Question about Maytag Neptune MDE5500AY Electric Dryer
The dryer is not heating up..i flipped the breaker and it still isn't heating. The lint trap is empty I've done everything the manual said to check. What do I do??
  • Anonymous Mar 15, 2014
    My dryer has no heat done everything it says to check it still doesn't work
  • Maytag Master
  • 43,501 Answers
Hi, If you have a gas dryerthe dryer is not heating up..I flipped the breaker - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
the dryer is not heating up..I flipped the breaker - 2_bing.gifour dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bingthe dryer is not heating up..I flipped the breaker - 2_bing.gifs= Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on May 12, 2010
Dryer wont heat up
Small 3oo f fuse mounted on the heater element is probo blown from over heat due to vent blockage.
Dec 30, 2015 | Roper REX3614KW Electric Dryer
Power indicator lights up but there is no power
Remove exhaust hose. Clean out lint. Remove back of dryer. Clean lint out of air flow system including lint and heat unit(coils). Try dryer. Is heat element glowing red hot? If not, replace heat element. They burn out intermittently and need lots of air flow to have good life. Clogged lint traps shorten life cycles. Definitely a DIY project. See youtube for general process.
Jan 09, 2014 | Whirlpool Dryers
GE Dryer DBSR453Eb2WW takes twice as long to dry clothes
A clogged or partially clogged vent will reduce the air flow through the dryer and greatly increase the drying time. I assume you checked the drying time again after you cleaned the vents. Have you also checked that the lint trap is clean? Make sure no lint has found it's way around the lint trap and has jammed the intake.
I would be very suspicious of the 240 v breaker double breaker feeding the dyrer; maybe the dryer is only running on 120 vac instead of the full 240vac. The motor would be getting full power, but the heating element would only be getting half power.
Mar 26, 2013 | Dryers
The dryer is not heating. It will run for a short time but then shuts itself off and the top four green lights will flash. We have thoroughly cleaned the lint traps inside and outside of the machine
Hello Brenda Gibson - Try reprogramming the unit by flipping the household circuit breaker off or unplugging it. Wait approximately ten minutes and restart unit. If it proves to be ineffective, the dryer could possibly be experiencing a communication error with the main control board, wiring failure, or faulty door lock assembly. Consult a professional for an accurate diagnosis and to assist with the repairs.
Feb 10, 2013 | Frigidaire GLEQ2152ES Electric Dryer
How to know if the blower motor isn't working? The heating element is working and the flame is on but not sure if it is blowing while on. It seems to take a longer while to dry.
There is always a kill switch on the door, so you have to hold the switch closed and the dryer will start. You can also take off the exhaust tube and see if you have any air movement there.
But first, when was the last time you check your lint trap to make sure that is isn't obstructed? And I am not talking about just cleaning the lint off of it either. Take the lint trap out, clean the lint out and then take it to you sink. If you run it under water, the water should pass right through without pooling. If it pools, then just clean the screen with a soft brisstled brush and water, then test again.
It is the dryer sheets that close up the screen openings and if bad enough can even cause an overload/overheat situation.
Jun 04, 2011 | Dryers
Dryer not putting out heat.
This could be many things. Flip the breaker off then on. Check the lint trap and vents for clogs. Use a multimeter to test the heating element and fuses inside the dryer. Good luck.
Apr 06, 2011 | Dryers
My dryer won't turn on.
A dryer may not start for many reasons...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Apr 15, 2010 | Kenmore 83042 Electric Dryer
It shuts off before the cloths are dry
Most likely either the lint trap needs to be cleaned out, the exhaust piping needs cleaning or you have faulty heat sensor / circuit breaker.
Be sure to clean the lint trap before every load may even try cleaning it out half way through the cycle too.
Good luck.
Aug 24, 2009 | Dryers
Maytag Neptune MDE5500AY Electric Dryer Logo
74 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
