Question about Grundfos MQ3-35 3/4 HP Pressure Booster Pump
Pump cut out. Primed pump and restarted but keeps cutting out within a minute - looks like only the water in the pump? not sure if priming is working ? do we routinely open the low vent valve for priming? this is a domestic water supply with an onderground tank and a grundfos pump
  • Grundfos Master
  • 43,501 Answers
Here is a tip that will help you..
Jet Well Pump Well Jet Water Pump
http://www.fixya.com/support/r3695577-jet_pump_jet_water_pump
Posted on May 26, 2010
My MGB fuel pump is always ticking, is this natural or should they cut off after its primed itself
On most MGB's they slow down and tick about every 4 seconds once the carb float chambers are full.
Feb 26, 2015 | Triumph tr250,tr6 fan belt mgbgtv8. fan...
How do i reprime ?
Close the supply valve to the tank. Open the priming port of the pump, (plug on the upper most part of the casing) pour in water until the pump is filled -up. Close the plug just finger tight. Run the pump. slightly open the plug just to bleed the air with little water. If all water is coming out, the pump motor should cut-off indicating the pump is already primed. Gradually open the supply valve. Pump motor will restart again.
Nov 12, 2012 | Fresh Water Systems WellMate Tank Fittings...
I have a Sta-Rite Max-E-Glas II (1.5hp) Pool pump and a Hayward Navigator sweep. The sweep was working then stopped. Pulled it apart found bad bearings replaced them. Ran sweep again worked at first...
Is the pump leaking water? If you lost the prime or are having trouble priming then there would be an air leak somewhere on the suction side of the pump. Poor suction would interfere with the sweep. One way to ell if the pump or suction line(s) are leaking is to examine the inlet basket once the pump is primed. Any air left in there after a few minutes of operation once primed would indicate a leak in the suction/pump.
Jan 04, 2010 | Zodiac BARRACUDA G3 IN-GRND CLEANER
My well pump keeps losing its prime. The pump
There may be a slight leak within the suction piping, just enough to allow air to enter as its sits for an extended time. I'd be ceratin the foot valve is good and check over all of my suction pipe connections.
I hope this may have helped,
Tom
Oct 29, 2009 | Plumbing
I have a Flotec FP 4022-10 3/4 hp shallow well pump. It was working fine yesterday afternoon and then in the evening I had no water. I replaced the pressure switch and checked the pressure in the tank...
If heating up, the motor thermal switch is opening to shut down the motor; this is by design. During the brief run time does it pump at all? It sounds as if there may be mechanical issues on the pump itself and the motor (from the extra draw) is heating up and shutting down. I'd look in to the pump to see if anything had failed within it.
Tom
Jul 16, 2009 | Flotec Corrosion Resistant Shallow Well...
Grundfos MQ3-35  3/4 HP Pressure Booster Pump  Logo
1,393 people viewed this question
Top Grundfos Garden Experts
john h
jasbo
jasbo
Audrey Messer
Audrey Messer
Are you a Grundfos Garden Expert? Answer questions, earn points and help others
