Question about Motorola Mobility RAZR V3
How to make a call via OT-020C blue tooch
I have a palm treo cell phone 755 and omnitech OT-020C. I fingure how to answer call and hangup form the head set.
To make a call, i have no clue.
    Brigadier General:
  • 7,752 Answers
Press the green button......
Posted on Mar 30, 2008
Palm Treo 755 P, key doesn't work
yes it can be fixed try turning it off for like 5min thin turn it bacc on
Feb 18, 2010 | Palm Treo 755p Smartphone
I want to delete all duplicate contacts on my phone.
It sounds like you have them saved to your SIM card and your phone so just delete the copies off of either one that you pefer.
May 13, 2009 | Palm Treo 755p Smartphone
My palm 755 wont hot sync
Restart your Palm Treo 744p. Take out the battery from the phone for more than 3 min and put it back in. Switch on the phone and then try to Hot sync Again. Hopefully it will work. I am assuming that you installed the Palm Desktop software came with the phone on your computer
I have same problem once in a while when i try to hotsync with new comp and this trick always worked for me.
Nov 17, 2008 | Palm Treo 755p Smartphone
Treo 755
Did you ever figure this out? Mine is doing the exact same thing now.
Aug 01, 2008 | Palm Treo 755p Smartphone
Palm Treo
pin number is always 0000
hope this helps
Jul 14, 2008 | Samsung WEP200 Headset
I have a OT-020C BT headset and once paired to my Sanyo SCP-3200 phone, I tap the power/control button on the headset and say who I want to call. The voice-recog in the phone does the rest, usually. Of course it doesn't work in noisy areas so then press [END] and manually dial the number.
Apr 08, 2008 | Samsung SCH-i600
Pairing a AtivaBT220 to a palm treo 755
Make sure both devices are turned on.
Do a search for new devices with the phone, it should find all devices in range. Select the device you want the phone to pair with. Use 0000 as a password.
Feb 29, 2008 | Palm Treo 750 Smartphone
BLUE TOOTH
The name of your bluetooth headset is the OmniTech (OT-020C).
This will be slightly difficult to explain without knowing the model of phone... First off, you need to ensure that you are using a bluetooth enabled phone. You will need to enter the settings and tools menu. From within that menu, you need to find either "connections" or "bluetooth" and select. Make sure bluetooth is enabled. There will be an option to add a new device.
On your bluetooth headset, hold down the power button down until the power light stays lit. This may take 5 seconds or more. Now your bluetooth is in pairing mode.
Back to the phone, you want to hit "add new device". On certain models of phone you additionally have to select "search for devices". Your phone will recognize any headsets in pairing mode. When it is finished scanning, allow the phone to add your headset. It will ask you for the device pin code. This pin code will be 0000.
I hope this answered all of your concerns. If you are having trouble with finding the correct settings from within your phone, reply with your phone model and I can give you more detailed information!
Jan 20, 2008 | Motorola Mobility RAZR V3
Cannot save received pictures
When you download the picture to the phone it shows up as an icon with a description at the bottom of the screen. Tap on the icon with your stylus and that is where you will find the save choices.
Dec 24, 2007 | Palm Treo 755p Smartphone
Motorola Mobility RAZR V3 Logo
133 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
