Question about Gaggenau EB294/295 Electric Double Oven
I have just had my Gaggenau wall oven (side opening) eb 904/905 cleaned by a professional oven cleaning company. The oven trays are now difficult to slide in and out of the oven and seem to be 'stuck'. Can you give me some advice please?
ctf1800
  • 4402 Answers
SOURCE: oven
go here
http://www.gaggenau.com/AE_en/Home.do
the customer support
then operation manual
Posted on Dec 04, 2007
SOURCE: Gaggenau EB294/295 Electric Double Oven
I am a gaggenau engineer this is usually a fault with the door lock mechanism it can be manually reset eg remove oven and side panel pull back locking arm there is a also a built in test prog in oven clock that will switch door lock back to reset position but these will need to be done by an engineer as oven very heavy.
ring 08705 678910 for service and/or advise
good luck
Posted on Dec 19, 2007
  • 12 Answers
SOURCE: Gaggenau EB 270/271 Electric Clock
To set the clock:
1. Press the clock key 3 items until the hr/min icon flash.
2. Press the + or - key until it come to your desired time.
3. Press the confirmation (check) key.
You have your time.
If not, call the service support.
Posted on Sep 01, 2008
  • 12 Answers
SOURCE: gaggenau eb 270
No you don't need to remove the oven door to change the cover of the display. You have to remove the whole unit out and remove the top lid. Don't forget to switch off the circuit breaker before doing this and be careful this unit is heavy.
  • 10 Answers
SOURCE: error code F 20 on Gaggenau EB 260/262 oven
Sometimes the error light will come on because of mixed signals sent. If everything works, then just ignore it. Unplug the oven or turn power off in fuse box. This may reset the light control. Be very careful around the power source. Wear rubber bottom shoes, have dry hands and floor. Don't touch exposed wires with anything. This is 240 volts that can hurt or kill you!!!!!!
Posted on Nov 03, 2009
Testimonial: "Appreciate the advise, but would still like to know the exact meaning of error code F 20. Thanks."
How can I unlock my oven
Set the oven to pyro clean, let run for 5 mins, switch selector dial to off, leave for approx 10 mins and the door lock should deactivate
May 17, 2013 | Gaggenau EB 270/271 Electric Single Oven
How do I set the time of day on a Gaggenau Wall Oven, EB 985611?
How do I set the time of day on a Gaggenau Wall Oven, EB 276-610?
Mar 08, 2011 | Gaggenau EB984 Electric Single Oven
Gaggenau Wall Convection Oven EB 270 installation instrutions and electrical hook up.
http://www.gaggenau.com/US_en/service.do
you can download installations and user manuals from this site. You'd probably be better putting the full Enr (model) number in the search.
Click where it says 'All manuals available for download' this will open a window where you type in the model. You then get a long list of manual, I presume you want it in english, so pick the one that had EN in the first column and II (installation instructions) in the next column.
Hope the is what you're looking for, all the best.
Jul 05, 2010 | Gaggenau EB 270/271 Electric Single Oven
I have a Gaggenau 270-271 wall oven. It is showing F 42 on the screen. what does this mean?
Open circuit in the door contact switch even if the door is locked.
If this happened during a clean cycle sometimes if you start another cycle and then switch the selector off after a few seconds the fault will right itself. If this doesn't work then you probable need a new door lock.
Hope this helps
Jun 11, 2010 | Gaggenau EB 270/271 Electric Single Oven
We have an Gaggenau eb 290 oven and the error code F23 shows up - what does this mean? how can we fix it?
F23-relay electronics not selecting. There is either a fault with the pcb or a loss of continuity within the ribbon cable. Unfortunately, I think you are going to need an expert to look at this to confirm.
Sorry I cannot be of more assistance but some faults do require a physical check from a professional and cannot always be sorted out from a distance.
All the best.
May 13, 2010 | Gaggenau EB290 Electric Single Oven
How to take the door off a gaggenau eb 290 oven
gaggenau oven EB 378-6 door won't close completely It pops back open 2 inches.
Apr 23, 2010 | Gaggenau EB290 Electric Single Oven
good luck
Nov 20, 2007 | Gaggenau EB 270/271 Electric Single Oven
Gaggenau EB294/295 Electric Double Oven Logo
243 people viewed this question
Top Gaggenau Ovens Experts
Dennis Boxerman
Jaime Hernandez
ashburton
Are you a Gaggenau Oven Expert? Answer questions, earn points and help others
