Question about Garmin StreetPilot c550 GPS Receiver
Unlock code file for C550
Hi
I am having the same issue you had. what does the unlock code file look like. My tells me it can't unlock the maps after I updated the firmware on it.
Please help
Thank you
How long have you had your unit for? Most places get a 90 day free trial and then they have to pay for the service. If you have registered your unit, when you log in to your account, you will be able to see this information.
Posted on Apr 12, 2008
Hi sir my garmin fm trafic alart is not working so please help thanks
6ya staff
SOURCE:
My garmin nuvi 205 keeps telling my " No detailed maps found that support routing. The nuvi cannot be used without them."
The "No Detailed Maps Found That Support Routing" message may appear on your device for the following reasons:
  • The GPS device is missing it's unlock code
  • The maps on the GPS device have been disabled
To determine the cause of the message, touch the screen until the message "No Detailed Maps Found That Support Routing" disappears.
  • If you see a "Can't Unlock Maps" message following this error, remove any microSD / SD cards in the device and follow the instructions below for Retrieving your unlock codes followed by the instructions for Creating an unlock file
  • If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device at the bottom of this solution
To retrieve your unlock codes you must first register your satnav if you haven’t already done so.
To registe;
  • · Connect the satnav to your computer.
  • · Click on “myGarmin”
  • · Click on “Register Your Garmin Product” and follow the prompts
You’ll be asked to create a username and password. Write them down and keep them safe as you’ll need them anytime you want to update your maps.
Retrieving your unlock codes:
  1. Log into your myGarmin account
  2. Select Manage Maps
  3. Select Details
  4. The unlock code is located under the Installed Maps.
Creating an unlock code file for PC:
  1. Plug your Garmin device into the USB port
  2. Double-Click on My Computer or Computer located on the desktop
  3. Right-Click on the Garmin or nuvi drive
  4. Click Explore
  5. Double-Click on the Garmin folder
  6. Right-Click in a blank space in this window
  7. Move your mouse over the word New
  8. Select Text Document
  9. Press Enter / Return on your keyboard
  10. Double-Click on the New Text Document. This will open the New Text Document in a window called Notepad
  11. Type the unlock code that is listed in the Manage Maps section of your myGarmin account in all upper-case letters with no spaces
  12. Select File
  13. Select Save As
  14. Change the Save As Type to All Files
  15. Type gmapprom.unl in all lower-case letters for the File name
  16. Select Save
  17. Close the Notepad window
  18. Delete the New Text Document file
  19. Disconnect the GPS device from your computer
Enabling maps on the GPS device:
  1. Touch the wrench icon on the Where to/View map screen
  2. Touch Settings
  3. Touch Map
  4. Touch Map Info
  5. Select the checkbox next to the maps to be enabled on the device
Aug 13, 2010 | Garmin nuvi 205 GPS Receiver
Nuvii 660 shows maps are locked
You can do a factory reset to restore the factory defaults back.
Jun 28, 2008 | Garmin Nuvi 660 GPS Receiver
My GPS says " no detailed maps found that support routing. The Nuvi cannot be used without them." Tried resetting and no change
To retrieve unlock codes you need to have your satnav registered with garmin. If you haven't already registered it connect the satnav to your computer and go to https://my.garmin.com/mygarmin/customers/myGarminHome.faces and click Register your garmin device. Follow the prompts. You'll be asked to create a username and password. Write them down and keep them safe. You'll need them anytime you need to update your maps or solve problems in the future.
  3. Select Details
  4. Click Explore
  12. Select File
  13. Select Save As
  16. Select Save
Creating an unlock code file for Mac:
  1. Open the TextEdit application located in the Applications folder on the Mac HD
  2. Click Format
  3. Select Make Plain Text
  4. Type in the unlock code that you retrieved from your mygarmin account. The unlock code should be in all capital letters and with no dashes.
  5. Click Save As and name the file as gmapprom.unl (Note: Be sure to uncheck the box If no extension is provided, use .txt)
  6. Copy the gmapprom.unl file to the GARMIN folder on your device. (Note: Save the file directly to the Garmin mass-storage device if connected)
*nuvi x70 owners with transatlantic mapping will need to follow the Creating an unlock code file instructions above for their U.S. mapping and then create another unlock file for their European maps:
  4. Click Explore
  11. Type the European unlock code that is listed in the Manage Maps section of your myGarmin account. This will need to be typed in all upper-case letters with no spaces
  12. Select File
  13. Select Save As
  15. Type gmapprom1.unl in all lower-case letters for the File name
  16. Select Save
  2. Touch Settings
  3. Touch Map
  4. Touch Map Info
Aug 10, 2010 | Garmin nuvi 205W GPS Receiver
My maps on my Garmin Nuvi 205w GPs device are lock and I can't use it hoe do I unlock the maps to use my device again?
If you are getting the message “Can't unlock maps, your unit will not function without maps” on your Garmin device, there is an issue with the mapping on your device.
