Question about Xerox WorkCentre M118 Laser Printer
I have a xerox m118 printer connected via ethernet. It's driver is installed on windows xp home machine. The problem is that after some time the windows machine reports the printer to be offline which is not the case as I can ping it and view the web interface just fine. It only works for a while if you delete the printer from printers and faxes and install it again which is not practical. I have also tried restarting the print spooler several times but it does not seem to affect the problem. Any ideas?
  • 10,421 Answers
How to connect this ir3300 xerox machine to computer plz tell me sir i request u
you need to have a driver installed on each P.C
http://www.usa.canon.com/cusa/support/office/b_w_imagerunner_copiers/imagerunner_2200_2220i_2220n_2800_3300_3300i_3300e_3300en_3320i_3320n/imagerunner_3300#DriversAndSoftware
You need an ethernet network of computers
You need to set up the ip addess and subnet mask in the printer via its setup menu . At the very least a ethernet network Switch with static ip addesses for each device , or A router with DHCP server to dynamically assign ip addresses.
you need an rj45 socket on the ir3300 which it should have 802.3 ethernet 10/100 tbase ethernet according to ir3300 specs if it is missing you need a network card to be added to ir3300 by Xerox / Cannon
Sep 05, 2015 | Xerox Office Equipment & Supplies
Where can I get printer driver for Xerox WorkCenter M118, I'm using Win 7
The M118 is a PostScript printer, which is an older (but fully functional!) protocol that allows Windows to print the correct fonts and typesetting.
In order to use this device as a printer, you will need to have the PostScript module installed in the printer, and then install the printer drivers.
Drivers can be found at this link, and support documentation at this link. The two particular support documents you'll want to review are the User Guide and the PostScript User Guide.
Hope this is helpful!
May 09, 2011 | Xerox WorkCenter M118 All-In-One Laser...
NOT PRINTING IN WINDOWS 7
update your driver download the compatible driver for window 7
http://www.support.xerox.com/support/workcentre-m118-m118i/downloads/enus.html?operatingSystem=win7
Apr 19, 2011 | Xerox WorkCenter M118 All-In-One Laser...
I need Xerox workcentre M18 Drivers
Xerox WorkCentre M118 Drivers
The required drivers can be downloaded from the above link from Xerox Official Support. Select the operating system you have on your PC and download / instal the files.
Hope it helps! Good Luck!
CreativeTECH
Apr 09, 2011 | Xerox WorkCentre M118 Printer
How to install xerox workcentre M118 for windows 7 64bits
I am one of the technician trained and specialized in different computer  and printer manufacturer.
Here is one of the instruction on how to install your printer to windows 7 64 bit
-run the driver downloaded from the site, then select the location
http://www.support.xerox.com/support/workcentre-m118-m118i/downloads/enus.html?operatingSystem=win7x64&fileLanguage=en
-Go to Control panel
-choose devices and printers
-add a printer
-add a local printer
for Standard TCP/IP port has already been created on the computer, choose the port from the Use an Existing Port pull-down menu, next, and then skip to step 10.
For the port has not been created on the computer, choose the create new port button, choose standard TCP/IP from the Type of Port pull-down menu, click Next, and then continue with step 8.
-put the IP Address or hostname of the printer
-check if the query for printer is set to automatic, then next
-choose have disk
-choose browse, then select where you save the driver
-choose the required printer model
confirm the name of the printer
-choose do not share, then next
-choose finish
for more information visit:
http://www.support.xerox.com/support/workcentre-m118-m118i/support/enus.html?operatingSystem=win7x64&fileLanguage=en
Contact number:
English 1-800-821-2797
Spanish 1-800-821-7726
Hours of Support - 24 x 7
I hope this will help a lot.
thank you for choosing Fixya
Feb 27, 2011 | Xerox WorkCentre M118 PCL 6
Cómo cambiar el fusor de la xerox m118 y
I need a card red to be used in the Xerox M118 with connection RJ45, wich I can get, model or any specificacion
Jan 20, 2011 | Xerox WorkCentre M118 Laser Printer
Xerox M20I SCANNER
You can only do scanning on an M20i with a USB or parallel cable. That machine does not support scanning via an ethernet cable.
Oct 25, 2008 | Xerox WorkCentre M20i All-In-One Laser...
Can ping printer but jobs not received
have you checked your firewall?
Often times, even though you can ping the printer, the firewall will block the data going to the printer.
Jan 12, 2008 | Xerox DocuColor 4LP Laser Printer
Xerox WorkCentre M118 Laser Printer Logo
94 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
