Question about Panasonic KX-T7730 Corded Phone
Phone lines are flashing making a loud beeping noise. The screen is texting funny words. Phone is ringing with ambulance style ring before the normal tone
    Problem Solver:
  • 5 Answers
Another possibility is EMF (electric + magnetic fields). Your telephone "key" system, commonly referred to as a 308, is prone to interference from electric fields emanating from welders, public pool pumps, industrial dryers, even refrigerators. The only 2 solutions I've known are recabling the affected extensions with expensive 'shielded' cable (it's protected by foil wrap and an earth wire) or upgrading the 308 to the next tel. system called the panasonic 816
Posted on May 22, 2010
  • Panasonic Master
  • 2,460 Answers
There are 2 possibilities. You have either toasted the system, or you have bad wiring. Start by unplugging all the extensions. The model and time frame is right that this is a TA series box, which has 3 CO lines and 8 extension jacks on every card. Leave the lines plugged in and unplug all the extensions. Now take a phone and plug it into Jack 01. Does it work? If it does, keep plugging extensons in until it fails. That will give you an idea what's bad. If it failed with one phone plugged into jack 1, you probably have a dead system.
Carl
Posted on May 13, 2010
2 Suggested Answers
greg411
  • 45 Answers
SOURCE: Phone lines are flashing making a loud beeping
The phone doesn't like something it's sharing a line with.
First, check to see if the extension number on each phone is different. You may have two extension 11's.
Next, check that line 1 is line 1 one all of the phones, then line 2 is line 2 etc. If one phone has line line 1 showing up on line 2 then you may have wires crossed somewhere. Or if you pick up a line on phone one and line 2 goes red on one of the other phones you have wires crossed.
Last, check in the plugs to make sure the connections are straight. Sometimes when a phone plug is inserted the pins cross and short two lines together.
Posted on Apr 17, 2010
My phones ring style is set to loud detail and volume is at the highest being 7,when I recieve a call it is silent?
Hi There,
As per my understanding you have set your ring style profile to loud and highest volume 7 but still ur phone phone rings on silent when someone calls..
Please change the Profile setting once again as mentioned below:
How to change call alerts and styles?
1.From the general menu, select "Settings" > "Ring Styles" > "Style Detail"
2.If you select one of the styles, ie. "Loud" you can then highlight by scrolling down on the wheel & select "loud detail" & press on the "change" button (top right corner key).
3.Here you will be prompted to change any feature available to the "loud" style: volume, ringtone, alerts, voice mail, text messaging sounds, reminders beeps etc etc. All you need to do is to select the feature you need to change with the directional wheel and press the "change" button for each.
If you think my solution helped u to resolve ur issue please do vote for me..
Thanks
Enjoy!!!
Oct 28, 2010 | Motorola Mobility RAZR V3
Mar 18, 2010 | Panasonic KX-T7730 Corded Phone
My ringtone goes beep
  1. Push Menu
  2. Choose Settings (Wrench icon)
  3. Then Ring Styles
  4. Choose the second option (Ends in the word "Details")
  5. Change the ringer for messages to be different then calls
Aug 23, 2009 | Motorola Mobility RAZR V3
My Motorola Razr won't ring or vibrate when receiving an incoming call except when plugged in to the charger
Turn off the ringer id function in settings, ring styles, load detail, ringer id's off.
Hope this helps
Jan 11, 2009 | Motorola Mobility RAZR V3
Motorola w377
Like most of the W377, this one's very odd. The only way I know how to do this is to switch off all Key tones. Key volume is part of the Ring Style menu, so:
>Settings
>Ring Style
>Ring Detail
>Change
> On the Detail menu use the 4 way selector arrows to cursor down to Key Volume
>Change
>0
>Ok
>Back out
NB The Ring Style settings for ALL ring parameters (Ring Volume, Line 1, Text Msgs, Voicemail, Alarm, and Key Volume) change whenever you select a different Ring Style, so you can set up one ringtone in Loud Ring but get a different one for Soft Ring, a different one for Vibrate and Ring, a different one for Vibrate then Ring, etc.
For the sake of sanity (and to avoid the alarm waking me up with a loud blast of Bach when I wanted a quiet 'Ding') I have set the same ringtones etc in all of the above profiles.
BTW whenever you can't find a menu you need, try pressing the black round button (OPEN MENU) in the middle of the 4 way selector arrows - it opens submenus that can't be accessed any other way.
Hope this helps.
Jan 02, 2009 | Motorola Mobility W377 Met Silver/Pink...
A beep/ sound when second line rings
Correct. When you are on a call, and another call comes in. You will get a "beep" and see the line flashing, after about the 3rd ring, you will hear another "beep"....etc...
Sep 19, 2008 | Lucent PARTNER18 Corded Phone
Text tone motorola V3i
go to options ring styles... then for example your ring style is loud, then go to loud detail and there select the type of alert for messages. similarly it applies for all the other ring styles.
Apr 26, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Loud key sounds
with your v3 press <<>> select <<>> select <<>> in <<>> you must choose a ring style exemple:<<>> then goto <<>> and move to <<>> and change 7,6,5,4,3,2,1. Normaly, i put number 3 it's loud enought.
Aug 22, 2007 | Motorola Mobility RAZR V3
Panasonic KX-T7730 Corded Phone Logo
161 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