Please follow the steps below to restore the mapping:
  1. Go to www.garmin.com and log into myGarmin account. (If you haven't already registered your satnav you'll need to in order to log in)
  2. Select myMaps
  3. Click Manage Maps and Downloads
  4. Below the appropriate device, select the "Details" link
  5. Look for the Unlock Code listed on this page
  6. Copy all the unlock codes for your device
  7. Close your internet browser
  8. Right click on your desktop
  9. Click new, and then click Text Document
  10. Click on the newly created Text Document icon from the desktop
  11. Type your unlock codes into the document
  12. Click File and Save as
  13. Change the file name to gmapprom.unl
  14. Change the “Save as type” to "All files"
  15. Close the document you should see the file gmapprom.unl on your desktop)
  16. Right click on the gmapprom.unl file and then click copy
  17. Connect your Garmin device to your computer and click Computer/My Computer
  18. Click on the 'nüvi (drive letter:)'2
  19. Right click on the Garmin folder and click paste (see next line for nuvi 1xxx series)
  20. For nuvi 1xxx series devices, the gmapprom.unl file is required in the ".System", "Garmin" folder which is a hidden system folder. In order for you to see the hidden system folder:
    • For XP:
      1. In MyComputer go to the Tools menu and choose Folder Options...
      2. Select the View tab
      3. Select the radio button next to "Show hidden files and folders"
      4. Uncheck the box next to "Hide protected operating system files (Recommended)"
      5. Click OK
    • On Vista:
      1. In the Computer window go to the Organize menu and choose "Folder and search options"
      3. Select the radio button next to "Show hidden files, folders, or drives"
      5. Click Ok
Safely disconnect your Garmin device from the computer to complete the process. If you are having any issues duplicating the steps above or are still receiving the message "Can't unlock maps, your unit will not function without maps” please contact Product Support.
1 The device must be registered to view the Unlock Code.
2 In My Computer, some units may be labeled 'garmin (drive letter:)'.
Aug 04, 2010 | Garmin nuvi 200W GPS Receiver
Cannot unlock maps on my garmin gps
go to garmin.com and ask for unlock codes. you may have to pay for them
Oct 31, 2009 | Garmin StreetPilot c550 GPS Receiver
Garmin Nuvi 200 Maps Disappeared
Hope this helps!
I wanted to add maps to my 250W. I found the maps I wanted on a Torrent. However, many searches around various forums never revealed how to install these. Found the following through reading and experimentation.
1. Downoaded map image file GMAPSUPP.IMG. Download also gave me "Use code XXX when generating unlock code for maps"
2. Downloaded Garmin Unlock Generator 1.3 by JetMouse
3. Looked on my GPS to find the UnitID
4. Entered the UnitID into Garmin Unlock Generator. Ignore the GM XT device unlock code and the top Generate button.
5. Selected Map Product as Custom and entered the code given for the downloaded image file.
6. Hit the bottom create button to generate a 25 digit code.
7. Download Img2Gps and run
8. Click Load Folder to load the image file. Select the tick next to it.
9. Check the Use Unlock Key option and paste the 25 digit code in.
10. Load a blank SD card into your Garmin
11. Connect the Garmin to your PC using a USB cable. You should see two dirves in windows: one is the Garmin and the other is the "Removable Disk" SD card.
12. Create a folder called "Garmin" on the SD card
13. Select Folder/Card in Img2GPS
14. Click "Copy Maps". Select the folder /Garmin on the SD card. You may need to click copy again.
15. Upload will take a while.
16. You should now see a file GMAPSUPP.IMG on the SD card in the /Garmin directory.
17. Create a new text file called GMAPSUPP.UNL in the same directory (make sure it does not have a hidden .txt extension).
18 copy the 25 digit unlock key into this file.
19. Close the file.
20. Disconnect the Garmin.
21. On Startup it should load your original maps and the new ones.
May 28, 2009 | Garmin nuvi 200W GPS Receiver
Garmin nuvi 200 after upgrading drivers, it keeps on saying cant unlock maps. How do I fix\ unlock maps if iI havent loaded any new maps
Go to your account at garmin that you created to manage your maps.
Click myMaps
Click Manage Maps
You should see your unit and it’s unlock codes
Click new, and then click a new Text Document
Change the file name to gmapprom.unl (( double check this please ))
Close the document
You should see the file gmapprom.unl on your desktop
Plug your Garmin device in and then click Computer/ My Computer
Click on the nüvi drive
Regards
Richard.
May 18, 2009 | Garmin nuvi 200W GPS Receiver
Updated software, now unit tells me im missing software.
You need the unlock codes from your account at Garmin....
Click myMaps
Click Manage Maps
(( important double check this please ))
Close the document
Regards
Richard.
May 18, 2009 | Garmin GPS
It says . cant unlock maps.
Follow this below
Click myMaps
Click Manage Maps
Close the document
Regards
Richard.
May 18, 2009 | Garmin Nuvi 255 GPS Receiver
Pin unloock
how do i unlock my garmin i never put i pin number but is asking me the pin is a garmin street pilot c 550 thank you
Sep 23, 2007 | Garmin StreetPilot c550 GPS Receiver
Garmin StreetPilot c550 GPS Receiver Logo
173 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
